Old 08-19-2014, 03:32 PM   #29
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Just picked up that flex cap from the hardware store. I've been capped on the firewall since day 3. I wonder if this will make a difference
drewbot is offline   Reply With Quote
Old 08-19-2014, 04:24 PM   #30
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
@BirdTRD : I would be nervous about having anything that could come loose or chip and get sucked into the engine.
@drewbot : I think plugging the firewall hole and securing the sound tube so it's no longer connected to the firewall is enough. I just didn't want that ugly tube in my engine bay if it has no purpose, and hopefully it helps with airflow since the intake tube now has only one channel.
Old 08-19-2014, 04:30 PM   #31
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Yeah, I was a little worried about that too. RTV is pretty tough stuff though but I'm going to keep my eye on it. Probably go with a Perrin (or other) Silicone intake tube soon anyway.
BirdTRD is offline   Reply With Quote
Old 08-19-2014, 08:34 PM   #32
Gunman
Drives: 2019 Mazda Miata RF
Added the end I cut off, and the rubber cap is a lot more secure, and fits a lot tighter. Much more confidence inspiring.
Gunman is offline   Reply With Quote
Old 08-19-2014, 10:16 PM   #33
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Just put it on. haven't driven yet. I already had it capped in the driver's compartment anyway. Looking forward to less intake and more exhaust.
Old 08-19-2014, 10:51 PM   #34
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
I just picked up this marine plug and a hose clamp from Ace Hardware for a couple of bucks and used it to plug the hole. I guarantee it's not going anywhere.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
The Following User Says Thank You to jeffchap For This Useful Post:
F14Scott (10-14-2018)
Old 08-20-2014, 03:16 PM   #35
B-R-Z
B-R-Z's Avatar
I don't really like that bolt being there in the middle. May be fine at first but after years and years who knows.
Old 08-21-2014, 01:50 AM   #36
hahaman86
Drives: 2013 Scion FR-S 10 Series #2013
Originally Posted by GotBRZ1691 View Post
Just did this to my twin. Exhaust is loud enough so part of my plan to quite the cab up. Have sound matting in the rear half of the car. No road noise at all. Just need to do the front now.
Thanks for the how to guide!
also if you dont have a flat head screw driver or just prefer to use the socket wrench, an 8mm will work for the pipe clamps!
How did you get rid of the rest of the road noise? I was looking into quieting the cab mainly cuz I can't make a phone call while driving on the highway because of all the noise. What did you add and how much did it run you to eliminate the road noise? Cheers
hahaman86 is offline   Reply With Quote
Old 08-21-2014, 02:55 AM   #37
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Read the sound dampening thread. You can get away with just using dampening material, no real need for barriers and insulation. For the entire car, I'd recommend anywhere between 25-50sqft total, on doors (outer skin and inside), drive tunnel, rear quarters, floor and wheel well, roof, under treat seat, trunk floor, trunk lid.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 08-21-2014, 04:00 AM   #38
hahaman86
OK can I get a link to said thread? I've spent the last twenty minutes searching and can't find any useful information. I'd love to get some info on material and instructions would be so helpful too
Old 08-21-2014, 08:57 AM   #39
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I this product
http://www.homedepot.com/p/Protecto-...7206/100396171
It is a construction product, but the company also makes a sound matting material and there is not much difference between the two expect $$$
Home Depot has it for under $20 a roll and there are a few places with it a little bit cheaper if you look around.
Weighs in at 5lbs per roll. I used two rolls for the rear of my car, which was enough to do the trunk, under the rear seats, the wheel wells and arches, and do a second layer in most of the areas. Need to do front half next!
GotBRZ1691 is offline   Reply With Quote
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
hahaman86 (08-21-2014)
Old 08-21-2014, 10:37 AM   #40
aznatama
aznatama's Avatar
Not much difference in price from other sound dampening product. My 25sqft of 50mil matting with roller cost under 25 shipped. Cheaper per sqft if you get more. Plus, the sound dampening mat is thicker and heavier, much more than 5lbs, making this actually much more expensive.
What is this stuff made of?
'14 BRZ LTD MT DGM
Old 08-21-2014, 10:41 AM   #41
aznatama
aznatama's Avatar
http://bit.ly/1BG3pXr
=D
Also, I would just use a lot more matting. You can skip the mlv and ccf. Key areas are panels that sound hollow when you knock on then. That's vibration. The only place that you may want to add ccf is maybe headliner, door cards, and rear quarter.
'14 BRZ LTD MT DGM
The Following User Says Thank You to aznatama For This Useful Post:
Old 08-21-2014, 05:51 PM   #42
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Do yourself a huge favor. Visit www.sounddeadenershowdown.com and educate yourself on the various elements that produce vehicle cabin noise and the products designed to mitigate each type. I think you'll find that there is not 1 magic bullet but rather a multi-layered (literally) approach to dealing with NVH (noise, vibration and harshness). Every Sound deadening company out there has their own version of the products you'll read about, just called something different.
The Following User Says Thank You to BirdTRD For This Useful Post:
hahaman86 (08-22-2014)
Sound Generator to keep or not to keep? FRS86edition#3 Scion FR-S / Toyota 86 GT86 General Forum 73 11-24-2013 01:26 AM
Sound generator delete for $1.06 PineappleFriedRice Engine, Exhaust, Transmission 13 11-10-2013 12:28 PM
Sound Generator Tube Delete Anthony Engine, Exhaust, Transmission 8 09-01-2013 04:25 AM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 11:31 AM
