Old 04-27-2015, 06:50 PM   #267
Racecomp Engineering
Originally Posted by cdrazic93 View Post
This just popped into my head (either its a super simple answer or complicated) if you match the perfect spring rate to the dampening force, you achive the critical damping ratio (~0.65). When you add adjustability, wouldnt that change the critical ratio? Or is the ratio more of a range thats acceptable given on road circumstances, i.e. higher ratio would be for track and a lower ratio would be on a street car.
The critically damped ratio is 1.0. The 0.65 recommendation is to get minimal overshoot and settle the car quickly.
The Kaz link posted was pretty good (also the part about not getting hung up on ride frequencies, but that's for another time).
"In reality, the damping curve of an actual damper is composed of at least four damping ratios or damping rates. These are typically low speed compression, low speed rebound, high speed compression and high speed rebound"
You may not want the same damping ratio throughout all piston velocities (read: you can do better than that). It bothers me a little when you see a blanket recommendation of "You want to be 65% critically damped" with no further explanation.
As the article said, the "correct" damping ratio is the one that makes your car go fast. It is true that 0.65 is a good place to start your testing. Same idea with the common recommendations on spring frequencies.
There is much more to talk about and I hope to write something later.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
fika84 (04-28-2015)
Old 04-27-2015, 07:02 PM   #268
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
i had a feeling that each adjustment needed its own ratio, but i only knew of the 0.65 (.707), didnt know that was for low speed...
Old 04-28-2015, 09:27 AM   #269
RBbugBITme
Drives: S60R/Corvette
When you have the ability to manipulate all areas of the damper curve you can easily end up with greater than 1 damping ratios in some areas and zero damping in others depending on the application. Understanding this, the knock on affects to springs/ARBs, and the ability to apply it is more critical to going fast than most people are aware. Engines are so much easier to deal with.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
The Following 3 Users Say Thank You to RBbugBITme For This Useful Post:
cdrazic93 (04-28-2015), fika84 (04-28-2015), Racecomp Engineering (04-28-2015)
Old 04-28-2015, 09:33 AM   #270
Right on.
- Andy
Old 04-28-2015, 01:23 PM   #271
fika84
fika84's Avatar
Dampers are confusing to think about because you have to think of something adjusting depending on speed instead of displacement... How do you tune for every different slope change on the ground??
@cdrazic93 It's even more confusing when you start to think that Formula 1 adds acceleration to the mix! https://www.google.com/search?q=j-da...sm=93&ie=UTF-8
fika84 is offline   Reply With Quote
Old 04-28-2015, 01:48 PM   #272
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
Old 04-28-2015, 01:51 PM   #273
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
What would that translate to on the graph? When you say all areas im assuming you mean a quadruple adjustable shock.
Old 04-28-2015, 02:47 PM   #274
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
*cue the angelic chorus*
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 3 Users Say Thank You to Shankenstein For This Useful Post:
Amaya (04-28-2015), cdrazic93 (04-28-2015), fika84 (04-28-2015)
Old 04-28-2015, 03:11 PM   #275
fika84
fika84's Avatar
It modifies the slope of the line. The slope is the damping rate (N-s/mm) when the graph is Force (N) vs Velocity (mm/s).
Old 04-28-2015, 03:16 PM   #276
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Theres no real time graphing you can do to tune a shock with its adjustments...are there? Besides a shock dyno, like leaving it on the car? Do any of the suspension models get computational enough to take all this into effect?
Old 04-28-2015, 03:24 PM   #277
fika84
fika84's Avatar
There are probably some clever ways to do it. You can input real data into the shock dyno for a given track. You can run the shock dyno at multiple different programmed speeds and use the data in data acquisition to get as close to real time damping ratio as possible with linear potentiometers on the shocks to measure displacement and velocity.
The hardest part about trying to do it purely computational is coming up with the right equation for the road surface... it's not a sine wave . Best way to do it computationally would be to drive the surface, take the data from the linear potentiometer and use that as the input for your differential equation.
The Following 2 Users Say Thank You to fika84 For This Useful Post:
cdrazic93 (04-28-2015), Racecomp Engineering (04-28-2015)
Old 04-28-2015, 03:25 PM   #278
Do you mean like shock position sensors? Those are incredibly useful for dialing in shocks...generally not used for adjusting on the fly though.
EDIT: i'm slower than fika84 today.
- Andy
fika84 (04-28-2015)
Old 04-28-2015, 03:27 PM   #279
fika84
fika84's Avatar
- Andy
And I don't even OWN a racecar...
The Following User Says Thank You to fika84 For This Useful Post:
Old 04-28-2015, 03:57 PM   #280
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
oh dear. Shots fired.
The Following User Says Thank You to cdrazic93 For This Useful Post:
fika84 (04-29-2015)
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ Hachiroku BRZ First-Gen (2012+) -- General Topics 350 02-02-2013 01:52 PM
Need opinions on two new items we're developing! yospeed Cosmetic Modification (Interior/Exterior/Lighting) 56 12-03-2012 02:13 AM
Chances of Someone Developing 5x114.3 HUBS (not spacers)? Entropy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-04-2012 03:35 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) -- General Topics 68 02-14-2012 07:16 AM
