06-23-2014, 07:59 PM | #71 | |
That Guy
Drives: 2013 asphalt FRS MT
06-23-2014, 09:02 PM | #72 | |
Drives: Hydra EMS Powered FRS Raven Black
The issue that needs to be overcome when trying to add a supplemental oil pump is how to keep it from working against the oem pump. An external pump can replace the oem pump entirely. |
06-23-2014, 09:57 PM | #73 | |
As a general rule of thumb tightening up the viscosity range is better so don't go to 0w-40 as I've had very poor results with that. I personally raced N.A. on 10w30 and thought that worked great for me as I was ru ning a little more power, e85, and higher RPM. Thanks, Phil Grabow |
06-23-2014, 10:21 PM | #74 | |
I have an Accusump and I'm going right at the mains as thats where a pressure drop will cause damage. The heads really don't need the high oil pressure like the crank and main bearings. |
06-23-2014, 11:04 PM | #75 |
Stig's dark passenger
06-24-2014, 12:20 AM | #76 | |
Could you use an external pump plumbed in at the sandwich plate and call it a day?
Also, what about separating the oil channels, having the external pump go to the mains and have the OEM pump cover the top end, or vice-a-versa? Quote:
06-24-2014, 09:18 AM | #77 | |
I will most likely install an oil cooler first to see if we can at least get street oil pressures to stay in target. The Accusump will be a bandaid for the track issue of oil starvation until I'm finished testing all I can for an OEM parts oil pressure solution. Plus while I'm testing on the street its nice to still have A.C. LOL! Thanks, Phil Grabow |
06-24-2014, 09:43 AM | #78 | |
This is where we stand right now as for Element Tuning we need to discover issues and then come up with staged solutions for our engine and Hydra customers. I have a couple more tricks up my sleeve that I need to test but I do think a good air to oil intercooler is going to be a must for turbocharged setups in the 400+ hp range. The cooler oil temps will overcome the pressure drop from the added restrictions. If my "trick" doesn't work then I do believe an external oil pump along with the oil cooler would be the next stage. Track day boosted people could add an Accusump and some sort of large drain back air/oil separator. Racers on built motors, turbocharged, slicks, and downforce like us will just need to go to a 3 stage dry sump which is a $5k investment. I'm hoping I can figure something out so we can get away with a 2 Stage like we do with our STi so a dry sump is $2k less. |
The Following User Says Thank You to Element Tuning For This Useful Post: | Surok (03-22-2018) |
07-01-2014, 07:16 PM | #79 | |
Junior
Drives: a car
07-01-2014, 08:06 PM | #80 |
Unfortunately this "trick" is not a quickie so I haven't had time to try it as it requires the removal of my turbo kit, header, and the timing cover. I've been tuning the variable cam timing with the Hydra EMS in open loop with the 14mm pump and cover so this can be an option for some people. I'm hoping I can add a cooler, an Accusump, molasses for oil, and pray it's readable at modest power for either GTA or the Ultimate Track Car Challenge.
I'm also moving forward with plans for an external oil pump. |
07-01-2014, 10:01 PM | #81 |
Junior
Drives: a car
Why do I get the feeling that an external oil pump would cost less than the Hydra EMS and supporting 14mm pump option...
07-02-2014, 08:40 AM | #82 | |
I'll be going back to the original timing cover, make some upgrades, try my "trick", and if that falls short, and external oil pump it is. The downside is that it will be expensive as it will require a geared belt and pullies, a new crank pulley, cnc'ed mount, deleting the air conditioning, oil sandwich adapter, AN fittings, and more. Still for probably around $1800 (I'm estimating) it's better than spinning a bearing in your newly built motor. Later down the road it could be upgraded to a dry sump also. |
07-06-2014, 11:52 AM | #83 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Fair to say the fa20 in wrx is more track ready out of the box huh?
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi |
07-06-2014, 01:06 PM | #84 |
Dismember
Drives: 2013 Red Scion FR-S
http://www.slwautomotive.com/products.php
Scroll down to the DC oil pump. 6bar (87psi) max and 125c max will, with an oil cooler before the pump, possibly give you what you want.
The Following User Says Thank You to EAGLE5 For This Useful Post: | victorb (07-07-2014) |
Similar Threads | ||||
FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 02:31 AM |
FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 05:19 AM |
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 12:33 PM |
FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-17-2013 11:24 PM |
