03-03-2016, 03:28 AM | #57 | |
Drives: 1981 Holden Commodore
The things you've discovered and shared over the time you've been doing your conversion may be used by someone to make a profit, and that's worth being angry. But being irritated that the free market is responding to a demand - when you're a part of the demand - is ridiculous. If the free market wasn't responding quick enough the option was there for you to pay an extortionate amount of money to a professional but you didn't so you have to wait for it to catch up. |
03-03-2016, 07:18 AM | #58 |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
I am happy to see there are more CAN BUS solutions than before. Developing software from scratch to work harmoniously in modern sports cars requires time, money and skill. The factory ECU probably ¯\_(ツ)_/¯ uses proprietary software someone would have to reverse engineer. Without significant demand, nobody in their right mind is going to waste company resources bringing such a product to market.
03-03-2016, 07:33 AM | #59 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
The irritating part is people have voiced their concern for years (at this point) that their only issue with swapping the motor was having CAN functionality. I've spoken with countless people that said they're holding off until there is a fix.
When I say this, I'm talking about the guys not wanting to spend $6000+ on a MoTeC setup. And even then, I can't think off the top of my head of any privately owned swap car with a MoTeC that hasn't skimped out on anything else.
03-03-2016, 01:36 PM | #60 |
Drives: 2013 Ultramarine FR-S
So you are upset that it has taken so long for people to start working on this?
03-04-2016, 06:10 AM | #61 |
Drives: LS3 BRZ
Sorry it has been a while. I have been juggling a few jobs including my other project of getting the FA20Turbo motor to work in a VW (which it does ).
As mentioned previously the prototype pretty much worked apart from the ABS and traction control lights remaining on. Because I am not exactly close to anyone doing a build and do not have an 86/BRZ myself I was relying on the FA20T ecu from the current model WRX, which is so close to being the same, but unfortunately not exactly the same. I have now done some testing in a BRZ and found a few little discrepancies with the data between the FA20 and FA20T, mainly around the ABS functions, so I am pretty confident it will work after fixing these bugs. I now also have access to a subaru monitor tool which will give more diagnostics, particularly with the brake unit. I am also just finishing off the coding to allow the unit to interface a BRZ/86 canbus system to a non canbus engine by having inputs for RPM and temp gauge etc. This system however, will not retain the traction control function. |
The Following 5 Users Say Thank You to toddy101 For This Useful Post: | 8686 (03-04-2016), Calum (03-04-2016), SleepingPanda (03-17-2016), whataboutbob (03-14-2016), WRBrzRX (03-05-2016) |
03-05-2016, 10:13 PM | #62 |
Yeah, I suppose you can say that.
The Following 2 Users Say Thank You to slicktop For This Useful Post: | DustinS (03-07-2016), Sportsguy83 (07-29-2016) |
03-14-2016, 02:28 PM | #63 |
Drives: Race Car
You can build a simple CAN device to read/write to the bus with a Raspberry Pi (Now built into the kernel from a software/driver stand point) or with an Arduino. Monitoring the channels is easy enough but trying to figure out who reads/writes what will be a large undertaking in organization and patience. But certainly possible.
I don't think many of your aftermarket ECU options will work because I don't think they allow 100% of all parameters to be configured when it comes to CAN. Most of them just allow the ECU to output data to a CAN bus, but I don't think you can configure the device ID to match the stock ECU to make it look like the stock ECU is still there. You can do that yourself if you are good enough at programming and building a microcontroller to do that for you. I would suggest that the easiest way to do an engine swap is to approach it like a race shop would do. Simply strip out the original engine/trans and the wiring and put your own in. You can easily buy aftermarket gauges to replace the stock cluster. You can even hack the AC to work or simply replace it with an after market solution. I don't know how well the stock evap unit will work with another engines compressor anyway, so you might after to replace the whole thing no matter which route you take. I doubt the chassis electronics are all on the CAN network but even if they are they are always be re-wired with the existing switches and relays to do the same job. |
03-14-2016, 03:41 PM | #64 | |
Drives: 2015 Raven V8
Unless you're building a race car that is completed gutted I would avoid hacking up the car that much. CAN network controls a lot of things in these cars, easier just to work with it. Your first paragraph is the winner. I personally used Arduino. It's not super hard but people just want to buy something and plug it in. There are a lot of people who desire an engine swap but are not willing to put in the time to learn anything new. |
03-14-2016, 08:27 PM | #65 | |
Drives: FRS Silver LS1 swapped.
03-15-2016, 01:42 PM | #66 | |
Drives: '13 BRZ
Awesome work man. Looking forward to updates. |
03-15-2016, 01:50 PM | #67 |
Drives: 85 corolla gts
When doing these types of things, getting certain info that is available through the factory can bus is nice to have. Not all ems systems will accept certain data over the can bus, hell many have it locked down. If you have a goal of using any this info that is available over the can bus then pick your management system appropriately. If you just want the basic functions to work, an interceptor may be an acceptable option for you.
04-07-2016, 08:51 PM | #68 |
So it's confirmed that Emtron EMS fully integrates with the FT86 platform (at least with my 2JZ swap).
I just drove the car again today after @Ross finished up the wiring harness and installed the Emtron KV8. EPS (Electronic Power Steering), tachometer, speedometer, fuel level, coolant temp are all functional. The Emtron will also take care of the traction control.
The Following 5 Users Say Thank You to slicktop For This Useful Post: | Draco_PR23 (04-09-2016), DustinS (04-08-2016), kmbkk (04-08-2016), RiceBuster (04-07-2016), Sportsguy83 (07-29-2016) |
04-09-2016, 02:50 PM | #69 |
[ame="https://www.youtube.com/watch?v=CxadzLqWLYg&nohtml5=False"]2JZ FRS showing full CAN integration with Emtron KV8 - YouTube[/ame]
The Following 3 Users Say Thank You to slicktop For This Useful Post: |
04-09-2016, 09:40 PM | #70 |
That Guy
Drives: 2013 asphalt FRS MT
How much is the KV8, I can't find a price for it?
Similar Threads | ||||
Eric's BRZ - A motorsports engineers perspective | eric6 | Member's Car Journals | 225 | 07-14-2015 11:15 AM |
Why I like Mazda engineers | themadscientist | Other Vehicles & General Automotive Discussions | 59 | 03-02-2015 10:41 PM |
For you engineers out there... | cdrazic93 | Off-Topic Lounge [WARNING: NO POLITICS] | 32 | 02-05-2015 01:16 PM |
Engineers Certificate needed for turbo kit? | happytimetom | Forced Induction | 18 | 02-23-2014 05:47 PM |
Software and electrical engineers look here | jonbonazza | Engine, Exhaust, Transmission | 6 | 09-15-2013 11:06 PM |
