08-22-2019, 06:58 AM | #59767 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
08-22-2019, 08:30 AM | #59768 |
Frozen yogurt bar
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Sapphireho (08-22-2019), Ultramaroon (08-22-2019) |
08-22-2019, 10:07 AM | #59769 | |
The Dictater
Drives: '13 Red Scion FRS
The Following User Says Thank You to Spuds For This Useful Post: | korhun (08-22-2019) |
08-22-2019, 10:09 AM | #59770 |
The Dictater
The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (08-22-2019) |
08-22-2019, 10:13 AM | #59771 |
Dismember
Drives: 2013 Red Scion FR-S
Sadly, none are out. It just hate having the truck sit there barely used and depreciating.
08-22-2019, 10:33 AM | #59772 | |
Country Boy 4 Life
I LIKE TIRES! |
The Following 6 Users Say Thank You to Leonardo For This Useful Post: | Dadhawk (08-22-2019), korhun (08-22-2019), Sapphireho (08-22-2019), soundman98 (08-22-2019), Spuds (08-22-2019), Tcoat (08-22-2019) |
08-22-2019, 10:59 AM | #59773 | |
Drives: 2014 BRZ Limited
08-22-2019, 11:10 AM | #59774 |
Database error
08-22-2019, 11:15 AM | #59775 |
Shitpost Generator v8.6
Spent the better part of last evening helping my dad attempt to bring his old R75/7 back to life. Its been sitting for the better part of 3 years, and as a result has some problems. We did an oil change and got rid of the old, bad gas and put new gas + a bit of seafoam in it. It starts up and idles on choke, but tends to die when the choke is off and doesn't seem to want to rev above 4K. Feels like the slides in the carbs just wont rise or the main jet is clogged... I'm thinking there has to be some kind of varnish or gunk in the carbs from sitting for so long. I'm hoping the seafoam we put in it will help un-gunk them a bit but who knows how much it will really help. And I don't know enough (really anything...) about 40 year old BMWs to really be much more than a pair of hands so the prospect of a full carb rebuild scares me lol.
08-22-2019, 11:23 AM | #59776 | |
Just go out and get yourself a carb rebuild kit. All the seals and gaskets will be all dried out and possibly even falling apart. There will be nothing you can do until you rebuild it. It is a simple rebuild though.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (08-22-2019), Ultramaroon (08-22-2019) |
08-22-2019, 11:32 AM | #59777 |
Drives: Crapcan
If it dies off throttle at idle it is likely an intermediate circuit like the pilot, or an air/fuel screw bypass.
Do the throttle cables go to a butterfly or to the slides? If they go to a butterfly the carbs are vacuum operated and rise with engine RPM, they pull vacuum from the intake which pulls them up. If they are vacuum operated pull the tops off and check the diaphragms to make sure there are no tears or holes. |
08-22-2019, 11:38 AM | #59778 | |
Basically, the only thing I really know regarding wrenching on this thing is that "nicht überfüllen" probably means "do not overfill". |
08-22-2019, 11:40 AM | #59779 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (08-22-2019) |
08-22-2019, 11:41 AM | #59780 |
Carburetor is a carburetor is a carburetor be it a car, boat, bike or lawnmower.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
