Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-25-2016, 01:31 PM | #1 |
Drives: Fr-s
Differences between auto and manual engine
I'm looking for an engine and have come across a couple from automatic cars.
What is the difference between the auto and manual engine in terms of replacing the engine. From searching it seems like there might be an oil pan difference but I'd like to know exactly before I buy anything. Thanks.
07-25-2016, 03:30 PM | #2 |
Drives: Waiting on 2nd Gen!
I could be wrong so dont quote me on this, but there wouldnt be any differences up to the flywheel. Auto/manual are all in the transmission boxes.
07-25-2016, 03:32 PM | #3 |
Drives: 2013 Ultramarine FR-S
If you're on Facebook message Driveway Labs he recently swapped an auto engine into his manual trans car. Surprisingly There's quite a few differences.
07-25-2016, 04:28 PM | #4 |
...Just add nauseum
Drives: 2003 (AP1) S2000
The RH cylinder head has a few differences. Externally, there's a block-off plate on the MT model and a vacuum pump on the AT. Internally, there's an oil pipe assembly on the AT head that's blocked on the MT head.
Then there's your flywheel vs flexplate and torque converter.
Inline 4 is best 4
There are many ways to displace. -Spartarus |
The Following User Says Thank You to Spartarus For This Useful Post: | jeepmor (08-08-2022) |
07-25-2016, 04:55 PM | #5 | |
Drives: Fr-s
Ultimately if I had both engines sitting in front of me it shouldn't be too hard to swap the parts over that I need/don't need. Or are there some show stoppers?
The Following User Says Thank You to redlined600 For This Useful Post: | Leonardo (01-10-2018) |
07-25-2016, 10:52 PM | #6 | |
...Just add nauseum
Other than that, just throw away the vac. Pump and get a cam plate from racerx or any of the other people who make aftermarket block off plates. There are small differences in the brake booster hose but just keep the MT engine parts. Get new flywheel bolts. ARP. But yes, the crank is the same, the flange on the crank is the same. that's it. Oh and IMPORTANT. Your direct injectors have to match. Each one has a flow number printed on the injector body. Swap your old direct injectors over. And swap over your IDU. The computer box on the RH port injector cover.
Inline 4 is best 4
The Following 3 Users Say Thank You to Spartarus For This Useful Post: |
07-25-2016, 11:11 PM | #7 |
義理チョコ
Thank you very much, sir.
07-25-2016, 11:59 PM | #8 |
Drives: UltraMFrS
Drive it or it drives you 😆
Sent from my SM-P600 using Tapatalk |
07-26-2016, 12:11 PM | #9 | |
Drives: Fr-s
Thanks
07-26-2016, 02:26 PM | #10 |
...Just add nauseum
Match the IDU, per cylinder.
The flow number for each injector for each cylinder is programmed in the IDU. Your old ECU stays in the car (it's hidden in the passenger footwell) therefore your old IDU has to go on the new engine. In order for the IDU to operate the injectors correctly, the flow number in each cylinder has to match. The easiest way to ensure this is to swap them over, but you have to pull them anyway to check the number. When you buy a new engine you'll have 8 direct injectors total. So, pull the old ones, write down number and cylinder, and pull the new ones. If they match, you wasted your time, but there are [EDIT] 3 numbers. [/edit] So, you want the engine to start and run... It's only logical to pull them all and ensure you have the correct number in the correct cylinder on your new engine.
Inline 4 is best 4
There are many ways to displace. -Spartarus Last edited by Spartarus; 09-14-2017 at 09:31 PM. |
09-13-2017, 10:10 PM | #11 | |
@Spartarus, are you sure there's an internal one as well? Not planning on pulling the valve cover off unless I need to. |
09-13-2017, 10:40 PM | #12 | |
Drives: Toyota 86 GTS
Or just make sure you get the direct injector driver from the new engine.
It's bolted to the engine after all for this exact reason. Quote:
09-14-2017, 05:39 AM | #13 | |
Drives: FT86
Hmm, i have not pulled di injectors in this car but i was under the inpression that you need to have the same flow numbered di injectors all cylindes ie all number 1 or all 2 or all 3 numbered injectors. Not a mismatched set. If thats the case that all numbers are same in each cylinder then its possible the di computer doesnt need to know the flow numbers Ps looked in service manuals, says use DI injectors with same numbers. In direct injector ecu install remove no memtion of calibrating it or entering flow numbers. Ive swaped a few engine ecu for people no issues just flashed in the correct engine ecu calibration (you don't rearly need to change vin) no problems with DI ecu or fueling after changing engine ecu. But safest option would be to keep the di injectors and DI ecu as a set Last edited by steve99; 09-14-2017 at 08:37 AM. |
09-14-2017, 09:17 PM | #14 | |
...Just add nauseum
Inline 4 is best 4
There are many ways to displace. -Spartarus Last edited by Spartarus; 09-14-2017 at 09:32 PM. |
Similar Threads | ||||
BRZ Manual Or Auto? | JT2Swag | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 06-29-2016 03:05 PM |
2015 Engine differences | nikitopo | Engine, Exhaust, Transmission | 112 | 02-15-2016 06:27 PM |
Engine from Auto car into a manual car? | John Rambo | Engine, Exhaust, Transmission | 8 | 11-26-2015 04:54 PM |
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado | huma | BRZ First-Gen (2012+) -- General Topics | 15 | 06-14-2012 11:33 AM |
FR-S vs. BRZ Differences - Engine/Model Codes | Flipside909 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 05-07-2012 02:26 PM |
