03-17-2014, 10:44 PM | #3991 | |
Drives: 13 BRZ Limited, 2000 Impreza Sport
03-17-2014, 10:49 PM | #3992 | |
Drives: Subaru BRZ with Delicious Innovate
How long has this kit been out and i have only ever seen 1 post with a log of IAT post charger and it was clearly not reading the air temperature. That's something I would still like to see and something I AM going to get myself.
03-17-2014, 11:04 PM | #3993 | |
Drives: 2013 SWP BRZ
03-18-2014, 01:13 AM | #3994 |
Drives: 2013 Asphalt FRS
Now that my car is issue free the Wife n I took her for a 270 miles cruise to the coast n back. Lots of 0-10% grade over the hump between Portland and seaside. Avg'd 29mpg and went 270miles with 1/4 a tank to spare. The new tune is working wonderfully.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
The Following 4 Users Say Thank You to NickFRS For This Useful Post: |
03-18-2014, 04:24 AM | #3995 | |
Drives: UK GT86
My car.....
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | calispec (03-18-2014) |
03-18-2014, 09:05 AM | #3996 |
Strange development for those following my post about the coolant leak/mystery. The level did go down to the low mark when I posted the other day. I've driven the car three times now (total of about 25 minutes or 15 miles) and checked the level at every interval along the way. It seems to be holding at the same level fine now.
My only thought is that I've been driving very conservatively which I had been since installing the intercooler (mostly due to snowy weather and ironing out the tune). When I was losing coolant at first it was under many WOT pulls which is uncommon for me. One trip under normal conditions did result in a drop in the level. Very strange, I'll be keeping an eye on it. At first I thought perhaps the weather change might have caused some evaporation but I still don't have any answer. I'm heading to Europe this weekend so probably won't have time until April to take a look if I need to pull the manifold.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) |
03-18-2014, 09:09 AM | #3997 | |
Drives: UK GT86
.: Stealth 86 :.
03-18-2014, 12:08 PM | #3998 |
I squeezed those pipes for over an hour, and I still had to fill it up a few times after. Then again I also did have a slight leak, but that was by far the worst part of the whole intercooler install
The Following User Says Thank You to xxscaxx For This Useful Post: | Xero-Limit (03-18-2014) |
03-18-2014, 08:27 PM | #3999 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
03-19-2014, 03:27 AM | #4000 |
Drives: UK GT86
@moto-mike just for you.....
Wire type IAT sensor and MAP sat in the manifold. The manifold had to be modified (drilled) to allow the sensor to fit.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Xero-Limit (03-19-2014) |
03-19-2014, 08:13 AM | #4001 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
@Kodename47 which IAT sensor did you use and who made the adaptor plate? Was it something you had made locally? Interested in how this comes out.
03-19-2014, 09:19 AM | #4002 | |
Drives: UK GT86
.: Stealth 86 :.
03-19-2014, 10:28 AM | #4003 |
Twin Screw You
Hopefully that one will function correctly. I had planned on trying to design one myself seeing as the ones that have been used before didn't read correctly. Keep us updated on if it works well.
03-19-2014, 10:42 AM | #4004 | |
That Guy
Drives: 2013 asphalt FRS MT
From what he said, I think the key isn't the design of the plate, but the design of the fact that he drilled out the hole in the manifold a little bigger to prevent the sensor from touching it. Is anyone else concerned that the sensor is actually in a runner and not in the plenum? |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
