05-11-2018, 11:47 AM | #113 | |
Drives: 2017 WR BLUE BRZ
I changed the diff for a few reasons. The original 4.30 gear would have been too low a gear for the engine and tire size. I want first, second and third gear to actually be useful. 3.55 should put me right where I want to be. The axles for sure would have needed an upgrade as well as the wheel hubs And I have broken a few differentials in other cars, being stuck somewhere with a broken diff sucks...hoping I bought some peace of mind. So the full blown kit addressed all of thos reasons for me. Gearing and strength in a bolt in kit...we’ll see how it holds up...it better! |
The Following User Says Thank You to ILLSMOQ For This Useful Post: | Alltezza (05-11-2018) |
05-12-2018, 09:25 PM | #114 | |
pessimistic skeptic
Is this also a limited slip Torsen differential?
05-13-2018, 11:18 AM | #115 |
When you order the kit, you can select what ever kind of differential unit you want. I chose a Detroit TrueTrac, which is a Torsen style similar to the factory unit (parallel axis gears) It’s a more simple design without any clutches or other components to wear out, also very strong. I’ve used these in the past and I like how they feel.
There are a few different types of torsen style differentials. https://torsen.com/how-it-works/ Last edited by ILLSMOQ; 05-13-2018 at 11:34 AM. |
The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post: | mrg666 (05-13-2018), Sportsguy83 (05-15-2018) |
05-14-2018, 11:29 PM | #116 |
Exhaust came back from Swaintech today. I’ll install l it tomorrow
05-17-2018, 11:09 PM | #117 |
Got the exhaust back and installed
It’s just about ready to start. Few more things to do still. |
05-21-2018, 10:42 PM | #118 |
Couple LS swaps running today, Awesome!
Pure Automotive is at the top of the game with their motec plug and play kit. The car is running, I can’t wait to see what can be done from here with this hardware/software. Vorshlags supporting LS swap hardware is awesome as well. Really happy with how this build has turned out so far. After some minor tweaking Needs a full on tune...More to come. |
The Following 12 Users Say Thank You to ILLSMOQ For This Useful Post: | BirgeyT1 (05-22-2018), Draco_PR23 (06-05-2018), DustinS (05-22-2018), gtpvette (05-22-2018), Joesurf79 (05-22-2018), KDad2 (05-23-2018), Lonewolf (05-24-2018), mkivsoopra (05-22-2018), mrg666 (05-22-2018), Sportsguy83 (05-22-2018), tehShirt (05-22-2018), yberther (05-22-2018) |
05-26-2018, 10:41 PM | #119 |
Hey @ILLSMOQ how much of the OEM wire harness does the pure auto harness replace? Do you keep the loom that goes through the firewall on the driver side behind brake booster? Thanks!
05-27-2018, 10:01 AM | #120 | |
What ever is behind the brake booster wasn’t affected. I didn’t have to do anything with the brake booster. I ran the wire loom through the same hole the factory loom passes through behind the battery. The pure harness plugs into the three plugs for the factory ecu. Then gets run out to the engine compartment and plugs into all the LS components. And then power from the batt and ground. I actually used the factory alternator, power and ground cables too. Revers lights still gets connected to the original Brz reverse lights wiring., I cut the wiring and connector off the original Brz reverse lights switch and soldered in the t56 switch. The harness didn’t provide a solution for the reverse locknout solinoid, so I picked up a reverse lock out module from American Powertrain so I can shift to reverse easily. And mounted it under the center council. http://americanpowertrain.com/i-2388...e-6-speed.html |
The Following User Says Thank You to ILLSMOQ For This Useful Post: | 1Cor10:23 (05-27-2018) |
05-27-2018, 12:17 PM | #121 | |
Drives: 2015 FRS - FFR GTM
Super clean,,, really nice work! I'm just started looking for the reverse lighting,, where did you find it???
2015 FR-S - One Day I'll Finish The Swap |
05-28-2018, 10:48 AM | #122 |
06-04-2018, 09:19 PM | #123 |
Still got a few things to wrap up on it but it’s finishing up nicely.
Another idle vid. |
06-05-2018, 11:12 AM | #124 |
Drives: 14 BSP Edelbrock BRZ
That is just the sexiest engine bay I have ever seen.
The Following 4 Users Say Thank You to toast For This Useful Post: |
06-05-2018, 07:53 PM | #125 |
Drives: '14 fr-s \\ 6mt \\ white
06-06-2018, 12:05 AM | #126 |
Believe me I want to! But I’m not gonna jack my brand new engine by running it on a bad tune..Getting it tuned on the 19th...until then it sits and I can tie up all the little loose ends. I’ve waited a long time to get it to this point...couple more weeks isn’t a big deal lol
The Following User Says Thank You to ILLSMOQ For This Useful Post: | Zer0 (06-06-2018) |
Similar Threads | ||||
Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 11:10 AM |
Pure Automotive's 2017 Race and Show Schedule | Pure Automotive | Mid-Atlantic | 4 | 01-21-2017 12:07 PM |
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 06:11 PM |
Pure automotive pre meet | KslayFRZ | Mid-Atlantic | 0 | 07-19-2013 11:32 AM |
Anybody want to help me pick up my car at Pure Automotive? | TyperRspec789 | Mid-Atlantic | 4 | 01-31-2013 02:07 PM |
