09-01-2014, 05:52 PM | #659 |
Drives: 2013 BRZ, 1979 Scirocco 16v
Hey guys, just wondering where I stand with my Stage 2 93 oct flash. Car has a Tomei UEL, Perrin 2.5 non-res catback, K&N panel filter and modified stock snorkel.
(Note, this pull was in 2nd gear only, approximately 75 degrees at 7:30 am, so relatively low humidity) http://www.datazap.me/u/fleischwagen...log=0&data=1-7 |
09-01-2014, 11:24 PM | #660 |
Drives: MT Raven Black FRS
@Shiv@Openflash can I use a Mac or do I have to use windows?
09-02-2014, 02:32 AM | #661 |
Drives: '13 SSM BRZ Limited 6MT
is there a preset tune for the following mods: Perrin Inlet hose, Perrin 2.5" Catback resonated exhaust? Considering switching from my Unichip if there's not much work involved with changing settings and such.
09-02-2014, 02:44 AM | #662 | |
Quick answer is yes Stage 1 OFT Tune would be flash and go maybe 10 minutes, would take you longer to remove uni-chip. Which TUNE should I run and what Mods are supported Check the file called "release notes" in the zip file for the tunes you download from the site . Rough guide OTS Map Requirements: Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune. Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune 91 (USA) octane or better required for 91 octane tunes 93 (USA) octane or better required for 93 octane tunes E85 required for tunes labeled E85 (ie fuel with 60 to 90% ethanol content) Exception for Stock cars running E85 use Stage 2 E85 EL header tune http://www.ft86club.com/forums/showthread.php?t=67310 |
The Following User Says Thank You to steve99 For This Useful Post: | tracerit (09-02-2014) |
09-02-2014, 02:08 PM | #663 |
Drives: n/a
The OFT doesn't have specific tune files for all the various mods like the Unichip does. So you're not going to find a tune that specifically says "Perrin inlet hose and catback exhaust" like I'm sure you have from Unichip. I have a Unichip on my FJ, so I know they have different tune files for different brands of intakes, exhausts, etc. The OFT is more general, but is also much more customizable and tuneable than the Unichip. I like the OFT on my BRZ much more than my Unichip on my FJ.
The Following User Says Thank You to football751 For This Useful Post: | tracerit (09-02-2014) |
09-02-2014, 04:33 PM | #664 | |
Drives: Yes
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
09-02-2014, 04:55 PM | #665 | |
Drives: n/a
As to your question, you may be able to try Stage 2 91 if you have 93 octane in your area. The less-aggressive 91 tune with 93 octane may work out. Other than that is Stage 2 doesn't feel right you may have to work with Shiv to design a Stage 1.5 tune for you, as you could probably get more performance than Stage 1 is giving you. |
09-02-2014, 05:04 PM | #666 | |
Drives: Yes
Unfortunately, I'm in Cali so only have 91 available
09-02-2014, 06:30 PM | #667 | |
Drives: 2014 WRB Bravo Romeo Zulu
Is there a major difference in regards to power with the stage 1 93 vs stage 1 91?
EDIT: Found answer by googling in an older thread Quote:
09-02-2014, 09:52 PM | #668 | |
09-04-2014, 09:12 PM | #669 | |
Drives: White 2014 BRZ
Looks too rich but that's how the tunes are. Mine is the same way. |
The Following User Says Thank You to stevo585 For This Useful Post: | Fleischwagen (09-04-2014) |
09-04-2014, 09:15 PM | #670 |
Better to be rich than lean… hah the car feels amazing, tonsssss of power after I did the header/stage 2 tune. Car feels completely different, in the best way possible!
09-04-2014, 09:29 PM | #671 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I need to order one of these tablets. I have a catless uel header and k&n filter and everyone says how insane the stage 2 uel tune is...ahh trying not to spend any more money on mods this year. Somebody talk me in to it lol.
09-04-2014, 09:41 PM | #672 | |
Drives: 2013 FRS
Did that help? Cheers, shiv |
Similar Threads | ||||
OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
