Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-23-2018, 11:55 PM | #1 |
Drives: GTS 86 auto
blame springs or dampers most
We are tiring of the jiggly harsh ride. Everything is o.e.
Tire deflation from 35 to 31 makes negligible difference but when worn we will replace with ones with softer walls. The next step is suspension. Which is mostly to blame of these two --- the springs or dampers?
GTS86 Auto (Australia)
10-24-2018, 12:08 AM | #2 |
Drives: Car
Dampers are more likely to fail first. How many miles/km do you have on the car? Could try to get a fresh set of OEM dampers or upgrade to coilovers.
The Following User Says Thank You to FirstWinter For This Useful Post: | notout86 (10-24-2018) |
10-24-2018, 12:31 AM | #3 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Coilovers won't necessarily be an upgrade...it could very likely result in the opposite unless the dampers are high quality and tuned well. That said, if OP is willing to spend the money on a quality set, it could yield some good results.
OEM dampers won't be much better IMO, though the Sachs dampers from the newer models are markedly better. If ride quality is your primary concern, maybe consider getting smaller sized diameter wheels with taller tires? Like a 16x8 maybe? Having a taller sidewall will provide some extra cushion over the bumps and can make a noticeable difference in ride quality, especially if you choose a cushier tire. |
The Following User Says Thank You to BlueWhelan For This Useful Post: | notout86 (10-24-2018) |
10-24-2018, 03:09 AM | #4 |
Drives: 2014 GT86
2013? OE shocks? Imho they might be to worn by mileage. Try to get used set of MY2017 shocks from someone parting out after change to coilovers.
The Following User Says Thank You to churchx For This Useful Post: | notout86 (10-24-2018) |
10-24-2018, 03:56 AM | #5 |
My 2017 PP Sachs suspension was rubbish in my "opinionated" opinion......
They lasted 4k km before I swapped them out with some MCA Street Performance coilovers. The MCA's are much much better everywhere.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
The Following User Says Thank You to 86MLR For This Useful Post: | notout86 (10-24-2018) |
10-24-2018, 04:46 AM | #6 |
Drives: GTS 86 auto
Thanks for the comments people. Although everything is still o.e. and are now 5 years old, the mileage is only 30,000miles / 53000km. It has hardly done any distance on rough dirt roads.
Moreover, I recently demo-drove a latest BRZ to compare ride quality as I heard they were better. I took my car on the same route. Beforehand I ensured tire pressures on both cars were all at 35psi. Any difference was minimal so I do not think the dampers are deteriorated. So my question remains is the harshness/jiggliness due more to springs or dampers?
10-24-2018, 05:14 AM | #7 |
Dampers
Well in my opinion, mine were rubbish on anything but smooth roads, bumps and speed humps = crash bang. My new coilovers are much more compliant on low speed bumps and speed humps, and the performance at speed is night and day. I believe the OEM valving was designed around smooth surfaces, throw some real world local roads in the mix and the OEM's fall over badly. Opinions will vary. My advice is to go for a spin in a car with "decent" coilovers and see what you think. Be aware that alot of aftermarket stuff, if it isn't valved and sprung right, will be poor for daily use. My coilovers are valved and sprung for real world roads, but are still very good for "spirited" driving and the occasional track day and khana. There is always a compromise when you want performance and comfort, I believe mine are on point for my requirements. Happy hunting
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits Last edited by 86MLR; 10-24-2018 at 05:29 AM. |
10-24-2018, 07:59 AM | #8 |
Country Boy 4 Life
IMO...
Dampers - Upgrade to koni yellow or Bilstein B6. This should (if any of the reviews are honest) give you a better and more comfortable ride. Springs tend to not wear out. (though older springs sagged pretty bad) I am betting with the miles (kilometers?) you have put on your car, that your springs are just fine.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | notout86 (10-24-2018) |
10-24-2018, 10:07 AM | #9 |
Drives: '13 FRS - STX
OE springs are as soft as you'll get, aftermarket is stiffer. Maybe if koni offered their fsd that'd be the way to go but idk, everyone who buys a sports car wants to make it sportier, not softer. I agree, OE ride is pretty sub par.
The Following User Says Thank You to strat61caster For This Useful Post: | notout86 (10-24-2018) |
10-24-2018, 10:53 AM | #10 |
Drives: '23 BRZ
Ride quality is almost all down to damping. Crappy dampers will feel both *harsh* due to excessive high-speed damping, and "jiggly" due to insufficient low-speed damping. Decent dampers cost more...
The Following 5 Users Say Thank You to ZDan For This Useful Post: | notout86 (10-24-2018), Racecomp Engineering (10-24-2018), strat61caster (10-24-2018), Tristor (10-24-2018), wparsons (10-24-2018) |
10-24-2018, 11:51 AM | #11 | |
Drives: 2019 BMW ///M4
The Flex As also have a Hydraulic Bump Stop (HBS) to help with bumps and stuff like that. It seems to have helped out for comfort in the terrible LA roads we have here.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
The Following User Says Thank You to N1rve For This Useful Post: | notout86 (10-24-2018) |
10-24-2018, 11:53 AM | #12 | |
Country Boy 4 Life
I LIKE TIRES! |
10-24-2018, 11:54 AM | #13 |
No. I used the camber plates that Tein supplies on their coilovers. I didn't modify the coilover.
N1rve
The Following User Says Thank You to N1rve For This Useful Post: | Leonardo (10-24-2018) |
10-24-2018, 04:27 PM | #14 |
LMGTFY
Drives: 13 FRS, 91 Miata
What tires do you have on the car?
(NOT size,but actual brand/model) |
Tags |
springs dampers |
Similar Threads | ||||
On springs - add dampers or go coilover for my needs? | re-animator | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-20-2018 04:14 PM |
swift springs and oem dampers | bartuc | Brakes, Suspension, Chassis | 1 | 10-20-2017 10:01 AM |
WTB: OE FRS Dampers/Springs | RYU | Brakes, Suspension, Chassis | 1 | 09-09-2013 06:05 PM |
Best springs to go with stock dampers | solidONE | Tracking / Autocross / HPDE / Drifting | 15 | 07-01-2013 01:36 AM |
GT86 springs on FR-S dampers? | jm1681 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 10-01-2012 12:36 PM |
