Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
View Poll Results: Have you had an issue with your Direct Injection System? | |||
I have had a DI issue and was fixed under warranty (Subaru) | 10 | 12.35% | |
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) | 2 | 2.47% | |
I have had a DI issue and was fixed under warranty (Toyota) | 31 | 38.27% | |
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) | 3 | 3.70% | |
I have had a DI issue and denied warranty by (Subaru) | 7 | 8.64% | |
I have had a DI issue and denied warranty by (Toyota) | 14 | 17.28% | |
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) | 8 | 9.88% | |
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) | 6 | 7.41% | |
Voters: 81. You may not vote on this poll |
01-04-2017, 03:24 PM | #547 | ||
Drives: 2013 BRZ Premium
01-04-2017, 03:46 PM | #548 | |
Drives: 13 SWP BRZ Prem
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
The Following User Says Thank You to Imrac For This Useful Post: | Tcoat (01-04-2017) |
01-04-2017, 03:49 PM | #549 |
OK for summer. Not such a great idea when in defrost mode in the winter. Unless ice racing of course.
The Following User Says Thank You to Tcoat For This Useful Post: | Imrac (01-04-2017) |
01-04-2017, 04:13 PM | #550 | |
Oh right, Canadian internet sucks more than US internet, no working from home for you guys |
The Following User Says Thank You to strat61caster For This Useful Post: | funwheeldrive (01-12-2017) |
01-04-2017, 05:03 PM | #551 |
Be really hard for me to work from home. Besides I don't want to stay in the house 5 months of the year!
01-04-2017, 08:01 PM | #552 | |
Drives: Toyota 86 GTS
On throttle knock while IAM > 0 is admittedly close to, but still within safe working limits. |
01-04-2017, 08:35 PM | #553 | |
yep if the iam is above 0 then the ecu still has some room to control knock correction magnitude apparently even if the iam is =0 the flkc can still retard timing up to the flkc limit set in tables about -5 I think id be worried about the size and consistency of the knock corrections. at least when you have iam active (above 0 ) the ecu can reduce the magnitude of the corrections although at 0.2 its got very limited scope to do so so any flkc corrections wont reduce in size if iam is 0 or close to 0, you just keep getting the knock then the correction, without any magnitude reduction. yep for sure knock at high rpm/load/cylinder pressures much more dangerous. I think that why the south Africans has so much problems with DI seals early on. High temps, no transient retard on early roms, crap fuel (95 ron best they get) alreay very low IAM so they got consistent large knock correction that could not be significantly reduced by IAM. |
01-12-2017, 06:12 PM | #554 | |
The Following User Says Thank You to MagicMexican For This Useful Post: | steve99 (01-12-2017) |
Tags |
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
Similar Threads | ||||
Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 06:33 PM |
Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 12:35 PM |
Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 06:54 AM |
Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 08:32 PM |
Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) -- General Topics | 9 | 01-30-2012 12:25 PM |
