#71 | |
Drives: 2022 GR86
Assuming a tall driver with not much headroom, in case of a rollover with the roof actually physically moving into the interior, will the DOT approved belt "still stretch" early enough to prevent large forces being applied to their neck? Or will the belt stretch only after the neck is already under stress? My understanding was that harness + fixed back seat but no roll bar is worse than the 3-pt belt + reclining seat in this situation, as the harness+fixed back "fix" the shoulders in a single place, so there's a risk of a lot larger force being applied to the neck. |
The Following User Says Thank You to timurrrr For This Useful Post: | Midnightsky (03-02-2022) |
#72 | |
Drives: 2022 BRZ WRB
#73 | ||
Drives: '22 Tacoma, '19 Macan, '22 BRZ
Cheers guys for a positive conversation. I'll put this out here for some context to others reading - I don't believe this is a trivial matter; changing the safety system from factory to modified has the potential to be dangerous and hazardous to your well being in the event of a crash. If you are not confident in what you're doing and are going off an internet strangers comments - simply don't do it. Consult with a professional. I am by no means advocating for any other changes I have done here for anyone else to try.
According to University of Virginia - roll overs account for 2% of all vehicle related crashes but are responsible for 33% of all vehicle crash related fatalities. They don't clarify if the occupants wore seat belts or not; the point is these are big fatality numbers. https://news.virginia.edu/content/de...look-rollovers Quote:
If I think about either scenario; wearing the factory 3 point belt with Hybrid Sport HANS and wearing the Schroth with Hybrid Sport HANS on, and I roll, land on the roof and the roof comes into the interior space - I don't see a significant difference in my survival rate. I could see there being more 'play' in the locked up factory 3 point belt where I might have more doll rag movement but with my helmet/HANS on I don't think I'd get that much benefit. And then there's the question (assumption?) if that movement is more desirable vs the more fixed position; I do not know. From the UVA study: "One of the most important results we've seen is that the human spine extends, straightens and aligns itself with the acceleration vector in a way we have never seen in other types of crashes... This puts the human head close to the roof, and closer to injury, at the time the roof gets impacted by the ground when the vehicle rolls over." I'm unclear how to read into that. So I rationalize it this way; I'd rather have the Hybrid Sport for virtually other crash scenarios (even with airbags, also that's a big assumption, too!) and I believe those scenarios are substantially more likely than a rollover. I think, in a completely unqualified manner, it is questionable if the 3point + HANS is going to have a significant survival rate increase vs ASM + HANS in the event of a rollover. I much prefer the comfort of the ASM over 3point. So I go with ASM and make my peace. But it's discussions like these that make me reconsider, always. ![]() Quote:
Quick edit here. Found this video clip on the youtube: Some quick takes from Joe Marko (involved in NASCAR safety engineering group) and merchant of Schroth wares as owner of HMS Motorsports. According to him, 99% of roll over accidents injury is due to the head rotating outwards and making contact with the pavement or armco (not from the roof). Less than 0.5% of rollovers occur with a risk of roof caving in. Last edited by Re_Invention; 03-03-2022 at 02:21 PM. |
The Following User Says Thank You to Re_Invention For This Useful Post: | razgriz12345 (03-04-2022) |
#74 |
Drives: 2022 GR86
My mental modeling is that a factor 3pt belt will try its best to hold the driver's butt in the seat while allowing their upper back / neck move to the side/front if needed to avoid the deformed ceiling; and a reclining seat back might even allow some movement towards the back of the car if it collapses.
While a 4+ point harness will lock the driver's upper back to the fixed back of the seat, and the fixed back won't move unless there's a massive force coming through their head/neck to move it. |
#75 |
Brief update here.
I installed the Cusco throttle pedal. It's a cheap, reversible part and it made a small but positive difference for heel-toe movement. There's no down sides and I certainly recommend it. I have not yet cut the headliner. I was doing some due diligence before taking the knife to the headliner and saw some videos on youtube of 2g twin's owners getting custom starlight headliners installed and I noticed the bracing structure and lines appear different on our second generation cars compared to the first. I was hoping to be lazy and make the cuts from inside the car, without having to remove the headliner. But now I'm uncertain of where the potential power lines are and will need to set some time aside for a headliner removal and proper cutting. As far as the seat bottom goes - I'm strongly reconsidering the pan basket removal. As I said in a prior post, removing the bottom support basket/bracket it has let the butt drop lower but now created new pinch points on my hips from the side leg bolsters. It's annoying enough to warrant reverting back to stock. I've purchased a seat belt buckle end to plug into the factory 3 point belt receiver when using the harness. It's to A) get rid of the seatbelt warning chime while on track and B) ensure the airbags deploy at full force in the event of an accident. I do want to clarify a potential safety issue on a previous post of mine: I stated I will be using the Schroth Rallye 3 ASM + Simpson Hybrid Sport HANS. I reached out and spoke with a representative from HMS motorsport regarding the combination of the Schroth Rallye 3 ASM + Simpson Hybrid Sport HANS device. According to the rep; they are not compatible together. That was a false assumption on my part. So I repeat; according to a product specialist at HMS Motorsport; the Schroth Rallye 3 ASM and Simpson Hybrid Sport HANS device should not be used together. I will quote the reasoning directly; "The belts do not work with devices, regardless if it attaches to the body or not, because the belt would be pushed off the device as all devices are much narrower than the human