11-14-2017, 08:05 PM | #2983 | |||
But really, if you wanna show up at a National Event and try and contest the rule you and try to force someone to protest, you will not win. Quote:
Note 1. is a detail going more into detail that a upper and control arm cannot both be substituted, for majority of us the lower control arm is the preferred route to go. However, if you wanted you could leave the lower control arm in place and swap the upper control arm and maintain legality. Toe adjustment is considered a link, and does not correct Camber (from section H) and thus is illegal. Just a question. You think since 2013, and the amount of attention STX has received from National Competitors and Champions...toe links has slipped through the minds of everyone? If you think I'm fighting, I'm not. It really isn't an argument. It's a statement....they are not legal. If you want to write a letter, like I did...go ahead. Mine was pretty simple: Quote:
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post: | dowroa (11-14-2017), strat61caster (11-14-2017) |
11-14-2017, 09:01 PM | #2984 | |||
Both links are required to lengthen or shorten to achieve desired alignment, the spirit of 14.8.H is to allow competitors to achieve desired camber in an affordable fashion, I think we can both agree on that statement at least. Whatever nomenclature is used to describe a part is irrelevant, for instance Subaru lists the parts as "Lateral Link Front" and "Lateral Link Rear" not a single part with "Toe" in the name in the entire rear suspension assembly. https://parts.subaru.com/a/Subaru_20...10-201-01.html As I keep repeating, 1 a-arm = multiple links, if you can change one a-arm you should be able to change the lateral links that are substitutes for that a-arm, it's defined in the SCCA rules that the two are equivalent. 14.8.H uses plural language combined with the previous letter that allows for multiple camber kits to be used I think changing the 'toe link' is on solid ground. Quote:
Here's how the rule was written for 2003: Quote:
People who have been doing this long enough to fight near the pointy end have usually figured out that the magic isn't in a friggin' toe link. We're not changing geometry here, just making it easier to adjust. I appreciate you writing a letter, it's concise and to the point and open ended, nothing else to do but wait and see what the response is, and none of my grumbling will change that so I won't bother. Either multiple lateral links were always allowed or they weren't. Last edited by strat61caster; 02-23-2018 at 12:08 PM. |
11-16-2017, 09:23 AM | #2985 |
APEXHNTR
Drives: 10 Series FR-S #1867
I can see both arguments equally and still cant figure out what side to be on haha
I'm drawn back by "if it doesn't say you can, then you can't" cant wait to hear what SEB says...
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
The Following User Says Thank You to Silver Ignition For This Useful Post: | DocWalt (11-17-2017) |
11-17-2017, 01:27 PM | #2986 |
Drives: '22 BRZ
IMO an "a-arm" is the lower link (camber arm) and the trailing arm (which you can't change anyway)... toe arm is completely unrelated.
11-17-2017, 02:30 PM | #2987 | |
1 wishbone controls suspension location and orientation in all three directions with 2 wishbones needed for full suspension control, the 86's multi-link uses 3 links to accomplish the same feat as a single wishbone with an upper wishbone finishing off the assembly. The "front lateral link" (aka toe arm) is not 'unrelated' at all, it serves the exact same function to adjust alignment as the 'front' wishbone bushing does on a double-wishbone car. Last edited by strat61caster; 11-17-2017 at 03:18 PM. |
11-17-2017, 03:17 PM | #2988 |
APEXHNTR
Eh sorry strat I think its a reach...it'd take some real semantics and verbal gymnastics to appeal a protest at a national event for toe arms...
11-17-2017, 03:42 PM | #2989 | ||
Whether or not it's legal is certainly a different story, I've played that game before, I won't argue with the results of the letter written by @M0nk3y I'd probably agree wholeheartedly updating the wording if the intent isn't coming across in the current language. At this point I only want to spread knowledge about suspension design. And jeez, I just want to DIY alignment without pulling my hair out, I'm not actually trying to get a competitive advantage (aside from making future test and tunes more effective). |
11-17-2017, 05:22 PM | #2990 |
APEXHNTR
I’m rooting for toe arms being legal. My left side eccentric is frozen to the bolt in the rear...
11-20-2017, 09:48 AM | #2991 | |
Drives: 2013 Satin White Pearl BRZ
Sent from my Pixel using Tapatalk |
The Following User Says Thank You to jbailey8748 For This Useful Post: | strat61caster (11-20-2017) |
11-28-2017, 02:07 PM | #2992 |
Drives: Many
I'm confident I know the answer to my question already, but what are the current STX lca options that are available?
Racer-X doesn't sell poly any more. And isn't really wanting to play ball on selling me replacement bushings. Velox RS-R SPC/Dif bushings SPL with steinjager poly Is there a middle ground between $550-600 and the SPC/Dif bushing setup that I'm missing? Last edited by e1_griego; 11-28-2017 at 02:22 PM. |
11-28-2017, 02:32 PM | #2993 | |
Drives: Some kind of Subaru
11-28-2017, 07:04 PM | #2994 | |
Really? Shame on RacerX. I love my arms from them. They had a Instagram post about making the arms in a different material and offering bushings again. Guess that never took off. Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
11-28-2017, 07:46 PM | #2995 |
Drives: Many
I think I'm must going to have a buddy make some new bushing cups for them, and I grabbed some DIF bushings to use.
Will update once everything is back together. Racer-x said I could send them by cups back to rebush, and I've asked twice for an invoice/cost and haven't heard back. |
The Following User Says Thank You to e1_griego For This Useful Post: | strat61caster (11-30-2017) |
11-30-2017, 01:05 AM | #2996 |
Shame on Racer-X they were the only <$500 LCA with an ST* bushing off the shelf when I bought mine aside from modifying an SPC.
If I had to replace them I'd do the same thing, find some poly bushings to press in. But yeah I think you listed everything except the Whiteline... which as far as I can tell is basically SPC+Dif bushing in one box. |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
