08-19-2019, 09:10 AM | #1135 | |
Drives: 13 Scion Frs
The service advisor handed me off to the guy in charge of the garage and wasn't seen from again. This was around 5:30pm on a Friday. Unfortunately I do not have proof of oil changes, I never really thought this would ever be a thing that was necessary, clearly I was wrong. You're definitely right about the Oil filter unfortunately. Not sure how much it may matter, but I intend on recording when we open it up(hopefully later on this evening) with my neighbors tube/pipe(?) cutter. I mean would someone really just have an oil filter lying around that would (hopefully) have bits of RTV inside of it? |
08-19-2019, 10:06 AM | #1136 | |
Drives: frs
And it is possible they cleaned up the pick up tube. Your last hope might be to find out where they put RTV and how much. There are certain areas on the engine where they are not supposed to put RTV and the amount is also important. |
08-19-2019, 10:18 AM | #1137 | |
Excessive sludge buildup pretty much went away with the wide spread use of detergent oil. Back in the mid 50s, the worst thing you could do to an engine was to start using detergent oil after it had run on non-detergent oil all it's life. Oh well, let's hope they get your car's engine fixed up soon. humfrz |
08-19-2019, 11:03 AM | #1138 | ||
08-19-2019, 11:07 AM | #1139 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Dadhawk (08-19-2019) |
08-19-2019, 02:11 PM | #1140 | |
Drives: 2013 Firestorm FR-S AT
And this. |
The Following User Says Thank You to RickyBobby For This Useful Post: | Ultramaroon (08-19-2019) |
08-19-2019, 04:47 PM | #1141 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
yeah its painful to see so many issues yet people still keep taking their cars in. Im guessing most people don't post on here until after they have issues instead of researching beforehand. Because we are supposed to "Trust" a large corporation like Toyota |
08-19-2019, 06:51 PM | #1142 |
義理チョコ
It takes some real insider knowledge to decline this recall with confidence. I feel bad for the owners who have no choice but to trust Subaru's severely flawed decision.
08-19-2019, 09:29 PM | #1143 | |
No way on earth would they have touched you engine if it had metal shavings in the oil. This is a clear cut lie. If there are metal shavings in your oil the engine is already toast and they wouldn’t risk working on it and then getting blamed for a blown engine one mile after being picked up. |
08-19-2019, 09:55 PM | #1144 |
Drives: 2013 FR-S Series 10
Pardon my language but fuck these irresponsible pricks. Ruin someones engine and say hnyyyaaah theres no way the sealant could have gotten in there.
The Following User Says Thank You to Decep For This Useful Post: | SuperTom (08-20-2019) |
08-20-2019, 09:19 AM | #1145 | |
I wouldn't need insider knowledge. The amount of problems found just on this forum would be enough for me. Especially if the reason for the recall has never happened to me. Basically don't Fk with it if it aint broke |
The Following 3 Users Say Thank You to SuperTom For This Useful Post: |
08-20-2019, 11:51 AM | #1146 |
Dismember
Drives: 2013 Red Scion FR-S
Gotta do it to register the car in Cali.
08-20-2019, 12:22 PM | #1147 |
08-20-2019, 12:48 PM | #1148 |
Dismember
I don't think it's that great a chance. Note every dealer is incompetent. Most are smart enough to see a major repair and put the right people on the rob. My service adviser said they put the guy who builds engines all day every day for a hobby on the job. They'd done 14 of them by the time I got my car back, and only one had come back with a serious issue, a transmission misalignment that was easily fixed. I'm only 2500 miles or so in, but I've been driving it like I stole it. No issues other than the broken aftermarket header, and that header had been welded like five times before, so it wasn't the dealer's fault. It's just not a panic issue. Avoid it if you want, sure. But trade in and buy another one? Meh.
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Similar Threads | ||||
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
