06-15-2016, 08:37 PM | #407 |
Drives: 2013 WO FR-S
@heatherger which dealership did you go to? Can you pm me?
06-26-2016, 02:28 AM | #408 | |
Drives: 2013 Asphalt FR-S/2003 Honda Accord
When u had ur squeak sound.. was ur clutch felt crunchy at the end of the trave as well? Sent from my Nexus 5X using Tapatalk |
06-26-2016, 02:01 PM | #409 | |
chicken tonight
When inspecting/cleaning my spare yesterday, I saw that the snout and the fork pivot were both caked with clutch disk material that had been absorbed by the applied lubricant. The combination had become a gritty abrasive mess.
The Following User Says Thank You to Ultramaroon For This Useful Post: | bhbnuckle (07-03-2016) |
06-27-2016, 01:43 PM | #410 |
Drives: 2013 Subaru BRZ MT Limited
No, my squeak was just from lack of grease on the tip of the throwout fork where the slave cylinder presses on it. You're supposed to put some grease on there every so often. I use High Tempurature bearing grease from Lucas Oil and just put it on whenever it starts squeaking.
Silver 2006 Toyota Tacoma Double Cab 4WD Longbed, Name: Loki - God of Mischief and Chaos
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
06-28-2016, 11:11 PM | #411 |
I got call from Dealership today and saying that my tranny need to be parted out in order to find out exact cause and must send to HQ for approval. If HQ deny on warranty (my b2b warrany expired period wise 2 month ago but only driven 38,000 km) ill have to pay off the diagnose and all the fee which they quoted replacing bearing would be 600+ tax. Idk what to do at the moment.
Let me hear from you guys if anyone had similar situation. Thanks in advance Sent from my Nexus 5X using Tapatalk |
06-29-2016, 02:56 PM | #412 | |
Waited 5 years for this
Drives: '18 MX-5 Club
Is your car just making the noise and still driveable? I drove mine with the noise for 1 year, 10k miles before I got it fixed. If yours is just the noise and nothing else, then you should try another dealer. Edit: I said if it's just the noise, but I also had a little bit of crunchy feel at the end of the travel as well. |
The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | bhbnuckle (07-03-2016) |
06-29-2016, 04:40 PM | #413 | |
Turning is for Nerds
Drives: 35 characters is not enough
06-29-2016, 04:49 PM | #414 |
chicken tonight
I'll post up good pics tonight. Complete breakdown of the oem lube. Separation, caking, drop, all of it. Dunno what they used or if the #2 Red will fare any better. We'll see over time.
Bottom line - get in there and clean it all up before all the parts wear even more. It's a gritty mess.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Sigh-on-Rice (06-29-2016), ZZT86 (06-30-2016) |
06-29-2016, 04:55 PM | #415 | |
I put some of Red Tacky #2 grease in there but no luck.(w/o removing the slave cylinder) Thanks Last edited by bhbnuckle; 06-30-2016 at 10:14 AM. |
06-29-2016, 05:10 PM | #416 | |
I guess what I'm getting at is, scare me. |
06-29-2016, 05:46 PM | #417 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I'm still confused. I have this issue. Same as OP. Only happens after the car has been driven for a bit (so clearly something needs to warm up) and it's just a squeak at the bottom travel of the pedal. There is a bit of "crunchiness" in the pedal, but it just matches the creak, as if it just isn't traveling smoothly because something isn't properly lubricated.
It seems for all the world like it is just a lack of lubrication somewhere, and yet tons of people in this thread have had entire clutch assemblies replaced, or throwout bearings replaced. Which is it?!?! Once the car is warmed up, it will make the same noise whether the car is on or off. That makes me thing it isn't the bearing, but what do I know...? |
06-29-2016, 11:00 PM | #418 | |
Imma pull the dust boot off and spray whitr lithium grease follwoing weekend. Will be updating the result! Sent from my Nexus 5X using Tapatalk |
06-30-2016, 12:01 AM | #419 | |
chicken tonight
full size image You can see how the lube just melted (dropped) It's sticky like tar. full size image The bearing itself is in perfect condition; buttery smooth - zero noise. full size image You're welcome to come up and check it out for yourself. I haven't touched the original parts. They shipped the fork and TOB with the spare trans so that's what I'm running now.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
06-30-2016, 12:08 AM | #420 | |
chicken tonight
Similar Threads | ||||
Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 08:58 AM |
Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 02:10 PM |
Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 06:44 AM |
Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 01:00 AM |
