Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-28-2016, 04:58 PM | #71 |
Drives: Scion FR-S Black
02-28-2016, 05:18 PM | #72 |
Inactive
Drives: .
Yeah just to let you know, if you have aftermarket wheels and tires then your sport mode or trac mode doesn't work the same as with stock wheels and tires.
02-28-2016, 05:22 PM | #73 |
02-28-2016, 05:26 PM | #74 |
Drives: 2014 GT86
5sec TC=VSC off partially (it still can engage if it detects wheel hop or other complete loss of traction for one wheel). EBS also is still on, when one heavy brakes. Though then again, unless on track, i suggest drive on public roads with at least VSC=on always. It should leave enough slack for correction at most sudden unexpected situations on public roads (i learned it expensive way ). On track - if you don't push much, this may do.
Only pedal dance disables VSC/TC & EBS completely, leaving only basic ABS on from all the nannies. Will remove any unexpected nanny intervention, but don't be too overconfident. |
The Following User Says Thank You to churchx For This Useful Post: | Chase1996 (02-28-2016) |
02-28-2016, 06:20 PM | #76 | |
The Following User Says Thank You to ryoma For This Useful Post: | Chase1996 (02-29-2016) |
02-28-2016, 07:09 PM | #77 | |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Right now I think the best solution is for him to ride along in someone elses car or someone ride along with him to find the problem. |
The Following User Says Thank You to Kostamojen For This Useful Post: | Chase1996 (02-29-2016) |
03-06-2016, 01:10 PM | #78 |
Drives: BRZ & Forester
Followup:
Thursday, with TC/VSC off and no pedal dance, I put my car through several hundred safe miles of testing on wet curvy roads. On 2 corners, during what seemed to be right rear wheel hop / lift /+plus sight roll, I believe (what some call) "ice mode” occurred, causing TC/VSC to engage. After that, for some strange reason , the roll was no longer there == Yay!!! I then attempted to reproduce the same results, ...and no matter how hard I tried; including going over the same corners where "ice mode” appeared to engage before, ...nothing happened, and the slight roll was still gone. Friday (during rain) I returned to the place where I first experienced this minor roll, everything was still good, it (roll) did not manifest, so I continued researching and found the following: well, ABS Ice Mode finally got me... http://rennlist.com/forums/997-gt2-g...ly-got-me.html "Ice Mode" …specifically this post: http://rennlist.com/forums/997-gt2-g...l#post11161605 and am considering what CSG_Mike says here: Ice mode is 100% driver error. Regardless of what they say, it is, absolutely, 100% driver error. I can replicate ice mode AT WILL, and if you are inducing ice mode, you're doing it wrong. https://www.reddit.com/r/ft86/commen...t_mode/cnp15zc rather than throw the blame on software. |
03-06-2016, 01:39 PM | #79 |
Drives: Full race 4cyl boxer
Sounds like this thread should have been titled "How to screw up your cars handling and ride - step by step!"
http://www.ft86club.com/forums/showthread.php?t=67345 I have told this story before: I ran into a guy at the track with a BRZ. He had the fastest lap times of almost any BRZ/FRS in the area. At every race, he said, that all the other twins drivers would come over and ask "what did you do to this car to make it so fast?!?" He said "NOTHING!" - "Take all that aftermarket shit off your car and learn how to drive it the way the engineers intended" He had ZERO mods to the car other than wheels and race tires. If you have only driven your car on the street then you have NO BUSINESS modifying the suspension because there is no way that you "know" what the car needs. Unless of course you are a "torretto wanabe" and drive like F&F on the street on a daily basis. In my first 20 minutes on a real track, I learned more about driving that the other 30 years of experience doing what I THOUGHT was "driving" while on the street. |
The Following User Says Thank You to justatroll For This Useful Post: | stevesnj (03-06-2016) |
03-06-2016, 02:34 PM | #80 |
Drives: 2014 GT86
justatroll: i'm 99% sure that he also did alignment in addition to wheels/tires.
03-06-2016, 03:04 PM | #81 |
Inactive
Drives: .
Yeah if you do any track driving I would say save your stock suspension if you already lowered it with something else chances are you will go back to stock and re learn the car and re evaluate what you want vs what you need. But if you mostly do street driving then keeping the rear within factory spec and 0 toe with a little camber won't hurt up front. You can lower it but just make sure you have the supporting items to get it within spec.
03-06-2016, 07:13 PM | #82 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
03-06-2016, 07:50 PM | #83 | ||
Front Strano Swaybar Front camber bolts BRZ front springs matched with FRS rear springs Rear subframe bushings That was it, even with the stock tires the car handled great and I had a ton of fun driving it. I tried other wheels/tires with this setup, and it was still good. But then of course I wanted to lower the car and things changed completely, and I've been trying to get it back to that point ever since :P |
Similar Threads | ||||
Corners, corners, corners :-) | Artalos | BRZ Photos, Videos, Wallpapers, Gallery Forum | 4 | 06-23-2015 12:27 AM |
losing traction? | sskillzz12 | Engine, Exhaust, Transmission | 4 | 03-24-2015 09:51 PM |
Losing Control. | Asterisked Accolade | Other Vehicles & General Automotive Discussions | 19 | 04-06-2013 08:47 AM |
Been on a losing streak with my car lately...help | sa1126 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 04-01-2013 10:18 PM |
Lowered Car, Losing traction while getting off drive ways | 86_ZN6 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 10-26-2012 10:02 AM |
