Old 06-20-2012, 12:00 AM   #1
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
DIY BRZ / FR-S Oil Change
Albino Rhinos first Oil Change
Tools needed: 14mm socket or wrench, ramps or jack and stands, oil drain bucket, small funnel, fresh oil, and oil filter. Gloves and shop rags are very nice but not required.
Time Required: I would give yourself about 30 minutes to complete the oil change.
Difficulty: One of the easiest oil changes I have done.
First I like to make sure the car is somewhat warm but not hot. You will want to drive your car up onto the ramps, or jack the front of your car up with a jack and make sure to secure it with jack stands. Pop the hood and locate the oil filter and oil filler cap on the front driver side(left side) of the engine bay. Take off the oil filler cap and put it aside in a safe location.
Next go under the car, and you should see the large metal under plate, and you will notice a large access hole, this is where you will be able to access the oil drain plug. Take your 14mm wrench and loosen the oil drain plug, and make sure your oil drain bucket is close at hand so you can get it directly under the oil flow path as you are removing the oil drain plug.
As oil is draining, you can start to remove the oil filter on the top of the engine. With the filter being on the top of the engine, you should not have to worry about the filter spilling oil as you remove it, should be a very clean removal. Once the filter is off, I like to clean the mating surface of the engine and apply a light film of oil to the new oil filter o-ring to ensure a leak free seal on the new filter.
Install the new filter and tighten down to manufacturer or oil filter specs. Once you have let the oil drain for a sufficient time, you can screw the oil drain plug back in the oil pan and torque to factory specs.
Last step is to fill the engine with oil, we used a small filter which will help keep any oil off the engine. Subaru states the oil capacity is 5.8 quarts, but ours did not take quite that much, so I would fill it to around 5 quarts and check the oil level, and top off if needed.
Put the oil cap back on, start the engine and make sure the oil light turns off. Get out of the car and check for any leaks. Once you have confirmed there are no leaks, double check everything, and enjoy your fresh oil! Now go for a drive!!!
We decided to use the Dimple Magnetic Drain Plug on this oil change, the part number is M16X1.5X12 which is also the dimensions of the oil drain plug. The new Dimple plug will use a 15mm head, so if you do go this route, make sure to have a 15mm wrench handy as well. We also used the Prova Sports Oil filter, part number 10000SP0010
Like us on Facebook!
RallySportDirect Blog
RallySport Direct is offline   Reply With Quote
The Following 63 Users Say Thank You to RallySport Direct For This Useful Post:
allanjeffreyy (06-29-2015), amram (03-25-2014), Anthonytpt (03-20-2013), BabaYaga (10-11-2014), BAE (01-02-2013), baldolera (06-20-2012), barabia (08-15-2013), BlUURZ (05-13-2014), Bonburner (03-13-2015), Brzer (06-21-2012), br_z1Lch (05-22-2014), Busybee (06-25-2022), CamryDS (04-22-2013), chanomatik (04-24-2013), charged86 (06-27-2013), ChilOut (07-25-2014), chrisp1992 (02-03-2014), civicdrivr (06-20-2012), Clembo (03-09-2013), Dang Lad (06-23-2012), DrDuquette (08-04-2013), Dreyup (05-17-2016), eurominican (03-29-2013), evil_1998 (12-27-2012), F1point4 (06-26-2012), Fish (06-20-2012), FRSapex (09-13-2013), FRSPirate (06-20-2012), ft86Fan (07-15-2012), GMT (10-01-2012), hmong337 (11-17-2013), HunterGreene (08-28-2013), IgnitionGundam (04-06-2015), Jayde (06-20-2012), Jayp (06-20-2012), jcw99 (11-14-2014), Keenercarguy (08-08-2016), kevinnivek8877 (06-25-2012), kwood9000 (06-20-2012), ManOfStiehl (06-20-2012), Marrk (06-20-2012), mfbmike (09-11-2013), MRZ415 (07-22-2012), Myv (03-03-2013), Neziah (06-26-2012), normancw (04-20-2014), nzer (12-01-2012), oxygen (04-04-2013), SILENT (05-13-2013), SkAsphalt (09-13-2013), Smudgeous (06-30-2012), soros151 (11-20-2012), Stonehorsw (05-18-2021), Tristor (08-31-2018), turtlefeeder (07-26-2017), WeAreLasers (10-15-2015), weederr33 (04-05-2019), WithNolock (06-20-2012), yajin (06-21-2012), YMAA (03-25-2015), ZeHeadBanger (12-20-2013), zex (06-20-2012), zoomzoomers (03-04-2013)
Old 06-20-2012, 12:58 AM   #2
baldolera
baldolera's Avatar
Drives: None Yet
Nice. Don't forget to mention that you should lube up the oil filter gasket with a little oil! Now, I just hope someone posts a DIY on a Fumoto Drain Valve and a review on it as well.
Originally Posted by LexusFman View Post
Nope because I have had Keichii Tsuchiya skills from the womb and I'm a beast at Gran Turismo. Reall cars can't be all different.
baldolera is offline   Reply With Quote
The Following User Says Thank You to baldolera For This Useful Post:
636 (05-29-2015)
Old 06-20-2012, 01:29 AM   #3
RallySport Direct
haha nice catch! We specifically took a picture of it, but did not mention in the writeup. Got that fixed. Thanks again!
