08-29-2012, 09:42 AM | #491 | |
I think that as far as ST/SP autocross goes nowadays, the common thought is, "well, if a little bit is good, more must be better!" So people end up with cars with crazy alignments, 1000lb spring rates, and $4500+ shocks with a billion adjustments. As someone who has chased their tail and spent a lot of money on these exact things before, I really learned the hard way that most of it is not only unnecessary, but actually ends up making the car slower, too. In fact, unless you're a race engineer with all the equipment needed (think shock potentiometers) and a ton of data, you will rarely find much improvement from Motons/JRZs/Ohlins/etc. over something like a basic Koni (or in this case, KWs) - and that's if you're a good enough/consistent enough driver to find that limit in the first place. I know I'm not! Sam's setup does not fall into this category - in fact, it's deceptively simple and works extremely well. I never felt like it needed to be stiffer, or that the spring rates needed to be changed, or that the shocks needed revalving, or anything like that. And a lot of people (including myself, if I looked at this a few years ago) would argue that his setup is "too conservative". It's not. The balance is very good, it's easy to drive fast, and at least for me, suits my driving style very well. Sure, you could throw more spring at it, or change the valving, but doing that would be a roll of the dice at best. Anyone looking to swap the suspension on these cars would be doing themselves a favor by talking to Sam first, regardless of it being for autocross, track, or otherwise.
The Following 2 Users Say Thank You to apexaddict For This Useful Post: | iLuveKetchup (08-29-2012), Scooby South (08-29-2012) |
09-21-2012, 05:41 PM | #492 |
Conedancer
Drives: 2013 Subaru BRZ SWP
And....Officially STX...wahoooooooooooo Last event this weekend in Milwaukee.. we'll see how it does with no PRO index this time... Straight up STX.. No changes to the car from the Subaru challenge so it should be as good... its supposed to be cooler this weekend so we'll see how it does for grip. Having a great co-driver who can help set the car up has been instrumental in the success so far...Thanks Everybody
Bill
STX #68 Join my BRZ/FRS FB Group Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
10-01-2012, 12:23 AM | #493 |
Conedancer
from todays event... 4th on INDEX out of 140, 7th Raw time and 1st in class
The Following User Says Thank You to Scooby South For This Useful Post: | Jedi1 (10-07-2012) |
10-07-2012, 10:14 PM | #494 | |
Conedancer
Adding this from the KW AX thread..
Plans are to finish the suspension with: -LCA Bushings -possible brake upgrade -Engine and Tranny mounts -Header -overpipe -catted midpipe with my trusty turn-down -Possible LW Seats -going to get tuned, but probably not until the spring to see what else develops.. Also going to wait on the diff as the Stock Torsion is working as Advertised.. Thanks to everybody for the support and following my build..I appreciate it. Bill
STX #68 Join my BRZ/FRS FB Group Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD Last edited by Scooby South; 10-07-2012 at 10:26 PM. |
10-08-2012, 10:55 PM | #495 |
Conedancer
Awesome action shot... full load, At Speed... not much roll there.....From my last Race of the year...4th on index out 150. I'll take it..
Enjoy
10-10-2012, 09:12 AM | #496 |
0 RWHP
Drives: 2008 Mazdaspeed 3
Congrats man, great work! I'm really keeping an eye on your build as the path for my car (at least suspension wise), so thanks for all your hard work and pioneering, best of luck to you!
10-10-2012, 10:39 AM | #497 |
Drives: 2013 HotLava FRS, 2005 Legacy
Hey congrats and thanks for sharing your experiences with the FR-S. I am hoping to hit up some of the local AutoX next year. And I have to say I am already a fan of the majority of the parts/people you are using on your car as well.
:happy0180:
HotLava FRS MT |
10-11-2012, 07:52 PM | #499 | |
Conedancer
http://www.ft86club.com/forums/showthread.php?p=363714
10-13-2012, 12:01 AM | #500 | |
Drives: 2022 BRZ
Simmons
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
10-13-2012, 09:02 AM | #501 |
Conedancer
Subaru Grp N mounts will work..
Bill
10-13-2012, 07:35 PM | #502 |
Drives: Toyota GT86
Bill i have been following your build so far and you really are in a very good path indeed!!!the good results are just the tip of the iceberg keep the thread alive and let us know how your spec list will get richer!
And remember seat time and practise will always be the best "modification" for good results |
The Following User Says Thank You to GMASTER6 For This Useful Post: | Scooby South (10-13-2012) |
10-14-2012, 12:04 AM | #503 |
Conedancer
thanks soo much..
here is a gallery from the Subaru Challenge that Andrew Pallotta co-drove.. Awesome time.. and the car did really well https://www.facebook.com/media/set/?...1&l=1b174ce89b Teaser...
STX #68 Join my BRZ/FRS FB Group Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD Last edited by Scooby South; 10-14-2012 at 12:15 AM. |
The Following User Says Thank You to Scooby South For This Useful Post: | Dimman (10-14-2012) |
10-15-2012, 01:56 PM | #504 |
Conedancer
So I made a wish list of my car and the approximate cost..I need to win the lottery..:/
Future STX mods • Front Four Pot BBK upgrade with 2 pc Rotors $2000 • Header $500 • Over-pipe $300 • Catted Mid-pipe $400 • Rear Sub-Frame Bushing $50 • Frt LCA Bushings $200 • Rear Control Arms $600 • Engine and Tranny mounts (inserts) $??? • Front Adj Sway Bar $200 • 1.5 way Rear LSD $2500 • Front Splitter $250 • Tune… $1000 • Light weight Seats $750ea with all this I expect to be around 2500lbs and have 200 Whp(Est) this is extra from what is already done: * KW Variant 3 Suspension * Front Camber Plates * 17x9 Wheels * Hankook 245/40/17 RS3's * Kartboy Rear Endlinks * Kartboy Rear Diff Bushings * DIY Intake w/K&N panel filter * Lightweight Battery * Muffler delete * Stainless Brake lines * Motul Fluid Change * additional Rear Bars as needed 16mm(WRX) 19mm (STi) * Various other Kartboy items.
Similar Threads | ||||
Subaru/Scion warranty and autocross | Ribface | Tracking / Autocross / HPDE / Drifting | 55 | 06-17-2015 08:30 PM |
Will you Autocross your 86? | Ribface | Tracking / Autocross / HPDE / Drifting | 131 | 06-22-2012 05:48 PM |
Which autocross class? | jpdarty7 | Tracking / Autocross / HPDE / Drifting | 66 | 06-21-2012 05:53 PM |
FR-S at a CA Autocross | oneday | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-26-2012 03:38 PM |
