Software Tuning Discuss all software tuning topics. |
11-05-2015, 04:21 AM | #15 | |
Drives: FT86
If you cannot read the rom from ecu then that may also indicate its tuned as some tuning systems ecutek and brzedit disable read. You will also need a device to read ecu , or access to someone who has one Some tunes have distinct features some do not. |
11-05-2015, 07:02 AM | #16 |
Nope not a good indicator. Mine idles at 600 and is solid as a rock with no tune.
11-05-2015, 07:42 AM | #17 |
Which is a very real possibility, especially given the shit I see owners post on Facebook....
11-05-2015, 09:32 AM | #18 |
Drives: 2015 Frs
Hey jsimmon7777 I'm in Fairfield. I just tried to see if I have ecutek and nothing happens with the cruise control. 1st gear Rev and let's me go past 6k so pretty solid evidence I don't have a tune. Which makes me happy in the sense I can get more power
11-05-2015, 11:04 AM | #19 |
Drives: 10 Series #974 6m/t
Even if the torque dip was gone I would still feel it if my other car was an E55 amg.
11-05-2015, 11:10 AM | #20 |
Drives: 2015 Frs
Yea she's kinda slow too |
The Following User Says Thank You to Captainstabalot For This Useful Post: | NyC Zn6 (11-05-2015) |
11-05-2015, 11:20 AM | #21 |
Dismember
Drives: 2013 Red Scion FR-S
Well, you're not going to gain much from a tune unless you get a header and/or run e85. Also, to save you some searching:
+35 9" wide wheels on stock suspension +45 with camber and coilovers yes, RPF1 are still the standard the car actually understeers at the limit stock until you put down the accelerator yes, you need an oil cooler to go to the track yes, you need track brake pads front and rear. Most people go project mu. I am one of the few who like PFC 08. yes, you need to replace the brake fluid with something higher temp. I like ATE. No, those coilovers are crap, and that anti-rollbar probably is too Yes, you want front crash or camber bolts - you'll get about -2 degrees, which is enough for most people You can adjust the clutch downwards. You can remove the spring. I'll be replacing the cylinder with a smaller one. SBD makes the cheap turbo. Full Blown makes the drag turbo. PTuning makes the track turbo. Jackson makes the track supercharger. OFT does pretty much everything that EcuTek does and has a screen for real-time data. It's also not beloved by many tuners who want to lock up their tunes. The thread about helping the guy find yoga pants for his girlfriend is really just an excuse to post pictures of scantily clad women. There, now you can leave the forum now. Though you might want to check out the yoga pants thread before you leave.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post: |
11-05-2015, 11:27 AM | #22 |
Drives: 2015 Frs
Lol well thanks for the information overload. I don't really plan on tracking this car but wouldn't mind having her ready to do so. This is how she sits now, I think I'll stay around the forum for awhile. T
11-05-2015, 12:25 PM | #23 |
11-05-2015, 04:36 PM | #24 | |
I Love custom Turbo kits
Drives: Limited BRZ
OFT is not a proper way of tuning if going FI and/or E85. Custom Ecutek maps are required to properly tune an FI 86 and flexfuel for E85.
11-05-2015, 04:37 PM | #25 |
So I can't buy a turbo kit and get it tuned for 93 pump only with OFT ?
11-05-2015, 04:50 PM | #26 | |
Drives: Limited BRZ
I am talking about doing things right, having the proper safeguards in place etc.... With Ecutek you get electronic boost control with CC stalk, you get overboost protection with several parameters, you can input a real wideband into the ECU to be able to properly tune the A/F ratio of the car, different timing/gas maps for different situations, Speed Density for when your MAF is no longer able to provide you a window for tuning because it's maxxed out, etc.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | NyC Zn6 (11-05-2015) |
11-05-2015, 04:50 PM | #27 | ||
Drives: FT86
Other tuners are reluctant to use opensource as their work can be copyed. you will find that the oft and sdb kits are limited to about 10psi boost as after that you start to need some of the fancy add on features of ecutek software like boost cut, flex fuel, hybrid speed density ect. However see here ztan has already implemented overboost cut and speed density patches for opensource. Shiv/OFT is now using the overboost cut patch on their OFT 350 turbo kit. In the not too distant future opensource flex fuel may be done and the gap between opensource and ecutek will be much less. Their is already a guy in australia "throttle happy tuning" who has flex fuel running without ecutek, its not open source though he uses brzedit and has written his own flex fuel code for 86/brz although you will still run into the problem of many tuners preferring to use ecutek due locking of tunes and that they dont have to manually patch roms ect, ecutek software does it for them. http://www.ft86club.com/forums/showthread.php?t=94751 |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | NyC Zn6 (11-05-2015), Sportsguy83 (11-05-2015) |
11-05-2015, 04:52 PM | #28 |
The biggest hinderance to FI with OFT is that when you go FI you generally want a proper dyno tune and those guys won't touch OFT if it doesn't let them lock the tune.
Similar Threads | ||||
How can you trust a tune? (tune noob) | Benschneider06 | Software Tuning | 20 | 05-21-2015 11:03 AM |
Drift Office Tune vs Visconti Tune | mechaghost | Engine, Exhaust, Transmission | 109 | 07-03-2014 12:57 AM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
difference between vortech tune and perrin tune? | Frs32907 | Forced Induction | 7 | 12-05-2013 02:49 PM |
Dynotronics and their E-Tune/ OTA tune. | Ricepuddin | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 12-24-2012 09:53 AM |
