jpit
Old 02-01-2013, 12:20 PM   #953
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Originally Posted by Jason@Nameless View Post
I'm certain the cabin noise is up a notch, but well be driving it here shortly to find out. Fired it up last night. It idles like butter - quiet even. But the second you're into throttle it's ballistic.
Jason, um... How do you think it'll be w/ overpipe, HF cat & your latest offset system @ cruise?
My older-guy ears are getting cranky to noise. lol
I'm more concerned abt mid-range TQ as well.
Thx
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 02-01-2013, 12:50 PM   #954
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
Again, all of my 'omg it's so loud' comments are in reference to the full 3" system. It should be pretty reasonable with a 2.5" system. And I'm not a bit concerned about this header producing great midrange and high end gains.
Jason
Jason@Nameless is offline   Reply With Quote
The Following User Says Thank You to Jason@Nameless For This Useful Post:
GTB/ZR-1 (02-01-2013)
Old 02-01-2013, 12:52 PM   #955
Jason@Nameless
Originally Posted by 2forme View Post
I've given up hope of any emissions passing headers.
In Massachusetts? Easy. Which entity does your smog checks? Let me know and I'll straight up call them to figure out what we need to do to comply. In the Democratic Peoples Republic of Kalifornia, lololol...nochance.
Old 02-01-2013, 12:53 PM   #956
OrbitalEllipses
Drives: Attitude
Jason
What's the diameter of the original one-piece OP/DP?
Old 02-01-2013, 01:00 PM   #957
2forme
lol basically needs a cat and to pass the OBD test without disabling sensors. I just want a nice catted header that makes good power and flows nice. Bonus if it works well with a SC as I'm leaning toward that route.
Old 02-01-2013, 01:11 PM   #958
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
You have a chance!!!
Installers may not install a new aftermarket catalytic converter in a vehicle unless all of the following conditions are met:
(A) The vehicle is specifically included in the vehicle application list for which the
new aftermarket catalytic converter has been exempted;
(B) The vehicle is more than 7 years old or has more than 70,000 miles on itsodometer;
(C) The vehicle is beyond the coverage of the OEM catalyst warranty period(which can vary from 7 years or 70,000 miles to as high as 15 years or 150,000 miles).2 Installers may reference the vehicle owner’s
manual/warranty booklet or contact the vehicle manufacturer or its
representative to verify the applicable OEM catalyst warranty;
(D) The vehicle has a legitimate need for replacement of the existing converter that has been established and documented by the installer on the repair invoice. If the OEM converter is present, the installer must make a determination that it is not functioning properly before acting to replace it;
(E) The exempted new aftermarket catalytic converter is installed in the same location as the OEM catalytic converter it is designed to replace. The front face of the installed catalytic converter shall be no more than three inches further upstream or downstream in the exhaust from where the front face of the OEM catalytic converter was located. The installation may not alter the location, position, or orientation of oxygen sensors upstream and downstream of the catalytic converter(s);
(F) The exempted new aftermarket catalytic converter is installed on a one-forone catalytic converter (not substrate) basis;
(G) The exempted new aftermarket catalytic converter is installed with all other required catalytic converters (no consolidation of catalytic converters, nor addition of extra catalytic converters is allowed); and
(H) A warranty card has been filled out by the installer, signed by the customer, attached to the repair invoice, and a copy returned to the manufacturer.
We just gotta tack on a buncha miles and limit the design of the header!
Old 02-01-2013, 01:26 PM   #959
2forme
Actually, on second thought, it probably wouldnt work. I already have an SRT headerback exhaust. So the chances of getting a stock fitting aftermarket header with a cat are slim to none :-/
Old 02-01-2013, 01:32 PM   #960
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
All I'd like is a full exhaust from nameless. Catted UEL header, 2.5" all the way back and a bit louder than stock but just enough to hear the subbie rumble under accel, doesn't need to be crazy loud.
Can't wait for you guys to finally release your headers
pheoxs is offline   Reply With Quote
Old 02-01-2013, 01:33 PM   #961
FR-S Matt
I don't think Nameless will be doing a UEL since it is just for sound. They're sticking with their EL longtube design for maximum performance last I saw Jason talk about a UEL.
Old 02-01-2013, 01:35 PM   #962
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'm pretty sure the majority of headers exits at the stock position for maximum marketability (more exhaust/header combos)
Old 02-01-2013, 01:37 PM   #963
2forme
Yea, but they make most of their gains from removing the cat.
Old 02-01-2013, 01:38 PM   #964
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
You can still have catless headers with the same spot for the pipes ...
Old 02-01-2013, 01:40 PM   #965
2forme
I understand that, my point is a majority of them are catless and I don't want catless. I'm tired of having to hunt around for an inspection sticker.
Old 02-01-2013, 01:43 PM   #966
OrbitalEllipses
Drives: Attitude
Those look like Federal emissions requirements, not state-specific. I could be wrong, but I don't feel like searching. For me to pass emissions...they need to visually check under the car for the cat (there's one in the DP that they'll see) and then just do ODBII scan. I can get away with a tune that turns off the CEL.
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
