11-27-2023, 02:47 PM | #1443 |
Drives: Ice Silver 2022 BRZ Limited
Installed a Nameless Performance strut tower brace.
11-29-2023, 09:55 AM | #1444 |
Drives: '15 GT86 & '22 GR86
Looks like your exhaust got left behind, no one told it it needed lifting, hanging low there my friend.
11-29-2023, 10:33 AM | #1445 | |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
There’s an exhaust joint right in front of the muffler, so at some point I might try to add a tapered shim there to tilt the muffler upwards to get the exhaust tips back up near where they’re supposed to be. The tricky part would actually be finding rubber hangers that are the right length(s). To make the shim work I think I’d need hangers for the rear 2 points that are just slightly longer than stock and ones at the front 2 points that are just slightly shorter than the longer ones I actually used. There just doesn’t appear to be that much choice in hanger length, nor of course do most vendors state the centre-centre hole spacing. TBH, it doesn’t bother me much and, since I haven’t decided if I will leave the lift kit on over the summer, I don’t want to do anything rash or permanent like getting the exhaust pipe bent or bending the wire hanger mount brackets.
Anything worth doing is worth doing twice...
11-29-2023, 01:54 PM | #1446 |
Drives: '22 BRZ
Ordered the Remark midpipe, pairing it with my JDL UEL, JDL Ultra Quiet front pipe, and STI muffler. Really curious how it's going to sound!
11-30-2023, 02:26 PM | #1447 | |
Drives: '23 BRZ Limited
But my commute is just walking from the bedroom to the other side of the house.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
11-30-2023, 02:47 PM | #1448 |
Drives: '22 BRZ
+44. Current commute is 3.2mi one way. Tried a slightly longer route today, but it ended up taking even less time due to lack of traffic lights. New location means an even shorter drive now. Barely enough for the car to warm up with winter here.
The Following User Says Thank You to eyeballs For This Useful Post: | vindiesel (11-30-2023) |
12-07-2023, 10:32 PM | #1449 |
Drives: 2013 FR-S, 2023 BRZ
i only put maybe 5000km on my first gen last year, mind you 4,999 of those were probably between 5k and 8k rpm
2013 Whiteout FRS 6MT with a JRSC RS Pulley @ 500ish WHP
2023 Ignition Red BRZ 6MT awaiting boost |
12-08-2023, 05:00 PM | #1450 |
Drives: 18 Brz (Sold) / 22 BRZ
Winter tires on
And they are squishy…removes a little bit of the fun.
12-11-2023, 12:56 PM | #1451 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Crash bolts installed and a proper alignment over the weekend. The car was a bit out of whack in stock form, so the difference between how it drove before/after is quite noticeable.
The Following User Says Thank You to Desertnate For This Useful Post: | Wally86 (12-12-2023) |
12-12-2023, 05:13 PM | #1452 |
Drives: 22 BRZ limited
Added the Verus master cylinder brace and bellhousing cover. The cover is NOT a direct bolt on like the last gen but it does fit the FA24 if you space the tube back there up so that the cover fits under the bracket. There is plenty of flex in the hose back there. And you need a bolt to go in the empty hole, also.
The Following 3 Users Say Thank You to dragoontwo For This Useful Post: |
12-13-2023, 12:11 PM | #1453 |
Spelling Impaired
How much better is the brake feel with the brace mounted?
12-13-2023, 12:25 PM | #1454 |
I was a bit apprehensive as to how it would feel, but it does add firmness to the pedal. For me the squishiness that is there was never noticed until I installed the brace. I'm not even talking about under hard braking. I noticed it right away while just driving around town and not getting into the brakes hard.
I don't think it will do any thing for the performance of the brakes as you can still lock them up without it. It just gives better and more consistent pedal feel as you have taken some flex out of the system.
12-14-2023, 09:11 AM | #1455 |
Drives: '22 BRZ
Went for my semi-annual oil change yestarday at the dealer. After coming home and looking at the paperwork I was surprised that it says they put 5w-30.
I thought the dealer always went strictly by the book. I think next oil change in the summer I will ask them to put in 5w-30 again see what they say |
12-14-2023, 07:25 PM | #1456 |
I thought my red brz looked good on first gen wheels but damn the blue pops, i like the wheel better on the new body than the old one lol
Similar Threads | ||||
WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 10:36 PM |
Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 02:51 PM |
just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 10:05 PM |
TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 01:16 AM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
