#4201 | |
Drives: Raven FR-S 6M
They increased the belt to 30mm which help it last longer but tension is stil manually adjusted. Sent from my iPhone using Tapatalk Pro
“The World is Flat”
[||•]=(86)=[•||] |
The Following User Says Thank You to Apoc For This Useful Post: | nos145 (03-21-2019) |
#4202 |
Drives: Subaru BRZ
Am I the first one to try the kit on a 2017 Toyota 86 ? The piping that goes to the intercooler are interfering with the bumper. The intercooler would need to move back 1 inch and a quarter so the bumper could fit. Is there new bracket ? I have a kit that was sold in the first 30 !
#4203 |
Drives: rx8. frs.
Anyone tracking their car with this kit? Autocross, drifting, etc.
I started drifting my car last year, the first belt lasted a few events. I replaced the belt and this one only last about 1 1/2 events, with one event in the raining and this last event maybe about 25 laps total. It’s sad when my cheap tires last longer than a belt. Feel like this kit was more for street driven cars or show cars. |
#4204 | |
Drives: 2018 BRZ tS
#4205 |
Drives: rx8. frs.
Has anyone upgraded to the 30mm belt? If you have, how is it holding up?
#4206 |
Drives: rx8. frs.
#4207 |
Idk when, but Kraftwerks, revised the kit to come standard with the wider belt/pulleys. But I've read with the new wider belt, failure is no longer a concern.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#4208 |
Drives: rx8. frs.
Well, the first belt system wasn’t a concern until I started tracking the car, I wonder if anyone here has tracked their car with the new belt system.
#4209 | |
#4210 |
Drives: scion frs
I’ve bought a used kit and installed it but not getting boost. Anyone know what i can do to troubleshoot it?
#4211 |
Is everything connected and clamped. No leaks? Are you data logging? Seeing posts you had put up previously leads me to suspect you are in way over your head or are trolling. You have been installing this since Sept last year .
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 04-24-2019 at 10:15 PM. |
#4212 |
Drives: 1996 ST204, Series 10 FR-S
@Apoc
Since you are local to me, I may be able to help. Shoot me your # over PM and we can talk over text if you'd like. |
#4213 | |
“The World is Flat”
[||•]=(86)=[•||] |
#4214 |
Drives: gt86 FIRST edition #86
Does anyone own the basic software for the map of the 86 with volumetric? Or at least an example from which to adapt then the map to my car
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
