05-23-2014, 09:40 AM | #477 |
05-23-2014, 09:50 AM | #478 |
It should be lower than bills mustang... I have never seen a dyno read this low. Stock cars run 125-135 typically around 130.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
05-23-2014, 03:07 PM | #479 |
Well, he stated a baseline of 130whp/113wtq.
That would mean the dyno reads at a rate of 35% loss. At the shown 281/223, that would translate to 432/343 at the crank, based on 130whp being 200hp crank. On a dynojet, that would be ~367whp (15% loss), or 354whp on a mustang (~18% loss). Approximately of course. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | *LongFella (05-23-2014), CxG (04-03-2018) |
05-23-2014, 03:17 PM | #480 | |
Drives: 2013 FR-S, 2004 Z06
05-24-2014, 01:37 PM | #481 |
Dw700 iniectors dw65c pump. I would have to check the logs to see how close this was to working in oem injectors. I did do a few pulls up to around 7200rpm on completely stock fuel system on e85 before but I don't remember if it was pushing the di time too far or not I would say it's probably on the edge of what i would push in the ever you get e90 and some very cold weather.
Then again if you were to drop the redline just a hair it might be a lot more within oem fuel capacity.
05-24-2014, 10:59 PM | #482 |
PhoneFlash by EcuTeK
Stock car reads around low to mid 130's on our mustang if I remember correctly. It's been a long time since we actually had a stock car on there. My car is back to stock for a short time for some NA parts testing so I'll get a base run if you guys care to see what a stock car makes on our mustang :P The Dyno Dynamics down at HG Motorsports we were using for awhile also reads mid 130's for a stock FR-S, BRZ. It's not uncommon for a Dyno Dynamics, Mustang, Maha, just a matter of whether you're running it in true heartbreaker mode or any sort of sim mode. We always prefer the lowest, truest reading and it looks like you do too @nelsmar
Sincerely, Zach Delicious Tuning |
05-27-2014, 01:16 AM | #483 |
Drives: Really slow
Would getting an aftermarket exhaust be a bad idea for the CARB tune kit? I'd like to add a distinctive exhaust note to my car along with other small benefits (weight savings, looks, etc)
The Following User Says Thank You to Cheeseballs For This Useful Post: | 4032pauln (05-27-2014) |
05-27-2014, 03:47 AM | #484 |
Drives: UM86 - 6MT
Would you guys say that the Jackson kit is superior to the other CARB legal FI options? I am in California, and I am heavily leaning toward the JR kit. Also, on the carb legal tune it is said there is a ~70 whp increase over stock.
What is the whp increase on a non-carb legal tune/map? What is the whp increase running E85? If I buy the kit straight up as it stands + an oil cooler, will I bet set? even if I want to periodically run E85 from time-to-time? Will whp numbers change with the oil cooler as well? |
05-27-2014, 04:17 AM | #485 | |
Sent from my SGH-I337M using Tapatalk |
The Following User Says Thank You to Raven604 For This Useful Post: | 1086 (05-27-2014) |
05-27-2014, 04:47 AM | #486 |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | *LongFella (05-27-2014), Cheeseballs (05-27-2014) |
05-27-2014, 04:49 AM | #487 | |
Yes, 70-75whp in full CARB trim is accurate, with zero other mods. On 91 octane? Rumor has it with supporting mods and a stock engine, you can extract plenty more With E85 and supporting mods, even higher. Get flex fuel You'll sustain the power with an oil cooler; I highly recommend it. While we're at it, I wouldn't be surprised to see 400whp+ with a built engine and the Jackson Racing kit. |
The Following 7 Users Say Thank You to CSG Mike For This Useful Post: | *LongFella (05-27-2014), 1086 (05-27-2014), Cheeseballs (05-27-2014), CxG (04-03-2018), sdlynx (05-27-2014), sklimo (05-27-2014), spitz (05-27-2014) |
05-27-2014, 12:59 PM | #488 |
Drives: '13 SWP BRZ-L
Installed my kit this weekend.
Ah-freaking-mazing. It's everything advertised and more. It is, in my opinion, now the perfect DD / Track weapon. Only small issue I had with the install, as previously stated by other owners, was bumper fitment. The pipes needed some man power to get into place, but this wasn't a big deal at all. Also, if Jackson Racing wanted to make this install completely brainless, they could create a installation guide with BOTH the oil cooler kit and SC kit steps combined. I had to flip back and forth between both kits, but just a suggestion more than a complaint. Install went very smooth.
The Following 4 Users Say Thank You to spitz For This Useful Post: |
05-27-2014, 02:19 PM | #489 |
Drives: 2013 white limited BRZ
With this kit, should I get the installer to install clamps on the vacuum lines as mentioned on some of the other threads?
05-27-2014, 02:21 PM | #490 |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
