02-12-2014, 12:07 PM | #3347 |
Drives: 2013 SWP BRZ
I think i'm going to go baller status and replace mine with ARP hardware. lol
02-12-2014, 12:47 PM | #3348 | |
Grip>Slip
Also going to pull the manifold when I do it this time to see if that method is any easier. |
02-12-2014, 12:50 PM | #3349 | |
Those strip seals stayed in there perfect for me when I applied some dielectric grease on them. I had to pull the sc off after i placed it down the first time, and they were stuck on there nice. Never moved. It may be easier, but I didn't want to go through the trouble of disconnecting all the fuel lines, then the injector covers, etc. But, it probably would have been faster seeing as those 2-3 bolts gave me a huge problem getting them off since they were in there tight, and you only have so much room with an allen key. |
02-12-2014, 12:54 PM | #3350 |
Drives: Attitude
Who said catch cans do nothing? A properly designed (read: good baffle plate or media) can will absolutely help raise effective octane due to less oil blow by making its way into the combustion chamber...as your mate very thoroughly explains.
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | evan (02-12-2014) |
02-12-2014, 01:53 PM | #3351 | |
Grip>Slip
Do you have pictures of the replacement clamps they sent you? |
02-12-2014, 01:54 PM | #3352 | |
Drives: fr-s
02-12-2014, 01:56 PM | #3353 |
Grip>Slip
02-12-2014, 02:00 PM | #3354 | |
I don't have a pic but I can take one later if you really want. But they just look like the standard worm drive clamp like this: |
02-12-2014, 02:00 PM | #3355 | |
Drives: fr-s
Was the drivability that much worse? I'm guessing you're using ECUtek? Evan |
02-12-2014, 02:04 PM | #3356 | |
Drives: Subaru BRZ with Delicious Innovate
02-12-2014, 02:06 PM | #3357 |
You know I accidentally pulled that line up and almost off when working on putting my IC on. I was thinking of how to get a clamp on there, but then said F it because I couldn't reach in there.
02-12-2014, 02:10 PM | #3358 |
Yeah I pulled mine off when installing my catch can.. then I said F@#K when I realized where it had to go..
02-12-2014, 02:32 PM | #3360 | |
Grip>Slip
The Following User Says Thank You to xjohnx For This Useful Post: | evan (02-12-2014) |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
