#869 |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
Perfect. I'm going to run it almost completely out of gas and fill it up out of a drum. So it should be like e82 or e83 haha.
#870 | |
see thread here http://www.ft86club.com/forums/showthread.php?t=61463 Horsepower gains on stock car are not big but drivability is improved, especially low/midrange. Gives option to run E85 on stock car and access to "free" tunes if you ever add bolt on bits at a later stage. Open flash Tunes are based on later ROM which have fixes for idle, transient knock problems which some dealers are reluctant to reflash for you for some reason |
#871 |
Drives: FR-S 10 #103 AT
You make it sound easy. There are so many threads mentioning this product that finding a particular dyno chart is like looking for a needle in a hay stack.
I ordered one (ships today ![]()
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#872 | |
Drives: 2013 Toyota 86 GTS
Stock cars Ran an average of 105rwkw but varied between 102 to 110rwkw depending on how they were run in and number of km. (older cars and cars run harder made more power) The e85 cars with boltons were in the 125 to 135rwkw range, the stage 1 pump oft's were around 115 to 118rwkw. For comparison a supercharged car made 138rwkw, turbo cars made between 150rwkw and 230rwkw. |
#873 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#874 | |
Drives: Subaru BRZ 2014 Limited WRB
Still a good buy on an 93 Octane Daily Driver (stock AT)? No big complaints about current driveability, but would be happy to see/feel a smoother idle/ride, smaller torque dip, and maybe a little more power when needed. |
#875 | |
Edit: I will go so far as to say this, with the Stage1 tune, the FA20 probably could have made the Wards 10 best list. |
#876 |
No doubt, how it effects the engines long term is yet to be known though, but it does seem that the harder you run it, the more power they make.
As much as 10% difference in power on totally stock cars! That's well above natural variance |
#877 | |
#878 | |
I sometimes wonder if there isn't a break in timer on this car, like Dodge has on some of its vehicles where the ECU has a "limited power" mode for the first few thousand miles until the car is properly broken in by their standards. I know it sounds nuts, but I haunted a Challenger forum because I was considering going big car before I saw the FR-S and the regulars there swear that it's true.
#879 |
Erected Member
Drives: frs
I do find it annoying that i have to drive around to have the ecu relearn after every oft flash, it makes it very slow to custom tune with the oft, unless there's some special way to reflash without relearn time that I didn't know about.
If anyone knows how to reflash without relearn time please let me know.. |
#880 | |
#881 |
There is a small period where the ECU adjusts to the throttle pedal positions, but this doesn't affect WOT power, it just gives a bit of a softer throttle response until it has sorted out the learning.
#882 | |
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
Tags |
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
