03-23-2013, 10:28 AM | #617 |
Drives: Raven MT Scion FR-S
are the lights listed here for the outback black housing or is it just the forester thats black?
http://www.subarupartsforyou.com/cp_...p?partid=19073 |
03-23-2013, 10:48 AM | #618 |
First86 & burning gas!!
Drives: Asphalt 2013 Scion FR-S
Here is a discount code for Subaru parts good until March 28. The email I received from them states it is good for up to a 35% discount off msrp. Maybe it can help someone.
http://estore.subarupartswarehouse.c...&siteid=217823
The Following 3 Users Say Thank You to terrypm For This Useful Post: |
03-23-2013, 11:22 AM | #619 | |
Those are the fog lights I ordered and they are black. I believe someone else ordered the JDM Toyota 86 fog lights and they had chrome surroundings.
03-23-2013, 11:24 AM | #620 |
Drives: 2023 WRB BRZ (MT)
correct, but be prpared to pay 3x per fog. i found em from 140-150, so unless your a baller i'd b happy with black realistically because that is absurd
03-24-2013, 04:18 AM | #621 |
SoCal86
Drives: '13 Whiteout FR-S
So nice!
Thanks! Just did this DIY it so helpful! I used the Nigel harness and tapped into the side marker leaving the button and other wires on the passenger side of the inside bumper. I covered it up with eclectrical tape so no issues during the rain. Thanks again and good luck!
.: SUPER KAWAII :. .: BUBSQUAD :. .: LivinLow :. .: FRS86 :. |
03-24-2013, 01:39 PM | #622 |
Seems Legit
Drives: Toyota
Installed:
No knock on Nigel, in fact I considered his harness, but I didn't like the construction or the cheesy fog light switch that's larger than the other switches. I suppose you can call me a perfectionist. So I opted to go with TRS relay harness. It's plug and play for ballasts but not halogen. I cut off the ballast ends and soldered on H11 pig tails. It uses a 2 relay design such that each lamp is powered from it's own relay. It also incorporates a light on each relay so if one were to fail, you only need look at the relay and replace it. As for a signal, I tapped into the passenger side marker so the lights only come on with light switch in the parking light position and headlight position. While I was at it, I removed the DRL junction box. There is no designated top or bottom to the fog lamps. So I designated the lamp such that the writing on the lamp was right-side-up. I modified the fog lamp housing fit flush and remove all gaps. Maybe someone has the gypsie magic to fitting flush without modification but I couldn't. I know some wouldn't feel comfortable modifying brand new lamps they paid $100 for but oh well, it worked. Onto the pics... Passenger side Drivers side Fogs off Fogs on Double relays (right headlights) (left fogs) Relay with fogs on Headlights & Fogs on Relay with fogs & headlights on |
The Following User Says Thank You to ecko04 For This Useful Post: | jbsali (03-25-2013) |
03-24-2013, 03:41 PM | #623 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Ecko assuming you dremeled down the diameter of the house? Or the inner portion of the lamp? More details please... I have no problem modifying brand new parts lol
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
03-25-2013, 03:34 PM | #624 |
Drives: scion frs firestorm
Dont want to go with HID's for the fogs. Looking for some white LED's. Would this fit the Outback fogs?[ame="http://www.amazon.com/AnzoUSA-809008-Super-White-Bulb/dp/B004037IL2/ref=sr_1_28?s=automotive&ie=UTF8&qid=1364239462&sr =1-28&keywords=h11+bulb+white+55w"]http://www.amazon.com/AnzoUSA-809008-Super-White-Bulb/dp/B004037IL2/ref=sr_1_28?s=automotive&ie=UTF8&qid=1364239462&sr =1-28&keywords=h11+bulb+white+55w[/ame]
-Alan
03-25-2013, 03:41 PM | #625 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
Get Nokya bulbs
03-25-2013, 03:54 PM | #626 |
I wanted those but the white Nokya's have a blue housing. I dont think blue will look right on the fog light when off
-Alan
03-25-2013, 04:04 PM | #627 |
Professional Smartass
Drives: White Out FRS
Why don't you guys just buy H9 bulbs and harnesses? I'm growing more impatient with my order as the weeks add up.
03-25-2013, 04:08 PM | #628 |
Seems Legit
Drives: Toyota
Something about white or blue fogs just seems so wrong.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
03-25-2013, 08:08 PM | #629 |
Drives: Raven FR-S
my switch broke easily... probably just gonna find a different one. once you push it to turn on, it wont push again to turn off. you have to pull it. and the harness also isnt long enough either, im doing my best to stretch the wire and it might barely fit
03-26-2013, 09:43 PM | #630 |
Similar Threads | ||||
FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 08:38 PM |
FINALLY - Got my FR-S | SkitterSkotter | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 08-03-2012 05:16 PM |
FINALLY GOT IT! | Ayaz2589 | NY / NJ / CT / PA | 8 | 07-28-2012 02:52 AM |
Finally got it!! | percyng | CANADA | 21 | 06-17-2012 01:50 AM |
Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) -- General Topics | 1 | 06-16-2012 07:29 PM |
