01-06-2014, 12:41 PM | #561 |
Drives: FRS
I got one of theses types. I found a 70mm version off ebay which should fit inside the intake tube right in front of the MAF.
http://www.treadstoneperformance.com...t.phtml?p=2096 I also got one of these. http://www.jscspeed.com/catalog/AEM_...d3-5016-1.html |
01-06-2014, 03:06 PM | #562 | |
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
01-06-2014, 03:59 PM | #563 |
Drives: FRS
Indeed.... I figured you could help with the MAF scaling. Are you interested? Assuming I can make them fit in my box before I send them to you? Would be an interesting experiment..... And it could result in the best intake for the platform....
01-06-2014, 04:14 PM | #564 |
I can help with maf scaling. If you have ecutek... I can help you remotely using your vehicle as well.
01-06-2014, 04:17 PM | #565 |
Drives: 2013 MT Asphalt FRS
Innovate Twin Screw Supercharger seems to be the only FI setup that MIGHT fit along with the trd intake. Can anyone confirm this? Looking into FI later down the road.
01-06-2014, 04:33 PM | #566 |
the TRD intake has a rear facing throttle tube, while the OEM has a passenger facing throttle tube that has a bend in it. So the intake wont bolt up.
01-06-2014, 04:36 PM | #567 | |
I am tired of bad info on intakes, tunes, etc! Things like this should be out in the open! I had multiple tuners tell me intakes were "bad" in the past but never explained why until I was able to start just logging cars my self and messing with them.
01-06-2014, 10:52 PM | #568 |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
How the heck did you come to this conclusion? Outlets are in entirely different places and are perpendicular to each other.
01-06-2014, 11:06 PM | #569 | |
Drives: FRS
01-07-2014, 12:38 AM | #570 |
01-07-2014, 12:01 PM | #571 |
Drives: 2013 WRB BRZ Sport Tech
i also have this trd cai, i actually sold woot his, ill be following this very closely, maybe i can pick up a air straightener as well to help out. let me know.
01-08-2014, 01:25 AM | #572 |
Well we made some tuning progress... At least log wise. Still have to hit the dyno to see if it actually helps. AFR's are more stable. I still have a few holes in my map, and need to do some general smoothing. This was done with speed density tuning instead of maf. We just completely ignored the MAF sensor. Mind you this log is far more detailed than the other ones i posted. the spots @ 3,600 & 5,000 will be smoothed out soon. We will then need to re-apply some cam changes and re-tweak (SD tuning takes a lot more work than MAF).
Custom map L is a wideband sensor.
01-22-2014, 01:36 PM | #574 | |
Hail Magnet
http://www.ft86club.com/forums/showthread.php?t=56141 |
The Following User Says Thank You to HunterGreene For This Useful Post: | DAN_BRZ (01-22-2014) |
Similar Threads | ||||
cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 08:06 PM |
HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 01:31 PM |
