05-20-2014, 10:30 PM | #463 | |
A dying engine will make all kinds of crazy noises, but a disconnected charge pipe after the MAF will make the car just not idle at all, and just stall. |
The Following User Says Thank You to CSG Mike For This Useful Post: | oc-drummer (05-20-2014) |
05-21-2014, 01:25 AM | #464 | |
Drives: 2015 Series.Blue
More likely to be trapped in the intercooler. |
05-21-2014, 03:15 AM | #465 |
Drives: 2013 Black FR-S
05-21-2014, 03:23 AM | #466 |
The Following 3 Users Say Thank You to sw20kosh For This Useful Post: |
05-21-2014, 11:55 AM | #467 |
Drives: Really slow
05-21-2014, 01:39 PM | #468 |
I figured I would share a local's kit that I helped tune this week since he isn't on the forum. I wasn't expecting such a large gain from E85! I plotted a stock car in comparison to show how low this dyno reads. Stock car made 130whp/113wtq. Nearly a 135% power gain over stock! There were gains all the way down even at 1,500RPM.
The car has agency power headers, overpipe, i believe catless front pipe, stock midpipe back to the rear of midipe and then twin exit muffler delete.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
05-21-2014, 05:20 PM | #469 | |
Do you happen to have a dyno comparing the REALLY low RPM ranges? I know it's not typical due to lugging, but it's nice to have |
The Following User Says Thank You to CSG Mike For This Useful Post: | *LongFella (05-21-2014) |
05-21-2014, 05:30 PM | #470 |
Driving Coach
Is anyone that's running E85/FlexFuel with this kit running out of injector capacity or fuel flow with the OEM fueling gear and E85? Is it ok to run without a higher flow pump in the tank and bigger injectors assuming the original 9psi pulley is used?
I thought that a new pump/injectors were needed or strongly recommended to run E85 with the C30-94. @moto-mike can you clarify?
05-21-2014, 06:06 PM | #471 |
Next time I am at my friends shop I can grab a plot. The dyno window started at 1,500RPM.
The Following User Says Thank You to nelsmar For This Useful Post: | CSG Mike (05-21-2014) |
05-21-2014, 09:08 PM | #472 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post: | ATL BRZ (05-21-2014), PikachuBRZ (01-20-2023) |
05-21-2014, 09:31 PM | #473 | |
Drives: 2014 Scion FR-S|Whiteout
So for us amateurs (me), running stock fuel pump and injectors is fine? If we want north of 300 hp, upgrade the pump and injectors? I'm really liking the numbers posted. Full exhaust set-up, E85, stock fuel pump and injectors... Great numbers! So glad I went with this kit!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
05-21-2014, 09:35 PM | #474 | |
Drives: Really slow
The Following User Says Thank You to Cheeseballs For This Useful Post: | *LongFella (05-21-2014) |
05-23-2014, 12:03 AM | #475 | |
05-23-2014, 02:11 AM | #476 |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
