Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
04-20-2015, 02:07 PM | #15 | |
Drives: 2014 Ultramarine FR-S
04-20-2015, 02:41 PM | #16 | |
If the wrinkles are in an area where it already overlaps the main shell, just sand/grind it away. The fleece doesn't need much overlap on the shell, even 1/2" is plenty to hold the shape until more glass is wrapped around it. Instead of bondo, you can make a paste with resin and microballoons as a thickener. Using this instead of bondo to smooth the outer wrinkles will create a stronger bond than having a layer of brittle bondo in between layers of glass. Mix it quickly (so it doesn't kick too early) until it has a consistency like frosting. If you want to add strength inside the enclosure, you can use this thickened resin like caulk around the inside corners where the fleece meets the shell. This isn't quite as strong as fabric, but the microballoons add structure to the resin, and you can smear it around blindly into the corners without having to see everything. Use a mirror on a stick to see what's going on in there. I recommend starting at the farthest, hardest to reach area first, and working toward your opening. (Again this isn't necessary but can help add some strength). Last edited by wheelhaus; 04-20-2015 at 05:11 PM. |
04-29-2015, 11:09 PM | #17 |
Build Update:
I finished fiberglassing and did a test fit in the car. It fits like a glove and I think it looks pretty good. Next step is body filler and sanding, then more body filler and more sanding and so on and so on...
Let me know what you think! |
04-30-2015, 03:55 AM | #19 |
Drives: Toyota GT86
poor Woofer ... with some holes in it. You need a Grill
04-30-2015, 10:45 AM | #20 |
04-30-2015, 02:40 PM | #21 |
Drives: 2013 BRZ Limited SWP 6MT
Looks good! I've been wanting to do this in my audi for years.
OVR-SCCA Course Design and SSSI |
04-30-2015, 03:24 PM | #22 |
Looks great so far!
05-08-2015, 04:26 PM | #23 |
Build Update:
I went a little crazy with the bondo but it looks really smooth now. I'm pretty happy with this for now. The fit is perfect. I was worried layers of fiberglass and bondo might make it not fit quite as well but it still fits.
Here are a couple pictures of the build so far. This is mostly stuff I finished over the weekend but haven't gotten a chance to upload the progress yet. I just ordered some carpeting to cover it but I have to wait for that in the mail so I am sort of stuck for now. My plan is to start working on some wiring and maybe look into plans for an amp. as you can see from this picture I left the back a bit unfinished but hopefully none of that will show so it won't be a problem. I still put a layer of bondoglass in some of the weak looking areas on the back, that's why its a different color. I also knocked down some of the high spots so at least it slides smoothly. I do also need to think about a terminal cup. I might have shot myself in the foot by not taking it into consideration earlier but I hope there is a flat enough spot to put one that won't require too much fabrication. I'm thinking I will probably put it on the back in that flat spot towards the right hand side. Let me know what you think! |
05-09-2015, 01:57 PM | #24 |
Frosty Carrot
Drives: The Atomic Carrot
Great work! Fitting a 12 in our trunk is a challenge, and everything is coming out looking professional.
There's no shame in Bondo. You could paint or vinyl it with that smooth of a finish. Thanks for taking the time to post it up.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
The Following User Says Thank You to Shankenstein For This Useful Post: | ハチロク (05-09-2015) |
05-21-2015, 11:02 AM | #25 |
Build Update:
I'm almost done!!!
here are a couple of pictures of my progress so far. I am working on wiring and installing an amp now and hopefully I'll be able to post the final build after the weekend. |
The Following User Says Thank You to ハチロク For This Useful Post: | niceguy21 (05-24-2015) |
10-02-2015, 11:17 AM | #26 |
Socal Valley 86 Member
Drives: 2000 Toyota Tacoma SR5 & Scion FRS
Tags |
12", build, enclosure, fiberglass, subwoofer |
Similar Threads | ||||
FR-S / BRZ / GT 86 - Fiberglass Subwoofer Enclosure Prototyping by Integrity Concepts | Integrity Concepts | Electronics | Audio | NAV | Infotainment | 302 | 11-16-2018 11:47 PM |
How do I create a "build thread" link? | NWFRS | Site Announcements / Questions / Issues | 2 | 02-25-2015 03:14 PM |
Meet "Cloud" Errol's FR-S Build Thread | RainEG | Member's Car Journals | 12 | 08-01-2014 05:18 PM |
Vicious LED "BABYLFA" Asphalt FR-S Build Thread! | Vicious LED | Member's Car Journals | 111 | 01-24-2014 02:20 AM |
