Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
03-31-2015, 08:42 PM | #43 |
I am on a quest for it! Could be buried in a build thread but I will eventually prevail. (Ahhh the curse of reading too many threads.)
The Following User Says Thank You to Tcoat For This Useful Post: | why? (06-12-2019) |
03-31-2015, 08:59 PM | #44 |
Drives: 2015 Subaru WRX
The Following User Says Thank You to iamdaspoon For This Useful Post: | Kids Heart (03-31-2015) |
04-01-2015, 09:01 AM | #45 | |
Drives: 2015 Aozora BRZ
Hurry up @Tcoat I wanna be like james bond too |
The Following User Says Thank You to BlueSky For This Useful Post: | Tcoat (04-01-2015) |
04-01-2015, 09:22 AM | #46 | |
Would have been easy if it was a topic of it's own but it has to be in the middle of something else.
04-01-2015, 09:44 AM | #47 |
04-01-2015, 09:47 AM | #48 |
04-01-2015, 11:19 PM | #49 |
Drives: 2013 Black Brz Premium 6sp
to add lock to brz glove box you need to swap handles with a 2008-2011 impreza black glove box, split open the glove box and remove the handles by removing 2 screws and be careful removing the striker arms from the bracket guides. to remove the striker arms you need to push in and twist until they pop out. then swap the handle with the original glove box. you will need to take lock cylinder to a locksmith to get a key made if one isnt available. you use the original striker arms with the lock handle. good luck!
04-02-2015, 04:04 AM | #50 |
Shoegazer
Drives: 2015 WRB BRZ Series.Blue
subbed
04-02-2015, 01:51 PM | #51 | |
Drives: 2013 BRZ Limited SWP
04-05-2015, 03:38 AM | #52 |
i ran into a problem separating the striker arms from the handle bracket, the striker arms have a spring that allow them to recess so the glove box will open and close. i need to figure out how to get them apart so i can replace the bracket. the striker arm has two pieces the long arm and the spring head that attaches to the bracket. i need to separate the spring head from the arm so i can swap the handle bracket, once this is done adding the lock will be completed. i will post a completed glove box picture when this is done.
11-14-2015, 07:10 PM | #53 |
Drives: Toyota Highlander; Subaru BRZ (SWP)
This seems to be the most developed discussion about modding a lock for the glove box. So only a 2008-2011 Impreza glove box handle will work?
@tim35ct where are the pics, man? |
11-24-2015, 12:04 PM | #54 | |
Drives: 2013 FR-S 6MT Whiteout
And sometimes you may want to lock that up in the presence of curious children. Also useful as a deterrent to thieves. Most will not take the time to break open a locked glovebox once they realize the car is a MT and they can't drive it anyway. |
11-24-2015, 12:48 PM | #55 | |
Drives: car
11-25-2015, 09:27 AM | #56 | |
It can be any private property that the police (especially ones involved in all these non-constitutional traffic stops lately) have no business seeing or messing with. |
Tags |
brz, glove box, lock, replacement |
Similar Threads | ||||
CG Lock Seat Belt Lock | Biggins | Interior Parts (Incl. Lighting) | 0 | 02-03-2014 08:41 AM |
glove box 12v light? | lbroskee | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 03-11-2013 10:44 PM |
Loose Glove Box | Spd229 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-06-2012 01:53 PM |
Scratched Glove Box! | greenguy101 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 07-29-2012 06:24 PM |
Canadian BRZs with USB+3.5mm in glove box | rawbz | CANADA | 12 | 07-11-2012 03:51 PM |
