Old 04-10-2014, 11:10 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Exclamation <^><^>^<^> E85 Mix Tracker for ALL the Southeast
Great idea from @chadstyle
I will make a Google Spreadsheet tonight we can all update with:
Station brand
Address
Date
Price per gallon
E content.
This will help us all identify the best and most consistent stations.
HERE IS THE SPREADSHEET
https://docs.google.com/spreadsheet/...FE&usp=sharing
Look at the tabs in the bottom of the document for your State. For an example on how to fill it, look at the FL tab that already has several entries
Also, thanks to @marcoaferrer for the nice E85 pump content calculator!!
http://e85pumpcalculator.com/
Please use it to help spread more information, the more the better
Alternatively and thanks to @s2d4 this one can also be used
http://www.intercepteft.com/calc.html
@jabbathewhat
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
lexusb3 (04-10-2014), lo_Opy (09-08-2014), TIE Pilot (04-10-2014)
Old 04-10-2014, 02:24 PM   #2
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Here is a little help (see attach) -as per http://www.e85vehicles.com/e85-stati...5-florida.html
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
The Following User Says Thank You to TIE Pilot For This Useful Post:
Sportsguy83 (04-10-2014)
Old 04-10-2014, 04:01 PM   #3
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Awesome! Thanks David!
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
Old 04-10-2014, 05:14 PM   #4
Sportsguy83
Drives: Limited BRZ
Spreadsheet is done.
Old 04-10-2014, 05:36 PM   #5
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
just added the stations Ive tried out.
marcoaferrer is offline   Reply With Quote
The Following User Says Thank You to marcoaferrer For This Useful Post:
Old 04-10-2014, 10:21 PM   #6
Sportsguy83
Drives: Limited BRZ
Thanks man appreciate it.
Old 04-13-2014, 07:23 PM   #7
chadstyle
chadstyle's Avatar
Just updated the sheet with a 5 gallon test from today. I think one more column that would be helpful would be gallons in tank/ethanol content in tank prior to pumping. I had 1 gallon in the tank of E65 and I pumped 5 Gallons and it rose to E74. I don't have a good equation to figure this out mathematically or I would input it into the spreadsheet too..maybe one of us can figure it out and add it in.
Sportsguy83 (04-14-2014)
Old 04-14-2014, 01:36 PM   #8
Sportsguy83
Drives: Limited BRZ
Would be nice if we could calculate, but for that we would need the exact amount of fuel left in the tank.
I added a column for E % before and after.
Old 04-14-2014, 01:43 PM   #9
chadstyle
chadstyle's Avatar
Agreed..I use Torque to gauge how much is left in the tank but who knows exactly how accurate it is.
Old 04-14-2014, 01:45 PM   #10
Sportsguy83
Drives: Limited BRZ
I do too!! But have tried running the tank to absolute lowest, literally having gallons of gas inside car for when I run out but end up still having half a gallon on the tank when I get tired of driving around pointlessly. Even after having run 5-10 miles with Torque telling me 0%
The Following User Says Thank You to Sportsguy83 For This Useful Post:
chadstyle (04-14-2014)
Old 04-14-2014, 01:46 PM   #11
marcoaferrer
E85 Mix Tracker: South FL
Well we can calculate that if you fill up the tank at each fill up. If we know when the tank is full it holds 13 gallons for instance and when we filled the tank the pump says it dispensed 9 gallons we would then know that 4 gallons of what is in the tank has our before e content
The Following 2 Users Say Thank You to marcoaferrer For This Useful Post:
chadstyle (04-14-2014), Sportsguy83 (04-14-2014)
Old 04-14-2014, 01:47 PM   #12
Sportsguy83
Drives: Limited BRZ
Extra effort, but very true.... I'll add columns for it so it can be calculated
Old 04-14-2014, 01:51 PM   #13
marcoaferrer
What does the manual say about the capacity of the fuel tank? I can put together a simple online calculator to make it easier I gues
Old 04-14-2014, 01:52 PM   #14
chadstyle
chadstyle's Avatar
That works for fill ups for sure... Not so much when testing for content like I was yesterday. Once I know what the few local stations are dispensing I will fill up each time after for the most accurate percentage.
PVT AJ Australia - Daily/Light Tracker Pvt AJ Member's Car Journals 11 06-23-2014 09:39 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
Mileage Tracker App for Android? FRyeS Scion FR-S / Toyota 86 GT86 General Forum 24 05-17-2013 04:03 PM
FR-S Inventory Tracker is Up Subie Scion FR-S / Toyota 86 GT86 General Forum 35 09-10-2012 10:29 PM
