Old 08-24-2013, 12:49 PM   #57
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by ericmpena View Post
I just received my Sportlines yesterday. I found a place that will install them but here's what they're telling me:
I will need a camber kit. I should not install any spring without a camber kit. If this is true, what do you all recommend? I'm really trying not to spend too much money. It's already $200 for the spacers and $240 for the Sportline. I'm sure it'll be another $250ish for install. That's a $700 project already. Do I need both front and rear cambers?
Also, the auto shop is telling me that I need to get the allignment the day that I get the springs put on, and that costs $90. Is that BS? I've read everywhere that you're supposed to wait about 2-4 weeks before your first allignment. This mechanic was swearing otherwise.
Personally I'd like to just be able to have the Sportline installed and be done with it. If there's going to be much more to this project then I might just sell the springs and not stress myself with it. I don't want my tires needing to be replaced every 3 months or having my tired rotated every 400 miles. That's just too much crap to worry about instead of me just being able to enjoy my ride.
Bottom line, what exactly do I need in order to not mess up my car with these springs?
Do them yourself. It takes less than two hours and all you needs is two jack stands, a jack, and wheel chocks.
I ordered front camber bolts and control arms. I may not even install them.
Old 08-25-2013, 09:49 PM   #58
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
DIY: http://www.ft86club.com/forums/showthread.php?t=10842
The Following 2 Users Say Thank You to DarrenDriven For This Useful Post:
8R6 (03-20-2014), klearfade (08-03-2015)
Old 08-26-2013, 11:38 AM   #59
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I understand I can do it myself, but that still does not answer my questions. So my basic questions are:
1. Will I run into any issues if I do not install front and rear cambers?
2. If cambers are needed, which do you recommend for me to purchase?
3. How long do I wait before getting my wheels alligned?
ericmpena is offline   Reply With Quote
Old 08-26-2013, 12:51 PM   #60
DarrenDriven
NW Region Moderator
1. The only issue will be increased tire wear on the inside of your tires over a longish period of time. I have often lowered my cars and not corrected camber, although it forces tire replacement about 25% sooner than you otherwise would need it.
2. Can't help with this one... anyone?
3. I would wait at least 24 hours before getting an alignment as the lowering springs may settle slightly once they have been installed.
The Following User Says Thank You to DarrenDriven For This Useful Post:
ericmpena (08-26-2013)
Old 09-17-2013, 03:13 AM   #61
ericmpena
ericmpena's Avatar
I finally got my Sportlines installed today. I don't have a full car picture because it's already dark outside, but here's some close-ups of the wheels before and after. I'm very satisfied with the look!
The Following 4 Users Say Thank You to ericmpena For This Useful Post:
2015firestormFRS (11-01-2015), exE36M3 (04-18-2014), FLIPDADY (08-02-2020), hmong337 (02-05-2014)
Old 09-17-2013, 03:24 AM   #62
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Can't wait to get mine!
ck-GT86 is offline   Reply With Quote
Old 09-17-2013, 07:21 AM   #63
ericmpena
ericmpena's Avatar
When I saw my car finally finished with the springs on, I could not stop smiling! The drop looks so perfect to me. It's exactly what I was looking for. I'll post some more pics when the sun comes up.
Old 09-17-2013, 10:34 AM   #64
ericmpena
ericmpena's Avatar
Here's a full car pic with the Sportlines. The new wheel gap is a little hard to see so I included half car pics that show the new gap clearer.
chanomatik (01-16-2014), ck-GT86 (09-17-2013), FLIPDADY (08-02-2020), hmong337 (02-05-2014)
Old 10-22-2013, 07:13 PM   #65
ericmpena
ericmpena's Avatar
I just noticed the the rear passenger side of my car sits a lot lower than the driver side. I can easily place 2 fingers between the tire and frame on the driver side, however on the passenger side I can barely fit 1 finger.
I've always thought that the rear looked a little saggy from the passenger side, but after looking closer I'm seeing a big difference of almost half an inch. Any suggestions? I've had the Sportlines installed since Sept.17th. Here's some pics.
The pics are in this order:
1. Driver side close (Picture taken with camera sitting on the street)
2. Passenger side close (Picture taken with camera sitting on the street)
3. Driver side far
4. Passenger side far
Update: I read some people saying on various forums that this could be due to a the gas tank being full. I'm not sure about that as I only have half a tank, but maybe I'll check it when I'm closer to empty and see if there's any difference.
The Following User Says Thank You to ericmpena For This Useful Post:
Old 10-29-2013, 12:29 AM   #66
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
Any luck with finding out the reason behind the uneven look?
3. Driver side far
Shad0ez is offline   Reply With Quote
Old 10-29-2013, 12:49 AM   #67
ericmpena
ericmpena's Avatar
Yes I did.
Prior to taking the pictures I had just installed wheel spacers on my rear wheels. I did the passenger side first, then the driver side.
After finishing up with the rear driver side wheel I lowered the car off of the jack and then was checking out the finished job. That's when I noticed that the passenger rear was a lot lower than the driver rear. I started freaking out!
I didn't hit me until I went back outside later in the day and saw that both sides were sitting even.
Raising up the car to install the wheel spacers took the stress off of the Sportlines, so when I took the car off of the jack it took a few minutes for the Springs to settle back into their normal drop.
Since I did the passenger side first, it had 10 minutes or so while I was working on the driver side to settle back down to it's regular drop.
So in conclusion, it wasn't that the passenger side was sitting low, it was the driver side that was sitting very high. It eventually settled back into the regular drop and now all is well! I meant to post a follow up but I've gotten busy with other mods. Thanks for reminding me!
The Following 2 Users Say Thank You to ericmpena For This Useful Post:
chanomatik (01-16-2014), flippy (04-17-2015)
Old 10-29-2013, 01:02 AM   #68
Shad0ez
Shad0ez's Avatar
Not a problem, I'm exploring as many different options as possible before deciding on what I will be doing and would like to know the pro's and con's of each set up.
So wheel gap all around is about 2 fingers, or does the front have more space than the rear?
Old 10-29-2013, 07:09 AM   #69
ericmpena
ericmpena's Avatar
On my car the rear sits a little lower. I have about 1 finger space in the rear wheels, and 1 1/2 finger space on front wheels. Can't quite fit 2 fingers for the front.
Old 10-29-2013, 07:51 AM   #70
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Is this still 1 of the biggest drops you can get from springs or is there something else?
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 07:26 PM
Eibach Sportline Spring review Dave-ROR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-24-2019 07:23 PM
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 4 07-06-2012 12:04 PM
Anyone running Eibach lowering springs? Bahraini86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-01-2012 03:05 PM
