Old 02-07-2021, 12:56 PM   #43
Anthonyc777
Drives: White Toyota 86
Has anyone else tried the Pennzoil sychromesh besides rice_classic? Any reviews? Not that I dont trust them but I like the to have a sample size of more than just one, and when I google/search it shows posts from them from 2012 running the same fluid, so I guess thats a good thing XD.
Anthonyc777 is offline   Reply With Quote
Old 02-20-2021, 01:22 AM   #44
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Another for Redline. I had issues upshifting from first into second gear and downshifting from fifth into fourth gear. Ever since I switched to redline, I have had zero issues.
scion fr-s is offline   Reply With Quote
Old 02-23-2021, 12:39 AM   #45
wil5bart
Drives: '16 BRZ
Redline or Motul, which ever is available or on sale.
wil5bart is offline   Reply With Quote
The Following User Says Thank You to wil5bart For This Useful Post:
jeepmor (03-02-2021)
Old 05-05-2021, 10:15 PM   #46
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I switched to the CounterSpace garage secret sauce 50:50 mix.
Old 05-06-2021, 03:19 PM   #47
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Is that the redline 50:50?
Was literally just looking for it on CSG. I think motul is too much for the PNW weather. It takes forever to heat up
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 05-06-2021, 06:10 PM   #48
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Yes.
The Following User Says Thank You to scion fr-s For This Useful Post:
BrahmaBull1990 (05-06-2021)
Old 05-06-2021, 08:56 PM   #49
T-Steve
Drives: 2014 BRZ
This reminds me: I put Redline MT-90 in my '14 about four years ago.
It initially had a bit of grind when going into second cold but was fine warmed up. Now (after four years) it seems to be perfecto in all weather.
It only took four years.
T-Steve is offline   Reply With Quote
Old 05-06-2021, 10:17 PM   #50
ermax
ermax's Avatar
I just switched to it and so far I’m impressed. It’s available locally for $9/qt. It’s less notchy than before the swap and if I recall it’s the smoothest it’s ever been.
Old 05-06-2021, 11:43 PM   #51
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I had your same problem except with the OEM fluid. Once I switched to Redline, I had no issues. Glad you fixed your problem.
Old 05-08-2021, 12:28 AM   #52
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Another vote for Redline. Changed to it from factory oil and it made the transmission feel buttery smooth. I stopped using their engine oil because it is so expensive and I prefer to change at least twice a year, but trans and diff oil is worth it.
Plumbus is offline   Reply With Quote
Old 05-08-2021, 05:21 AM   #53
ermax
ermax's Avatar
In reality just about anything is better than the OEM fluid.
Old 11-10-2021, 03:04 PM   #54
Jonboy73
Jonboy73's Avatar
Drives: Toyota GT86 GTS
Looking at changing mine over to Redline in the new year, so would the following be correct:
Redline MT-90 75W90 GL4 for Gearbox and Redline 75W85 GL5 for Diff.
Car is a 2014 GT86
Thanks in advance.
Jonboy73 is offline   Reply With Quote
Old 11-10-2021, 03:51 PM   #55
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
GEARBOX (GL-4) 75w80
DIFF (GL-5) 75w90 NON-LIMITED SLIP
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 11-23-2021, 12:08 PM   #56
misterfly
Drives: Toyota 86 2017
Im seraching the best one in 75-85 for the diff , for the trans i will take motul but motul dont do 75w-85 , what guy use in 2017 + ?
misterfly is offline   Reply With Quote
differential, fluids, maintenance, oil, transmission fluid
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG jfg5067 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 01-18-2016 09:24 AM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 11:52 AM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 08:02 AM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 09:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