Rick
The Following User Says Thank You to RallySport Direct For This Useful Post:
Pho20 (10-15-2017)
Old 06-20-2012, 02:01 AM   #4
baldolera
baldolera's Avatar
Drives: None Yet
Rick
Haha no problem, I was wondering why the pic was the but there were no instructions for it.
Old 06-20-2012, 02:08 AM   #5
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 06-20-2012, 07:28 AM   #6
lancie
lancie's Avatar
Drives: brz wrb
oil stock is 0-20w ?
lancie is offline   Reply With Quote
Old 06-20-2012, 10:19 AM   #7
Jayde
Jayde's Avatar
Yes.
Jayde is offline   Reply With Quote
The Following User Says Thank You to Jayde For This Useful Post:
lancie (06-20-2012)
Old 06-20-2012, 10:34 AM   #8
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Rick
Arg! You beat me to this. I was going to change my oil today.
Great writeup though. Do you know the torque specs on the plug and filter offhand?
Hawaiian is offline   Reply With Quote
Old 06-20-2012, 10:39 AM   #9
Ben_G
Drives: Blue BRZ
Which filter are you using? I looks like it's much smaller than the original.....
Ben_G is offline   Reply With Quote
Old 06-20-2012, 10:54 AM   #10
Marrk
Drives: Honda Fit
Good write-up. Clear and thorough.
It might be interesting if you would comment, here or elsewhere, on your reasons for going with the Prova Sports Oil filter. If it supersedes the quality of the OEM filter, that is one thing. But, since it looks noticeably smaller, as has been noted, it raises concerns.
Thanks.
Marrk is offline   Reply With Quote
Old 06-20-2012, 11:11 AM   #11
RallySport Direct
The reason of going with the Prova filter is the simple fact of how high quality they are.
Subaru USA and Subaru Japan have different oil filters, the OEM filters that come on the cars are the super nice Subaru Japan filter. When you go to the dealer Subaru North America sells the cheap Fram made oil filters which are not nearly as nice of quality.
This was something that Subaru did a few years ago (and Im sure most North American dealers such as Toyota, Honda, ect to cut cost). It has been heavily gone over in the Subaru community, and the easy way to tell is the OEM subaru filters in NA are Blue, where the Japanese made are Black.
The filters that come on the cars look identical to the 2002-2005 WRX oil filters. If you look at the speed hunters coverage of the BRZ STi concept, that car has the smaller STi 2004+ oil filter. The smaller filters where used on those cars just for clearance reasons as the older WRX filters wouldnt fit, however they both performed just as well even with the size difference.
Kirill
RallySportDirect.com
The Following 5 Users Say Thank You to RallySport Direct For This Useful Post:
amram (03-25-2014), FT86Z (12-07-2015), Keenercarguy (08-08-2016), Mr. (03-15-2013), Texas BRZ (10-24-2014)
Old 06-20-2012, 11:15 AM   #12
RallySport Direct
As per SOA FSM the torque spec on the filter is 10.3ft-lb, and 28.9 ft-lb for the drain plug
Kirill
The Following 9 Users Say Thank You to RallySport Direct For This Useful Post:
alucard7755 (02-29-2016), amram (03-25-2014), BRZGM3 (08-28-2015), Keenercarguy (08-08-2016), p1l0t (06-27-2016), Pete (07-06-2013), scionfrs2014 (05-21-2014), Slick (03-03-2015), Texas BRZ (10-24-2014)
Old 06-20-2012, 11:57 AM   #13
Marrk
Drives: Honda Fit
Thanks, Kirill.
My experience with, for example, Honda is that, for the North American market, they use two oil filter suppliers, both are good, but the Canadian one is judged to be better. Fram I have never liked, although many swear by them.
I'll have to look further into the Prova filter. What you are saying makes sense, but that smaller size still makes me want to be sure. I mean, when it's installed, it doesn't look very pretty, does it? Not that it has to, but....
BTW, since you appear to be a retailer/distributor of the Prova, did you want to make a "full disclosure" on that point?
Old 06-20-2012, 12:15 PM   #14
RallySport Direct
Glad I was able to clear that up for you
Yes we are a Prova Retailer, however any high quality filter will work. Just make sure its something at least as good as OEM if not better. K&N, PowerEnterprise, and Prova we have found to work very well and are what we used on personal cars and offer to customers. If we dont find it good enough to run on our own cars, we dont offer it to our customers
Typically for oil filters you want to stay away from the budget units as they dont have the same features such as a high quality units such as: bypass valve, internal construction to keep the filters shape, and the density of the filter to be correct for proper flow but yet allow for proper cleaning.
Kirill
The Following 2 Users Say Thank You to RallySport Direct For This Useful Post:
Marrk (06-20-2012), NeedsmoreCowbell (06-22-2012)
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Color Change Dark_Angle Mid-Atlantic 10 05-30-2012 02:00 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 77 04-16-2012 10:12 AM
I was able to change my pre-order. nkrein22 BRZ First-Gen (2012+) -- General Topics 23 04-10-2012 04:16 PM
Can SOA change my preorder? Zaneman BRZ First-Gen (2012+) -- General Topics 8 04-08-2012 02:06 PM
