Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-29-2019, 11:50 PM | #15 |
TOB?
2013 Series 10 FRS #553
08-06-2019, 01:03 AM | #16 |
義理チョコ
You do not fuck around. Props.
08-06-2019, 06:11 AM | #17 |
Drives: 2014 MY15 86 GTS
Supposably from factory the 2014+ got larger oil galleries from the factory.
To prevent oil starvation Is this true? |
08-07-2019, 01:02 PM | #18 |
Drives: 2013 BRZ Sport-Tech
08-17-2019, 07:52 PM | #19 |
義理チョコ
What's going on between these two points?
08-17-2019, 08:28 PM | #20 |
Drives: Q5 + BRZ + M796
It does look melted like the gears spun against each other, where just the tips were rubbing
08-17-2019, 08:30 PM | #21 |
義理チョコ
08-17-2019, 08:32 PM | #22 |
義理チョコ
08-18-2019, 12:13 AM | #23 |
義理チョコ
lol
Fuck yeah.
08-19-2019, 09:40 PM | #24 |
What will you use as your FD? I just looked up the ratios on the 350z and unless you change the FD your going to have some crazy short gears, especially with the power you’re making.
08-20-2019, 03:56 AM | #25 | |
Yeah I already looked up those numbers and at a glance it looked like it would have a larger impact. I just threw the numbers into a calculator and the top speeds per gear aren’t as far off as I thought they would be. Even stock seems a little short for big power though. Seems like somewhere down the road it wouldn’t hurt to go with a lower FD. |
09-10-2019, 03:53 PM | #26 |
Drives: 13 White MT FR-S
where in NC are you? I need you to come build my motor lol
09-10-2019, 10:41 PM | #27 |
I'm sure.
09-10-2019, 11:36 PM | #28 |
Is this happening with 17+ blocks?
Cheers
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
Similar Threads | ||||
Engine failure - Spun rod bearing TWICE | dinoniel | Issues | Warranty | Recalls / TSB | 38 | 11-07-2016 01:17 PM |
rod bearing failure. New long block question. | USMCgetsome | Engine, Exhaust, Transmission | 13 | 06-12-2016 04:35 PM |
Engine Failure (#4 Rod Bearing + Short Block) | eriktherod | Issues | Warranty | Recalls / TSB | 215 | 10-30-2015 12:24 AM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
Engine Failure (Bearing Rod 2) | Incursion | Issues | Warranty | Recalls / TSB | 59 | 11-27-2014 02:17 PM |
