BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
04-20-2024, 03:35 PM | #29 |
Drives: BRZ 2023
ZDan, I am seriously considering ND3 since this thread. ND3 has new diff, steering rack and track mode. Steering improvement depending on who you ask are significant or negligible. Differential improvements are significant for track usage, mainly getting in to corner. No one has made video on track mode.
Did some digging on transmission issues as well, it's a grey area for me, worst case if it blows, I would put NC transmission in there with swap kit. Few things I still need to figure out, safety mainly, do I fit with a black bird roll bar and pass the broomstick test. |
04-24-2024, 09:48 AM | #30 | |
Drives: '22 BRZ
NC trans is *barely* stronger than the ND trans and costs as much or more to replace... and has worse gear ratios. Just buy a spare ND trans. Also, the differential improvements are great for a stock car. Not ideal once you start modding, it changes the setup a lot from ND1/2.
04-24-2024, 11:28 PM | #31 | |
Drives: BRZ 2023
Which mods are we talking about? Just coilovers and BBK would be an issue? |
04-25-2024, 10:52 AM | #32 | |
Drives: '22 BRZ
It's not that strong, people break NC transmissions regularly. It's marginally stronger than the ND trans while having a lot of disadvantages. Spring rates, bar rates, shock valving, etc. are all going to be tweaked based on how the diff behaves. It's why when people throw an untuned clutch type LSD into a twin it turns the car into an understeering mess. The OEM Torsen has very little lockup on decel and now there's decel locking and the car plows. Same issue will exist on the ND3 if the diff is truly as aggressive on decel as you're suggesting.
The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
Tags |
900brz, fa24, oil pressure |
Similar Threads | ||||
Ansix Auto FA24 BRZ/GR86 Accusump Oil Pressure Drop Testing Results | Ansix Auto | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 49 | 09-14-2023 08:35 PM |
Should an oil cooler cause oil pressure to drop? | blsfrs | Engine, Exhaust, Transmission | 6 | 07-30-2023 09:28 PM |
Fuel Pressure Drop on my LS BRZ | Shahano | Engine Swaps | 6 | 04-28-2021 04:57 PM |
Intermittent fuel pressure/signal drop (Fuel regulator prob?) | Decimus | Issues | Warranty | Recalls / TSB | 6 | 03-27-2019 07:38 PM |
Temperature drop, tire pressure check! | radroach | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 11-07-2016 08:43 PM |
