07-10-2019, 01:55 AM | #589 |
Drives: 2019 BRZ / E36 325is
ADVAN RACING TC3 18x9.5 +45 square setup 255/35/18 firehawks
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu |
07-30-2019, 04:33 AM | #590 |
Drives: 2017 BRZ
AC Wheels Syclone Bronze 8x18" ET+38 (Running Dunlop Sport Maxx RT2 235/40)
Notes : Car is lowered 1" Tires are a bit to high, should probably be 35 instead of 40.
// Pierre Broberg
2017 Subaru BRZ, Christal White Pearl |
07-30-2019, 12:53 PM | #591 |
Drives: 2019 Toyota 86 TRD SE
Actually I really like your setup. For me, the tires are just right. How's the ride quality?
07-30-2019, 12:58 PM | #592 | |
Drives: 2017 BRZ
The Ride quality is pretty much the same as stock, it's feels a bit heavier due to the 18" wheels, it has a lot more grip than the stock "plastic" wheels!
// Pierre Broberg
The Following User Says Thank You to broberg For This Useful Post: | Drifter X (07-30-2019) |
07-30-2019, 03:07 PM | #593 |
07-30-2019, 03:08 PM | #594 |
07-30-2019, 03:32 PM | #595 |
Drives: 2017 BRZ
Stock dampers with Eibach Pro springs.
// Pierre Broberg
07-30-2019, 03:42 PM | #596 | |
Country Boy 4 Life
I think your car looks great! IIRC, there is only one 235/35/18 street tire, so that's not really possible. If your tires are too tall for you, then next time get 225/40/18. They are a very common size (which makes them cheaper usually too) on tirerack with 141 tires to choose from.
I LIKE TIRES! |
07-30-2019, 04:42 PM | #597 | |
Whiteline RLCA Whiteline Diff Inserts Whiteline Subframe Inserts
The Following User Says Thank You to ayoshioka1 For This Useful Post: | Drifter X (07-30-2019) |
07-30-2019, 06:08 PM | #598 |
The Following User Says Thank You to Drifter X For This Useful Post: | ayoshioka1 (07-30-2019) |
08-02-2019, 02:13 PM | #599 |
Drives: 2013 BRZ Sport-Tech
Don't know if the original posts are getting updated at all but here's another couple pictures for Super Advan Racing (SAR) v2.
17x8, et IIRC is 35 Tires: 215/40/R17 (too small) Stock suspension Also have a poor picture of Konig Ultraforms 17x9, et 35 front, et 40 rear (5mm spacers front) 255/35/R17 tires stock suspension +alignment goodies for -3* camber front and -2.2* rear |
08-07-2019, 10:38 AM | #600 |
Drives: 2019 BRZ Sport-Tech RS
I don't see the OEM BRZ performance pack wheel on the top post so I weighed mine since I had no tires mounted.
20.8 LBS, 17x7.5" +48 |
The Following User Says Thank You to N_Raged For This Useful Post: | phm14 (04-18-2020) |
08-17-2019, 05:14 PM | #601 |
Drives: Red 86
I need your help guys.
I just got 17×9 +38 wheels and was wondering if I could fit 255/40 on them, I will be installing the Eibach pro kit lowering springs 1inch with some front camber bolts. I know that the 245/40 will fit easily but was wondering if the 255/40 would fit. Thanks. Sent from my SM-G975F using Tapatalk |
08-17-2019, 05:35 PM | #602 | |
Drives: 2022 GR86
-> https://www.ft86club.com/forums/showthread.php?t=44927 You may also find a lot of useful info in the "meaty tire thread". |
The Following User Says Thank You to timurrrr For This Useful Post: | Glitchy86 (08-17-2019) |
Tags |
brz aftermarket wheels, brz wheels, fr-s aftermarket wheels, frs aftermarket wheels, scion fr-s wheels, scion frs wheels, subaru brz wheels |
Similar Threads | ||||
BRZ/FR-S Wheel Fitment Photo Topic | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-12-2012 04:16 AM |
BRZ/FR-S/86 Wheel Fitment Simulators | JDMSushi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-05-2012 10:49 PM |
Stock Suspension and Wheel Fitment | bneale | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 06-29-2012 07:42 PM |
Wheel size and fitment | bsclywilly | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 03-27-2012 12:34 PM |
Wheel fitment | sfwg | BRZ First-Gen (2012+) -- General Topics | 6 | 10-28-2011 06:33 PM |
