Old 12-27-2015, 09:01 AM   #1
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
NA tuning 9000rpm Element Tuning
Hi guys
I need to know your idea about Element tuning 9000rpm NA kit :
http://elementtuning.com/competition...r-wrx-fa20dit/
did you see any dyno ? I like to see the torque curve in 7000-9000 rpm.
how much is the power gain?
before posting i looked at these posts :
http://www.ft86club.com/forums/showthread.php?t=63901
http://www.ft86club.com/forums/showthread.php?t=63723
@Element Tuning @celek
Toyota86.ir is offline   Reply With Quote
The Following 2 Users Say Thank You to Toyota86.ir For This Useful Post:
GhostOp86 (01-19-2017), GT86_PRAGUE (01-04-2016)
Old 12-27-2015, 12:58 PM   #2
acro
Drives: GT-86
Haven't seen would love to know though
acro is offline   Reply With Quote
Old 12-27-2015, 01:07 PM   #3
Toyota86.ir
It is so interesting to me if FA20 rev 9k without dropping torque like honda king high rev engines.
Celek build is interesting and i can not wait for that:
The Following User Says Thank You to Toyota86.ir For This Useful Post:
Old 12-27-2015, 03:46 PM   #4
FRS Justin
Drives: 2013 Asphalt FRS
I believe the 9k motor was a turbo motor. With stock cams 9k isn't going to do much.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Darryljr11 (12-27-2015)
Old 12-27-2015, 03:59 PM   #5
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Ask Phil at Element Tuning. Most of us running their motors are turbocharged. He responds quickly pn facebook.
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
The Following User Says Thank You to Darryljr11 For This Useful Post:
FRS Justin (12-27-2015)
Old 12-27-2015, 04:50 PM   #6
Teseo
Drives: frs
This with itb!!
Wonder how much will cost
Old 12-27-2015, 04:53 PM   #7
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Anyone have that video of the 9000 RPM turbo FA20?
Originally Posted by klearfade View Post
Is that gel in your hair?!
Originally Posted by HueyLooie View Post
Nah, homes. It's your dadda's hot goopey goop.
Old 12-27-2015, 04:58 PM   #8
FRS Justin
link to video on element site click on link above
710whp
Old 12-27-2015, 05:06 PM   #9
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
looks like the bigger valves are the key to their 9,000rpm builds that plus a bunch of undisclosed oil system mods
high revs are always nice though......
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
Old 12-28-2015, 09:04 AM   #10
Toyota86.ir
http://www.ft86club.com/forums/showthread.php?t=28723
http://www.ft86club.com/forums/showthread.php?p=390105
http://www.ft86club.com/forums/showthread.php?t=87289
http://www.ft86club.com/forums/showthread.php?p=2094860
http://www.ft86club.com/forums/showthread.php?p=1404202
http://www.ft86club.com/forums/showthread.php?t=54023
Originally Posted by arghx7 View Post
Stop comparing this engine to a Honda engine. It has a fixed valve lift. That requires big compromises. And ITB's will be very expensive and hard to control with electronic throttle.
Originally Posted by mad_sb View Post
7800 was a no brainer for 4B11t's.
This motor can rev, but some of the ecu tables will need to be re-scaled and it will need either cams or FI to make it worth reving deep.
Originally Posted by MattR View Post
I am also wanting to keep the engine N/A!
While definitely not the end-all factor, Rod/Stroke will also play into high-revving plans. Consider what seems to be a short rod length @ 130-131mm*. This will put your R/S ratio at 1.51-1.52. Not exactly the best starting point for a 9k engine.
A higher R/S ratio will lessen the side-load on your cylinder walls which is nice when wanting to rev to the moon
A few mentions of Honda engines. Hondas are already at an advantage for increased revs due to this factor. K20A engines were in the neighborhood of 1.62, iirc. B16A() screamers were at 1.74.
The mentioned S2000 F20C engines were at 1.82, but note that when Honda introduced the F22C for the S2000, they increased the stroke which lessened the R/S ratio to 1.65. No coincidence that they also decreased the redline.
One of many factors to consider when revving high. Looking forward to fellow all-motor builds!
*If someone knows the actual rod length measurement of the FA20 please educate me. I've been looking all over the damn place and can't seem to locate it.
:happy0180:
Originally Posted by serialk11r View Post
Oh dear, that's going to be hard. Do cheat with E85 to get you that extra 10% :P Moving the power peak from 7k to 8k with longer duration cams and a different intake manifold (full exhaust and the rest of the jazz too) can net perhaps 8/7*165?lb-ft/150lb-ft * 200hp=251.4hp, at the crank, with very little room to play with after 8k, and a rather peaky powerband before that. From the exhaust numbers and stuff we're seeing, I think 170lb-ft shouldn't be too hard to hit. But now you are looking to find that last 10-15% "drivetrain loss", that's going to be tough on pump gas! (let's admit it, 9000rpm with a 1.5 rod stroke ratio isn't so good for the cylinder bore or bearings) E85 should get you there though, if you can direct inject all of it. When done right the charge cooling effect on pre-combustion pressures alone should be worth 3% more power, or something like that (I did some calculation a long time ago).
@MattR, I think Crower or someone did post a picture of the EJ rods next to the FA rods, and after I asked what the rod lengths were they did post it. I just remember it was 130+/-1 mm.