shoulders. When you go forward, the belts get slightly wider, thus coming up on the little winglet on that device and then popping over it. I know they sell that device saying it works with a factory 3 point, but it does very little to actually protect you as the motion with a 3 point belt is different than how that device is designed to work. ALL head and neck restraints are only designed to be used when both shoulders are stopping at the same time with both shoulders staying on the same plain, not one rotating forward some compared to the other." Reading between the lines I felt like there some, uh, let's say suspicion of the Simpson Hybrid Sport product in general by this individual. While I understand the belt size being incompatible with the channel on the device, I do not understand why the tension on the tethers connected to the helmet being materially different if the anchor on the body is independent from the harness itself. I can see the inside shoulder articulating some but the force distribution on the body should still be similar. Meaning; if the product is designed for a factory 3-point where the shoulder articulates in the event of an impact, why would the Schroth harness, which has the same or similar movement allowance, be materially different? I responded to their message with a direct question: do they believe the Hybrid Sport is an inferior product and should not be used at all? I did not receive a response - probably a better question over the phone. I'm going to continue to explore the topic with other specialists in the field. But yeah, for transparency sake and to contribute to our collective knowledge base here I wanted to follow up with this information. Frankly I'm bummed the Hybrid Sport and Rallye 3 are incompatible per the rep. I'm undecided which product is going to get priority and usage from hereon out. I do believe the HANS is a vital part to motorsport safety and I see a higher likelihood of having some sort of front/side impact incident where a HANS would be good to have on. Seeing professional drivers and instructors all around praise the product for what it is, and the common sense of having that extra security to reduce the force to the neck movement, makes it a seemingly obvious choice. On the other hand, the immediate benefit of the Rallye 3 is huge while on track. The extra comfort and security in the seat has made a big, tangible difference in quality of life and well, better lap times. Tim - I believe I understand your line of thinking. I do see the biggest thread as a fixed back seat in the event of a roll over. I'm still exploring helmets - I don't think there's going to be a big discrepancy between brands or models when it comes to overall width/height given what I've been told about the SNELL certification requirements. Considering an open face this time around, not as safe as a full face but loads more comfortable and convenient. Going to pull the trigger on the Pyrotect Pro-Sport Open Face SA2020 for $199.99 and remove the sunvisor piece. In other news, I've ordered a load of additional parts: Schroth 2" Harness Pads Subaru STI Lateral Link Set (rear lower control arms + toe links) Subaru STI Sport Springs Cusco Steering Rack Bushings (+ tool) Cusco Axle Boot Heat Shield Pedder Offset Strut Mounts Porsche GT3 Front Brake Ducts Subaru JDM clear side markers And still waiting on the Lathewerks 5" angled shift extension piece to come in. Cheers All, Colin |
The Following 3 Users Say Thank You to Re_Invention For This Useful Post: |
#76 |
Drives: 2022 BRZ Limited WRB, MT
Sadly I am selling my BRZ for profit and I have a 22 WRX GT on order.
Too hard for my old ass to get in and out. Wife hates it for that and she can't drive stick. I had my fun for 4 months and made 3000. I got 1000 off msrp on the WRX, even though no one is going below MSRP. I played dealers against each other. I guess this was my solution for taller drivers. I'm 6 foot 2 and 53. |
#77 | |
Drives: 2022 BRZ Ltd, 2019 Ascent
#78 | |
Drives: '17 Subaru BRZ series.Yellow
Which is not to say Schroth harnesses are poor in design or quality. I've used Schroth 6-points system in my race car. The ASM just isn't fit for purpose; Schroth includes it under their "tuning" section. Tuning, AKA, some safety benefit but mainly for show. |
The Following User Says Thank You to series.trackday For This Useful Post: | Midnightsky (03-28-2022) |
#79 | |
Drives: 2023 BRZ
SIMPSON RACING HYBRID S
Director of Rocky Mountain 86CUP
The Following User Says Thank You to Pat For This Useful Post: | timurrrr (03-28-2022) |
#80 |
Drives: '22 BRZ
The Hybrid S is the only HNR device that is rated to work with a 3 point belt.
#81 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Cut the roof off and make a convertible.
Just like what they had to do to the Toyota 2000GT in "You only live Twice" to get Sean Connery to fit. |
The Following User Says Thank You to Sasquachulator For This Useful Post: | Midnightsky (03-28-2022) |
#82 |
There is a bit of BRZ folklore that I have not verified, but it goes along the lines of Toyota wanting to create a drop-top version. Still stinging from being talked into building the car in the first place, they said as long as it is being built in our factory, no. The roof is integral to the rigidity of the car and the development costs would be too much. If anyone is serious about fitting in the BRZ/86, spend some bucks and have a “Gurney Bubble” installed. Race car driver Dan Gurney had trouble fitting in the Ford GT40 so the car was modified. Gurney was 6’4”.
#83 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
My update was just deciding I’m not interested in a new one.
I also removed most of the interior of my car for this season, a bonus extra little bit of headroom there in my 13. |
#84 | |
I finally found seats for big and tall people! | arkanist | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 11-26-2019 05:31 PM |
How tall are you | djmm | Scion FR-S / Toyota 86 GT86 General Forum | 122 | 12-26-2013 04:05 PM |
Portland people meet with Seattle area people before going into ForumFest 2013? | stockysnail | Northwest | 24 | 06-18-2013 06:19 PM |
Seat fit for tall people? | clubraf | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 06-29-2012 10:51 AM |
How tall are you? | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 111 | 11-14-2011 03:32 AM |
