Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-29-2023, 09:54 PM | #43 | |
chicken tonight
That is pure fucking poetry. Bravo.
The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (10-30-2023) |
10-30-2023, 09:00 AM | #44 |
Drives: 2013 frs base
The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (10-30-2023) |
10-30-2023, 07:39 PM | #45 | |
Drives: Toyota 86
This figure from Tune to win, Carroll Smith.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ |
The Following User Says Thank You to makinen For This Useful Post: | blsfrs (10-30-2023) |
10-31-2023, 07:10 AM | #46 |
Drives: Toyota GT86
as if anyone understands that picture :P Love the use of pop rivets on your shroud!!
Looking forward to hearing the results
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
The Following User Says Thank You to autoracer86 For This Useful Post: | blsfrs (10-31-2023) |
10-31-2023, 01:09 PM | #47 | ||
Drives: '23 BRZ Limited
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | blsfrs (11-01-2023) |
11-14-2023, 08:43 AM | #48 |
Update on shroud: It didn't work as well as I hoped. In the afternoon with ambient temps in the low 60's, I still saw oil temps in the 240* range.
At redline, my oil pressure was in the 50's. Since my last event I switched from Mobil 1 1030 to Motul 8100 5w40. I think the gap between the cooler and condenser may be causing a problem with the flow of air through the cooler even with my beautiful shroud. So, over the winter I'll remount the cooler so it backs up the the condenser with a 1/4" gap and reshroud it for good measure. Despite somebody's "brilliant" suggestion, the dang foam piece behind the bumper did not seem to make any difference. |
The Following 5 Users Say Thank You to blsfrs For This Useful Post: | autoracer86 (11-15-2023), NoHaveMSG (11-15-2023), Teseo (11-17-2023), Ultramaroon (11-14-2023), x808drifter (11-15-2023) |
11-14-2023, 12:55 PM | #49 |
chicken tonight
Well, shit.
The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (11-15-2023) |
11-15-2023, 08:03 AM | #50 |
Drives: Toyota GT86
yeah that kinda sucks to hear. Sorry
The Following User Says Thank You to autoracer86 For This Useful Post: | blsfrs (11-15-2023) |
11-15-2023, 09:19 AM | #51 |
Drives: '23 BRZ
11-15-2023, 12:41 PM | #52 | |
I'd like to know if the oil flow could actually increase when the oil is hot and therefore at a lower viscosity. But then, what is the cutoff point of high temp vs low pressure? When does it become detrimental? |
The Following User Says Thank You to blsfrs For This Useful Post: | autoracer86 (11-16-2023) |
11-15-2023, 01:17 PM | #53 |
Dismember
Drives: 2013 Red Scion FR-S
The oil cooler gave me peace of mind on 100+ degree days at the track.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post: |
11-15-2023, 01:42 PM | #54 |
Drives: 2013 BRZ HKS Turbo
I'm with Zdan, why do you believe 50psi at redline and 240 oil temps are a problem to be solved?
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
11-15-2023, 02:53 PM | #55 | |
So @ZDan and @terboboost, what does your pressure run at 260*? And what is your cut off point for pressure and temp? I've read where syn oil doesn't break down like dino oil does but it does thin out at high temperatures. What minimum pressure are you guys comfortable with at redline? 30-35 psi? |
11-15-2023, 07:03 PM | #56 | |||
Drives: '23 BRZ
Tags |
haha |
Similar Threads | ||||
Full Race external oil cooler kit | duqx | Engine, Exhaust, Bolt-Ons | 1 | 01-20-2019 08:41 PM |
External mic placement | Shark_Bait88 | Tracking / Autocross / HPDE / Drifting | 22 | 06-13-2016 06:39 PM |
Anyone have info on the BRZ OEM external oil cooler (Japan only)? | mav1178 | Engine, Exhaust, Transmission | 5 | 04-22-2016 12:20 AM |
External Wastegate Question | TurboBRZ | Forced Induction | 23 | 07-22-2015 12:38 PM |
