Old 08-18-2017, 02:59 PM   #43
stevesnj
stevesnj's Avatar
Take it to the dear, say it failed. lol I'd love to hear what they say.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
TEWwild (08-18-2017)
Old 08-18-2017, 03:49 PM   #44
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
If you managed to cut it before the journal got mangled too badly you may very well be able to save it.
Just spit balling here and I didn't go back and read your write up to see what parts from what engine you actually used but you did mention that the new engine was from a car with fire damage. Is it possible that some of the parts of the new engine suffered heat damage? Unlike heat from when the engine is running a fire can create very isolated hot spots which could cause damage that isn't obvious with an examination. Such hot spots could explain the mystery "weld splatter" material you found in the valve seats. This could be way off base for your current issue but thought it was worth mentioning since other things could fail down the road.
The fire damage didn't look that bad, no melting of any of the aluminum ears etc... My thoughts on the internals is they should be pretty much protected by the oil and coolant inside the motor at the time....
TEWwild is offline   Reply With Quote
The Following User Says Thank You to TEWwild For This Useful Post:
Tcoat (08-18-2017)
Old 08-18-2017, 03:54 PM   #45
TEWwild
TEWwild's Avatar
Unless you just get a kick out of rebuilding that engine, I suggest you take the crank into a machine shop and have them resurface that journal. If, after they clean it up, it measures to within specs, you should be good to go.
humfrz
While it has been fun, it is starting to wear on me (and the wife) a bit.
I actually just got back from returning the truck and trailer to the track. I happened to take the 2015 crank with me for their opinions as well, they sent me to a machine shop to have it checked....Unfortunately that one is too far gone, still need to break her the rest of the way apart to get the other one checked.
The Following 3 Users Say Thank You to TEWwild For This Useful Post:
humfrz (08-18-2017), stevesnj (08-18-2017), Tcoat (08-18-2017)
Old 08-18-2017, 04:14 PM   #46
TEWwild
TEWwild's Avatar
I assume you mean dealer, and no, I don't have time for that kind of run-around.
As much as I have abused the car, I would not expect coverage anyway, which is why I didn't go there in the first place....
That reminds me though, I did inquire on the cost of a motor for the fun of it, complete engine, $23k. Long block; $16k....
AC compressor pulley not spinning when dis-engaged? Lynxis Issues | Warranty | Recalls / TSB 7 05-03-2017 04:16 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
pulley not spinning and then spins loud noise Composite Engine, Exhaust, Transmission 19 12-11-2014 07:09 AM
Spinning at Buttonwillow (1CW) ddeflyer Tracking / Autocross / HPDE / Drifting 76 05-22-2014 08:24 PM
Wheel choices got my head spinning!! Trmx2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 11-25-2013 09:34 AM
