Old 08-12-2019, 12:21 AM   #43
86MLR
86MLR's Avatar
New rubber
RE003 235/45 17
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 08-12-2019, 08:56 PM   #44
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Originally Posted by 86MLR View Post
Punched out cat in front pipe.
Can you describe the process you used to 'punch out' the cat in the FP? I am thinking about doing the same since my state no longer requires emissions testing.
Is the Cat some kind of filter/paper material that i can just cut and gut?
DuMa is offline   Reply With Quote
Old 08-12-2019, 11:14 PM   #45
86MLR
86MLR's Avatar
Warning: cats are filled with magical stuff called heavy metals which will fuck you up if inhaled.
Dispose of the waste at a local exhaust shop, double bag it, treat it like asbestos.
RACE USE ONLY
Use PPE.
Tools required
1 x drill
1 x big long drill
1 x hammer
1 x screw driver
My favorite youtube >
Stop after step 5, cutting out the cat and welding in a straight pipe showed no advantage, again, NA power levels.
The video is of a aftermarket "metal" cat, a OEM honeycomb cat will break up alot easier.
I would grab a spare to punch out, for if you decide to sell the car, or you need to have the car compliant if you move
Pity your not local, I have a few front pipes laying around, that will be put out in the next metal waste collection.
Old 08-13-2019, 08:28 PM   #46
86MLR
86MLR's Avatar
Hooray for internet shopping
The Following User Says Thank You to 86MLR For This Useful Post:
Boomerang (08-14-2019)
Old 08-19-2019, 11:04 PM   #47
86MLR
86MLR's Avatar
And in
MCTeeJ (08-20-2019)
Old 08-19-2019, 11:36 PM   #48
Lantanafrs2
Drives: 2013 frs red
Nice car. Nice results from the tune!
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
86MLR (08-20-2019)
Old 08-20-2019, 10:11 AM   #49
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
And in
Been shopping around for RLCA. How much do you trust that bolt to stay in place over bumps and whatnot? This isn't meant to agitate, I'm genuinely asking.
MCTeeJ is offline   Reply With Quote
Old 08-20-2019, 05:19 PM   #50
86MLR
86MLR's Avatar
I haven't heard of any issues
When torqued down correctly (tight as) I cannot see it moving
I prefer this over the pillow ball style, I had issues with threads seizing before, and install took about 1 hour all up
MCTeeJ (08-21-2019)
Old 08-28-2019, 03:09 AM   #51
86MLR
86MLR's Avatar
Put some new Penrite 5w 30 and a Subaru oil filter in/on today.
It was a early change, normally I change every 5k km (severe conditions, dusty hot Australia), but as the car is going in for boost soon, and I gave myself a free arvo at work, I changed at 4k km.
Also trimmed the nipple of the Fumoto drain valve, finally, I got p/n F108n instead of F108, the nipple on the F108n sits to low, but it was nothing a hack saw and dremmel couldn't fix.
Old 09-06-2019, 03:17 AM   #52
86MLR
86MLR's Avatar
Pulse Racing and AVO strike again.
The graph is from the initial run prior to NA tuning, to now running some boost.
The feeling between NA and boosted is summed up in one word, WOW
JesseG (02-25-2020), MCTeeJ (09-11-2019)
Old 09-11-2019, 12:00 AM   #53
86MLR
86MLR's Avatar
Incoming
Not required, only for the LOLS
The GFB Respons, not the sticker
JesseG (02-25-2020)
Old 09-16-2019, 05:07 AM   #54
86MLR
86MLR's Avatar
I has Pssshh for the LOLS
Only opened a bit currently so only minor LOLS, I tried it everywhere from 100% which brought all the bangs to the exhaust and PSSSHHH to the extreme, right down to closed with nil psshh's
Spring is wound down pretty tight, so only really vents at max boostage, under that its very minor dosage
LOLS are pretty good
Old 10-02-2019, 03:26 AM   #55
86MLR
86MLR's Avatar
Contemplating a catback or axle back.
Car sounds stock, except for turbo spooling and tyres slipping.
Conundrums:
1. Pre fab - Invidia? N2? R400?Cold start noise?
2. Shop made - pretty much design what I want with the sound I want.
1. Pro: Would be cheap and I get to install, Con: get what I get given sound/drone wise
2. Con: Would be a bit more expensive vs the massed produced item, Pro: able to test what it sounds during the build, Con: I don't really get to install.
2. Found this axle back pic on the nets, will need to speak to my local exhaust shop, Pro: stock rear pipe and resonator, Con: Cost???, not really any other cons that are blinding obvious.
Disclaimer: this is not a performance modification, I'm after just a little more sound.
Hmmmmm
Old 10-02-2019, 10:30 AM   #56
Lantanafrs2
I've always found that avo kit interesting. Passed on a used one couple years ago. Still regretting it
FS: 2017 PP Sachs Dampners and 2017 stock front sway bar doctor_driver Brakes, Suspension, Chassis 2 12-26-2018 07:21 PM
Stg 2 OF on stock 2017 with auto 22R Software Tuning 1 04-16-2018 11:58 PM
2017 Stock Suspension VS RCE Yellows on Stock 13 FRS TeutonicShift89 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 04-06-2018 08:39 PM
Stock 2017 FR-S / BRZ Needed for R&D FRSport.com Southern California 2 09-21-2016 12:56 AM
