09-26-2014, 05:16 PM | #57 | ||
The FRS/BRZ big issue is it's not a track car. In stock form its fun on the street. But if you want to autox or track. You don't have a factory way to adjust alignment which means as soon as you put sticky tires on, you have to go to the after market for camber kits. That's a huge downer with it compared to the S2000. S2000 all you beed to do is order tires, head to alignment shop, go to track. On a light braking track the S2000 OEM brake will hold up with stock pads. FRS won't. But you should be swapping pads on both cars for track days regardless, thats normal practice. The difference between the two is basically this. The 86 modified and unmodified is more accessible and neutral for a newer and average driver to control and enjoy. Its predictable and forgiving. That gives most confidence to push harder. The S2000 is much more edgy and is much more rewarding when driven by someone with more seat time who is ok with being in the edge. The car rotates in every corner, under hard braking which requires constant input from driver. You have to stay ahead of this car or it will spin. It's not forgiving. The 86 has the potential to be the better handling car for most people. But if you have experience the S2000 is much more fun to drive as it's more challenging to go fast. Quote:
The 86 can be that almost primary car. The S2000 will always be that smile on your face second car in 4 season climates. If you had to choose one or the other as your only car you choose the 86. But if you didnt have to do that and wanted to choose the better sports car...(stock)
The Following 4 Users Say Thank You to Dezoris For This Useful Post: |
09-26-2014, 05:37 PM | #58 |
No Money, No Problems
As someone who knew what they wanted in a first "new" sports car, you pretty much summed up exactly why I went with an FR-S over buying a used S2K or something similar.
09-26-2014, 05:41 PM | #59 | |
Off Topic
It's only due to a rare moment of sanity that I don't have a bright yellow 2005 S2K. |
09-26-2014, 06:08 PM | #60 | |
This is all dependent on whether or not you can fit in the car properly.
09-26-2014, 06:11 PM | #61 |
Off Topic
09-26-2014, 09:38 PM | #62 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Finding an unmolested S2000 is also impossible
Sent from my OnePlus One |
09-27-2014, 08:39 AM | #63 |
Drives: 2013 WR Blue 6MT BRZ
i would agree, as the video created concluded, that it is more headache than its worth to add forced induction to the GT86.
i would disagree however that this is not a track car. i would instead say it is a good beginner's track car, as you can learn to drive at its limits more easily |
09-27-2014, 10:59 AM | #64 | |
09-27-2014, 11:15 AM | #65 | |
If you hop in and expect to match other experienced drivers with expensive or modified cars after a day on the track because you did in your last car, then yes, you require all of those things before you go, but if it's your first time at the track you will need a couple days to get the hang of it, you can distribute those costs as you get better and run into the roadblocks and learn and do the jobs yourself. Still a great beginner track car stock, especially for someone who's last goal is to get a laptimer and analyze data the next day. |
The Following User Says Thank You to strat61caster For This Useful Post: | lionbacker54 (09-28-2014) |
09-27-2014, 02:31 PM | #66 |
Drives: e92 M3
Sounds like S2000 might be the only track-ready stock car on the market. Are there others <70k? How does track-prepping the FRS compare to Miata, 240sx & 350z? These cars are ubiquitous on the track, and it seems like they only change oil, tires and pads.
09-27-2014, 02:44 PM | #67 |
Drives: BMW 120d
Ultima GTR/CanAM... Though I have a feeling the definition of stock is getting a little stretched!
09-27-2014, 03:51 PM | #68 |
Drives: 2013 FRS / 2013 427 Vert
To be fair, four of those are consumables and most track addicts are constantly making changes as they wear out.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
The Following User Says Thank You to Deep Six For This Useful Post: | strat61caster (09-27-2014) |
09-27-2014, 04:13 PM | #69 |
in stock form, you don't need an oil cooler to run at a track. Keep an eye on temps via torque and pull off when you reach a certain temp. For me 250 is where I stop.
09-27-2014, 04:18 PM | #70 |
Drives: 2013 FRS Whiteout
I guess the oil cooler comes in so you don't have to pull off. Although as you mentioned is not needed.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
Similar Threads | ||||
S2000 vs FR-S BRZ Review | Video Part 1 | Dezoris | FR-S / BRZ vs.... | 115 | 07-15-2015 12:11 PM |
Vortech Finale Review Video | Track Testing | Part 4 of 4 | Dezoris | Forced Induction | 75 | 04-12-2014 12:45 PM |
The Sad Truth | Vortech Autocross Review Video Part 3 | Dezoris | Forced Induction | 19 | 07-24-2013 04:18 PM |
My track day video at Willow Springs 1-19-13 vs S2000/FR-S/RX8 | Mark Slide Squad | Tracking / Autocross / HPDE / Drifting | 18 | 02-04-2013 07:26 PM |
Track Video: BRZ Passes worked Miata, unable to be passed by prepped s2000 | gmookher | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 11-06-2012 01:01 PM |
