#85 | |
Yes the two values you highlighted are taken from maps then you add the FLKC which is a negative value in this case . then if you IAM was less than 1 you would have to use the full equation. |
The Following User Says Thank You to steve99 For This Useful Post: | Silver Ignition (08-07-2014) |
#86 | |
APEXHNTR
Drives: 10 Series FR-S #1867
Gotcha so it's like a balancing act between Base Timing B and Knock Correction Max A. So looking at this weird spike, should I pull another degree or two of timing? Issue is, looking at the chart, the Engine Load is pretty steady in the 1.1-1.25 range across the board but there's that random downward spike on the FLKC...so how do I tune this out?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#87 | |
All you do is look at the Engine load/RPM point where the knock is occurring. In this case 1.2 to 1.3 load and RPM 6100-6700 and the ECU is pulling about 2 degrees so remove about half that ie about 1 degree or slightly more from the cells in that area ie load 1.2-1.3 and rpm 6100-6700 area out of the Base_Timing_B table. |
#88 | |
here is a log with a few more timing parameters that makes it easier to see graphicly. http://datazap.me/u/steve99/98-knock...zoom=1846-2750 |
#89 | |
APEXHNTR
I think I'm getting this now... You're awesome dude thank you so much
#90 | |
Drives: UK GT86
Base timing table is just that, your base ignition timing value. Most people reference the KCA table just as the advance table and is why the IAM is the advance multiplier. So the calculation of IAM x advance table value is then added to the base timing. This gives you the output timing. FLKC (Fine Learned Knock Control) will then be subtracted from above when necessary. If you log FLKC you will see where the timing is being reduced, and if you look at the total timing, usually you'll see the sudden change, especially as the ignition timing should be relatively smooth. If it's consistent then look to remove timing and in the area. If you can see the timing as a graph (total timing ideally), then look to make it smooth. It could be a non-smooth table is inducing knock. Using VGI's tool can make it quick and easy to spot any correllations etc. You could alternately try changing the fuelling a little if timing doesn't seem to make much difference. I would test both methods.
.: Stealth 86 :.
#91 |
APEXHNTR
so what is the ECU seeing/doing when I have changes to FLKC? Is there actual knock events happening or is FLKC adjusted to prevent knock?
same maps/settings as the last log, only this is a 3rd gear only, 2-7.6k pull http://datazap.me/u/silver-ignition/...=0&data=1-4-12
#92 |
Drives: UK GT86
FLKC is in response to what the ECU though was a knock event. It's not instant, but is stored for when that area of timing is passed again. The ECU will try and add timing back in after time to "test" the area again but if it continues to see that it's a problem area it will keep the timing removed.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Walla Walla (08-07-2014) |
#93 | |
As per @Kodename47 post above also read link below its for WRX ECU but the process is same but IAM calculated different in BRZ/86 but it appears most of it applies to 86/BRZ http://www.romraider.com/forum/topic1840.html http://www.romraider.com/forum/topic5371.html It appears the ECU applies the FLCK correction to the timing and also stores it in a fine learning knock correction table similar to below (this is WRX one. As Kodename47 says if the value in the learning table is negative the ECU will always be trying to "return " the timing if the next time it passes that rpm/load range it see no or less knock. This is why you sometimes see positive FLKC as the ECU "returns" timing previously pulled. Thats the way I think it works anyway ![]() |
#94 | |
APEXHNTR
I did exactly that…flashing now…I'll run it tomorrow and post up
#95 | |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
#96 | ||
Drives: UK GT86
The way I have used to easily see what's happening is as below, using VGI's Tool. - Go to Log Stats screen - Import Log - On the set axis button, copy in your base timing table and verify (save for future if you want) - Set X axis as engine load - Set Y axis as RPM - Set Data as FLKC - Set a filter as FLKC < 0 I would then check the mode value and the count. You can repeat for FBKC too. Obviously if you log pull by pull then you won't need to do that, but if you're logging more than that, it can be useful to see other problem areas.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (08-08-2014) |
#97 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#98 |
Drives: UK GT86
The very same one....
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Turdinator (08-08-2014) |
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks | Shiv@Openflash | Engine, Exhaust, Transmission | 129 | 11-24-2017 07:58 PM |
Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 05:01 PM |
Crawford Billet power blocks | Triumphrider | Engine, Exhaust, Transmission | 0 | 08-01-2014 01:39 AM |
FS: One set of barely used Crawford Billet Power Blocks | Robert@Openflash | Engine, Exhaust, Bolt-Ons | 1 | 06-07-2014 04:13 PM |
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** | R/T Tuning | Engine, Exhaust, Bolt-Ons | 3 | 05-21-2014 11:18 AM |
