07-21-2022, 02:04 PM | #43 |
I doubt an oil analysis would have any meaningful indication. A new engine is going to show high on silicon whether it is where it belongs or in the filter. Not like it is getting chopped up into small particles so there really wouldn’t be anything unexpected to catch.
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (07-21-2022) |
07-21-2022, 02:25 PM | #44 | |
Drives: '22 BRZ
It's an assembly issue, IMO. Design seems fine.
The Following 5 Users Say Thank You to DocWalt For This Useful Post: | Blighty (07-21-2022), DylanJZA (07-22-2022), OkieSnuffBox (07-26-2022), Tcoat (07-21-2022), Ultramaroon (07-21-2022) |
07-21-2022, 02:29 PM | #45 |
chicken tonight
Devil's in the deets
07-21-2022, 02:38 PM | #46 |
Assembly and QC. Though not sure how they could actually inspect it.
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (07-21-2022) |
07-21-2022, 02:42 PM | #47 | |
Drives: '22 BRZ
Sure, still not a design issue though. Whoever calibrated the sealant gun and checked off on it failed at their jobs. Quote:
No good way to inspect it, just use an appropriate quantity of sealant.
The Following User Says Thank You to DocWalt For This Useful Post: | Tcoat (07-21-2022) |
07-21-2022, 03:16 PM | #48 |
And in the right place.
The Following User Says Thank You to Tcoat For This Useful Post: | DocWalt (07-21-2022) |
07-21-2022, 03:22 PM | #49 |
Drives: 2022 BRZ sport-tech
Actually, would an oil pressure gauge give you early warnings signs?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
The Following User Says Thank You to Petah78 For This Useful Post: | mswbrz (07-28-2022) |
07-21-2022, 03:35 PM | #50 | |
Drives: GR86
But if it's one big chunk that wasn't a problem and then is, you'll see the needle bottom out and then, rapidly, the engine puke. Borescope up the drain plug could do it. I have one so I'm thinking about doing that next oil change. |
07-21-2022, 04:05 PM | #51 |
Drives: 2022 GR86
anyone who has this happen should share their build date and engine serial number
07-21-2022, 04:34 PM | #52 |
chicken tonight
Those are the deets I meant. Please excuse my lazily expressed agreement.
The Following User Says Thank You to Ultramaroon For This Useful Post: | DocWalt (07-21-2022) |
07-21-2022, 05:08 PM | #53 |
Drives: 2015 FR-S
Are you able to borescope up the Pickup neck? or can it not make a twist at a sharp enough angle?
we all know that RTV degrades with thermal cycling and gets harder with age + thermal cycling (-25C to 70C) so it would make sense that cars that went through the first winter in Japan or US and were driven everyday might see more of this excess RTV fall off in the pan. NVH of a sportscar will help shake it off. Last edited by FrickingReallySlow; 07-21-2022 at 05:19 PM. |
07-21-2022, 07:21 PM | #54 | |
07-21-2022, 08:22 PM | #55 |
They have not told me the actual reason yet.
The day that I dropped it off, they did some kind of ECU check and said that the car had been ridden hard, many rev limit instances and also an overrev event at 7900 rpm 2000 miles before the engine failure. The dealer told me that Toyota will fix it this time under warranty, but will not the second time under similar circumstances. Basically telling me that I caused the failure with the overrev. This was all before they even removed the engine from the car. The fact that they ordered a short block and will re-use the heads is pretty telling that the overrev had nothing to do with it. |
The Following 9 Users Say Thank You to toeout For This Useful Post: | Ash_89 (07-22-2022), Blighty (07-21-2022), gcmak (07-21-2022), Petah78 (07-21-2022), RedReplicant (07-26-2022), Samba86 (07-23-2022), Stephen W. (07-22-2022), Tcoat (07-21-2022), timurrrr (07-22-2022) |
07-21-2022, 08:37 PM | #56 | |
So at this point it is not confirmed yours is sealant related even though it is high (lily top) on the list of probabilities. Just hope that if they find any they are honest about it. Ordering a short block and reusing heads in not a great indicator it wasn't over rev. Could easily do bottom end damage and not touch the heads.
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
