Forced Induction Turbo, Supercharger, Methanol, Nitrous |
11-25-2014, 10:11 PM | #1 |
Drives: Brz
I like turbo delay question
The following might be riddled with nonsense but please educate me , thanks in advance, here goes
I know most ppl will probably disagree but I like lag. Not in terms of throttle response , but i like the delay of boost only kicking in above ~5k rpm and BOOM! I like the idea of having the turbo being semi off and being docile while i m just cruising and having my car feel stock when driving regularly , basically what i m asking for is a really skewed top end powerband turbo , kinda like what aggressive cams would do So far most kits do a amazing job smoothing out the curve / removing torque dip , but i just want a turbo that really changes the car in the higher rpm and pretty much keep it stock on the low rpms i never really go below 4k rpm during spirited driving anyways Is this all the tune ? Or is there a kit/ big turbo out there for edit update , after gaining further understanding i now understand i need a controllable wastegate via ebcs, preferably with a recirculating bov a big turbine is prefered but not neccessary [ame="https://www.youtube.com/watch?v=zenMEj0cAC4"]How Turbochargers Work - YouTube[/ame] < this guy is great makes some of the most informative videos i think he should be featured on most forums lol http://www.ft86club.com/forums/showthread.php?t=48689< thanks for the info @pixel67 again thanks for all your inputs! Last edited by RaineyStar; 11-26-2014 at 01:14 AM. |
11-25-2014, 10:18 PM | #2 |
Drives: frs
Tune, probably a "big" turbine
The Following User Says Thank You to Teseo For This Useful Post: | RaineyStar (11-25-2014) |
11-25-2014, 10:42 PM | #3 |
Senior Addict
Drives: 86 GT
When you were younger did you like saying "VTEC just kicked in YO!!!"???
11-25-2014, 10:44 PM | #4 |
Drives: Brz
11-25-2014, 10:50 PM | #5 |
義理チョコ
Subbed for interesting question. Oversized yes, but...
The Following User Says Thank You to Ultramaroon For This Useful Post: | RaineyStar (11-25-2014) |
11-25-2014, 10:57 PM | #6 |
in orbe terrum non visi
Drives: violent
Check my build thread. My first tune went from 200 whp to 460whp in only 1000rpm. Very hard to control. That was with a manual boost controller. With an ebcs you could make it even worse.
11-25-2014, 11:04 PM | #7 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
full blown stage 2 with gtx35r seems to fit what you want.
11-25-2014, 11:16 PM | #9 |
Drives: Brz
11-25-2014, 11:20 PM | #10 |
Drives: 2JZ FRS
A precision 6766 should have enough lag for you. Your goal for lag is kind of weird, opposite of what most look for lol
11-25-2014, 11:23 PM | #11 |
Drives: Scion FRS
Yeah if a GTX35 isnt laggy enough your going to have to look into a transmission swap because a turbo bigger than that is going to cause a host of issues
I think you would be happy with a gtx3076 or gtx3576. |
11-25-2014, 11:34 PM | #12 |
Drives: 23 BRZ
What you are describing is torque, and a lot of girls I give rides to love that torque as well. What you are trying to achieve can be done with the right size turbo, WG spring, electronic boost controller, and having your tuner keep the timing mellow before that curve. My car has that kick at 4500 that pulls your head back - PTuning turbo kit.
The Following 2 Users Say Thank You to rb6freak For This Useful Post: | RaineyStar (11-25-2014), Teseo (11-26-2014) |
11-25-2014, 11:49 PM | #13 |
Drives: violent
I think I have the most peak torque per peak hp than anyone on a stock engine. Might be wrong though. Gtx2867r. 393wtq 461whp.
11-25-2014, 11:52 PM | #14 | |
Similar Threads | ||||
P&l turbo kit question. | Suko | Forced Induction | 22 | 03-18-2014 07:24 PM |
Turbo Question regarding Headers | Admired | Forced Induction | 13 | 10-16-2013 08:27 AM |
Dumb turbo question | glorydays | Forced Induction | 5 | 10-15-2013 07:40 AM |
Turbo Question | Admired | Forced Induction | 4 | 07-29-2013 09:45 PM |
Delivery delay??? | FT86_Zero | AUSTRALIA | 4 | 06-15-2012 07:50 AM |