Actually, this should be much easier than you think, given that we're willing to accept slight compromises in cam design. I believe one of the biggest reasons for the poor low end performance of big cams is that the big amount of overlap introduces large amounts of exhaust gas into the charge, completely ruining combustion efficiency. They say direct injection helps to increase the tolerance for internal EGR, but when you're idling and the vacuum is high, any overlap is going to mean a lot of exhaust sucked back in.
Larger cams however will lose volumetric efficiency at low rpm cruising conditions, which will decrease pumping losses and allow a cooler charge which further increases efficiency.
If you see some Toyota diagrams for VVT operation, you'll notice the range of cam movement allows the stock cam to be retarded to the point where it opens several degrees after TDC. So a performance cam that doesn't go too crazy on overlap can likely maintain near stock combustion quality characteristics at low loads. I mean this for both intake and exhaust. We lose a little bit of scavenging like this, but maintain driveability and increase fuel economy.
Oh, the heads might actually be a problem on this engine. Direct injection is picky about how the air flows into the cylinder, so you may completely ruin basically everything below 3000rpm or so if you port and polish. arghx7 said that the ports are probably "medium flow" in the sense that they introduce some tumble motion but not as much as typical DI engines thanks to the D4S setup.
Right now I am guessing the power is limited primarily by cams (and intake manifold), but once you start increasing the rev limit the heads might become the bottleneck, and there's pretty much nothing you can do at that point. The next FA20 supposedly has tumble generator valves and no port injection to address the issue with tumble flow and DI not working well at low engine speed, but that no doubt sacrifices some flow as well. How much we'll have to see.
My guess is Subaru will try to pursue high end power in the next FA by putting high flow ports with TGVs for low end combustion stability. I think the next FA20 might be something to anticipate, for this reason (it also has cooled EGR by the way, so there is no benefit to using D4S if they pull this off correctly). TGV and high flow, sounds like an oxymoron, but this is the only explanation, they could just use high tumble ports instead if they didn't care about flow.
Originally Posted by moto-mike View Post
Frankly I think past 200 on pump gas is definitely optimistic. We hit an honest 205 or so on E85 with Simmons' car last year (now Derek's) and I doubt you'll see too much higher. It is > 100hp/liter, to the wheels, which is damn impressive. While we could get more creative with some dyno work (such as arbitrary dynojet conversions on other dynos...) I think there's just a limit to what a 2.0l will do with stock compression--which is already a ludicrous (for an OEM) 12.5:1.
I doubt you'll see too much with cams; the stock setup is already pretty aggressive. If it weren't you wouldn't get the torque dip nor spin to nearly 8k without a massive tq drop. Thankfully the dual VVT keeps things at bay. I'd say no more than 10 hp from cams alone. Compression wise there isn't too much room if you plan on doing many miles.
ITBs sound nice, and make for great response. But the stock plenum ain't half bad for flow. Larger throttle body(ies) might make more HP but I've not seen anyone prove this just yet.
My gut tells me Subaru/Toyota are not making this one easy for the NA aftermarket. Though they certainly did for FI, given the punishment these motors are taking.
Where did you hear about ITBs being stock? That sounds like nonsense.
You can't say 86mm stroke is perfect for high rev, but it can be brought to 8000+ if everything else allows.
It appears we have a rod:stroke ratio of about 1.51-1.52, which is close to the smallest number you'll find on production engines. The actual difference between the piston motion at 1.51 and 1.7 isn't that big mathematically speaking, but OEMs refuse to let an engine with a short rod rev, something to think about.
CxG (03-17-2016), GT86_PRAGUE (01-04-2016)
Old 12-28-2015, 11:40 AM   #11
Toyota86.ir
It seems the Head is the limit.
i want to be sure before project.
i need to see dyno result
Old 12-31-2015, 10:52 AM   #12
celek
Resident Gear Head
celek's Avatar
Head is not the limiting factor it flows around 270CFM at .470 Lift in stock form the head flows fine and with minor work it can make 700+ WHP with a turbo. Bigger valves are a waste in an NA platform. The limiting factors are cams, springs retainers, rockers and the factory intake manifold.
celek is offline   Reply With Quote
The Following 7 Users Say Thank You to celek For This Useful Post:
Bykov (01-29-2020), cdrazic93 (12-31-2015), drewbot (01-04-2016), hmong337 (12-31-2015), new2subaru (12-31-2015), Spartarus (12-31-2015), Toyota86.ir (01-01-2016)
Old 12-31-2015, 11:30 AM   #13
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Plus the tune, timing, and header. Chase NA power if you want to burn money. A cheap turbo kit will produce more power everywhere, all for less money.
The Following User Says Thank You to EAGLE5 For This Useful Post:
CSG Mike (12-31-2015)
Old 12-31-2015, 05:06 PM   #14
CSG Mike
CSG Mike's Avatar
The FA20 is barely in B18C territory. Not terribly impressive given the engine is nearly 2 decades newer.
civicdrivr (09-09-2016), drewbot (01-04-2016)
Element Tuning's Time Attack Roll Cage. MA-Motorsports Review Element Tuning Tracking / Autocross / HPDE / Drifting 21 04-25-2017 12:51 PM
Element Tuning Raven Black FRS Track Build Element Tuning Member's Car Journals 130 04-04-2016 02:13 AM
Element tuning Hydra EMS mike the snake Software Tuning 29 03-29-2016 09:08 PM
Element Tuning FRS/BRZ Hydra EMS Stand-Alone Turbo 400 whp Injector Limited Element Tuning Engine, Exhaust, Transmission 40 12-17-2013 01:12 AM
Element Tuning FRS Battling the Corvettes at VIR Element Tuning FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-27-2013 03:02 PM
