07-07-2016, 06:12 PM | #1332 | |
Iam is 1 no fbkc you did not log flkc but looking at the KC Learned looks fine the only issue is its running quite rich 11.2 and while thats safe it will cost you some power , you will need to do some maf scaling to correct it, the bogging at low rpm is likely due to load limits |
07-07-2016, 06:29 PM | #1333 | |
Drives: Toyota 86 GTS
All the openflash tunes are safe in the short term due to the factory ecu logic, they just may not live up to their potential is all.
With mine all you need to max them out is select between 2 maf scales. If you're on E85, flash the US.Rich scale, drive 150km after flashing or filling up, then log WOT 3rd gear from 2500-7500. If it's richer than about 11.8 AFR @ 6800 then switch to the US.Lean scale. Just don't base decisions on data logged straight after flashing on E75 or so, because fuel trims won't have settled correctly. The process is the same on 98 except that you can log after filling up, provided you haven't switched from E85 recently. Quote:
07-07-2016, 08:08 PM | #1334 | |
Drives: FR-S Whiteout
http://datazap.me/u/solidone/z6-kc1h...&data=1-8-9-11 As knock free as this log looks I'm pretty sure if I punched the throttle with the AC on I would see some knock correction where I typically wouldn't or more knock correction where it is minor with AC turned off.
Intent > Content
cowardice is the mother of cruelty. |
07-07-2016, 08:33 PM | #1335 | |
Drives: GT86
On WOT the AC automatically shuts off. Anyways, i'm gonna stick with wayno's v107 98 stg1. I think i ruined my tune with pulling timing over the couple of months. It doenst feel peppy anymore between 4000 and 6000 when WOT :/ A friend of mine has OTS stg1 91 from vishnu. He has absolute no knock, never, even if it is hot. Overall i am running about 2,5degree less advance. And this is driving me nuts.. And he is driving with 98 octane i never heard of. |
07-07-2016, 10:28 PM | #1336 | |
Why not try the fuel your friend is using? Maybe it's just better fuel he is using?
Intent > Content
07-08-2016, 11:09 AM | #1337 |
Drives: GT86
Wow..
Wayno's v107.2 Stg1 solved all my problems. Zero knock on WOT, unbelievable... http://datazap.me/u/rezi/0807wot?log=0&data=1-12 |
The Following User Says Thank You to Rezi For This Useful Post: | solidONE (07-08-2016) |
07-08-2016, 06:49 PM | #1338 |
Drives: 2022 crystal white BRZ
Hey guys, ended up picking up an OFT and flashed the stg2 EL E85 map onto the car.
I'm not getting anything at all for my IAM, and the FLKC is consistently -5. From the other logs I've seen that means its pulling loads of timing, right? It seems really odd that it never budges from 0 at anytime, so maybe the ECU didn't take the flash, although it seems to run very well. The CalID for my car is ZA1JF00C, iirc. http://datazap.me/u/cz6t/log-1468013...a=1-7-12-13-14 |
07-08-2016, 08:22 PM | #1339 | |
from what i can see it looks ok using kc leanred. logging for flkc iam is not working correctly |
07-08-2016, 09:20 PM | #1340 |
I've sent them an email, so I'll just have to wait and see what's going on. It's a releif to know it doesn't look realy terrible, though. I'll take it easy for a few days and see if it starts developing knock or not, and hopefully the ltft will be nice.
07-08-2016, 09:26 PM | #1341 | |
afr looks ok and ltft is ok for e85 |
07-09-2016, 02:43 AM | #1342 |
Drives: 2015 86 GTS
Hi guys,
Stock D00G car running Wayno's Stg 1 98 v107.2 tune. Fuel - Caltex Vortex 98 2 Logs attached: http://datazap.me/u/fibble/oft-stage...o?log=0&data=1 Note: ignore FLKC due to problems with OFT. Still seems to be some knock and trims look a little out with AFR a little rich. Thoughts on whether there's still work to be done (timing and fuelling) or acceptable for Stg 1 tune on my car? Wayno - this is with AVCS in v107 (not experimental). Thx KCA Max A attached below: Last edited by fibble; 07-09-2016 at 02:54 AM. |
07-09-2016, 03:14 AM | #1343 | |
Looks fine to me. It may get leaner. Do at least 150km before you judge fuel trims.
The Following User Says Thank You to Wayno For This Useful Post: | fibble (07-09-2016) |
07-09-2016, 03:19 AM | #1344 |
Drives: 2015 86 GTS
No probs - will do the extra ks.
Also noted experimental Stg 1 AVCS is significantly more conservative on both Intake and Exhaust. Something you found or suspect? |
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
