01-22-2013, 03:56 PM | #267 |
Drives: Monkey-butt red FR-S
Wow, it's good to discover the Hotchkis front is too stiff. After all, I only ran it in RTR for half the last season in the AZSolo and the AZBR regions and was doing really well. Plus, I have been letting some of our top locals run it, and none of them said it was too much bar.
But, it's good to know. |
03-08-2013, 10:18 AM | #268 |
i'm sorry, what?
Drives: Canada
So i'm reading the coil-cooler thread, and now i'm reading the stock class/ rtr rules and oil-coolers are not permited
sad fucking panda what's up with that?
03-08-2013, 10:29 AM | #269 |
Yeah there has been some talk in the past about allowing those. They aren't even allowed in the ST classes where people would be even more likely to have them. I could see them being allowed in ST if someone just wrote a letter to propose the addition.
I don't see an oil cooler as a performance benefit, it wouldn't really even come into play on an autocross course. They allow catch cans in stock class so there is some precedent. |
03-08-2013, 11:22 AM | #270 |
Drives: 2021 Supra / 2022 Tundra
The goal in SCCA is to keep stock as reasonably stock as possible plus the old rules inherited that made cars in past eras handle reasonably well (shocks, sway bar). There have been small concessions over the years (shift knob, catch can), but it just makes it hard in most cars to have a stock class car that you take to the track at times.
TomR
03-08-2013, 09:23 PM | #271 |
Drives: 2012 Miata
Well put Tom, if anything the stock class ruleset should be taken back some rather than allowing more. However, I can see oil coolers being allowed in ST* classes, since most casual track-day cars would fall into them mod-wise. There is debate going on right now regarding allowing them in Street Touring, but don't expect to see them legal in Stock anytime soon.
Mark Scroggs
Edge Motorworks 2013 Subaru BRZ STX #30/130 Special thanks to Edge & Perrin Performance https://www.facebook.com/EdgeMotorworks |
03-13-2013, 10:46 PM | #272 | |
Drives: ND2, formerly BRZ (MT/CBS)
I'm not really into exhausts so to speak, but I did want to drop some weight with minimal hassle. So, with the Borla cat-back system for 'inspiration', I had a local shop fab up a system. First, they removed everything starting just forward of the small box resonator. Total weight removed according to my scale was 42.7 lb (3.8 box res + 12.5 mid/resonator assy + 26.4 axle back assy). They replaced that with 16 ga 2.5" OD SS tubing, a centrally-located Borla 40942 muffler, and more 16 ga 2.5" OD SS tubing. That's it - single exit, no tip, just functional. Total weight added back was ~20.6 lb (8.0 muffler, 11.6 pipe, ~1 for unmeasured hangers and welding), so the total savings is approximately the same as a muffler delete. I don't put a lot of stock in exhaust videos, but I put this together just to see how it would turn out and compare to other videos: I tried some inside shots with the gopro mounted to the side window, but at moderate revs you can't really hear the exhaust at all over the wind, road, and mounting/housing noises. In person, there are a couple interesting resonances in the 2k-3k range, but nothing bothersome and overall I'm satisfied with it. As far as any power increase, I have no idea. I have no plans to dyno it and the axle-back part is 'crush bent', which probably compromised the benefit of the 2.5" a bit. cheers! |
03-14-2013, 08:00 PM | #273 | |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
There is no reason a stock class car should require an oil cooler at autocross speeds and autocross lap times unless you are hot-lapping the bejesus out of the car. ...and it that case, you should probably let your tires cool down before they start chunking. But to Tom's point above, yea the stock class rules for autocross don't really consider a "stock" autocross/track day car where some of those more preventative reliability modifications are important. There has always been a rule disconnect there.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ Last edited by Sccabrz192; 03-14-2013 at 08:36 PM. |
03-14-2013, 09:45 PM | #274 | |
i'm sorry, what?
Drives: Canada
03-17-2013, 01:56 PM | #275 |
I think at some point the rules will be rewritten to cover what modern enthusiasts do to their cars and what makes the most sense. HPDE didn't really exist back when those rules were written but is extremely popular now. I'd like to see them allow upgraded radiators and oil coolers in stock.
There has been a lot of talk on other forums about stock class recently, like the current shock rules. I'd love to see them downgrade the current shock rule and add the ST allowance for front camber adjustment to stock class. It would help out all the camber limited cars and potentially save people a lot of money on race tires. |
03-18-2013, 02:50 PM | #276 | |
Drives: Whiteout FRS- autocross ready
03-18-2013, 02:57 PM | #277 | |
i'm sorry, what?
Drives: Canada
and it's not a slippery slope because i don't see how you're going to constitute a larger turbo as a safety feature
03-18-2013, 03:33 PM | #278 |
Overthinking it
Drives: BRZ in CS
It is
These are the rules. Pick a car. It is NOT Pick a car. Adjust rules your benefit. |
The Following 2 Users Say Thank You to mla163 For This Useful Post: | race2win (03-18-2013), whataboutbob (03-18-2013) |
03-18-2013, 03:55 PM | #279 | |
Drives: Scion FRS
We're not happy till you're not happy 2013 Scion FRS Whiteout 6MT SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover. |
03-18-2013, 04:29 PM | #280 |
The stock class rules are ancient compared to the other classes, they haven't really seen many revisions at all. The shock rules are from a time when shocks on most cars were terrible, and the tire rules are from a time when none of the classes ran on "street" tires.
Oil coolers and radiators aren't exactly performance items, they are for reliability and generally just add weight. There is an allowance for using catch cans in stock, that arguably has more of a performance benefit than either of those items. Unless you have a really crappy car, neither of those items will ever come into play on an autocross course. Stock is at a point now where people are starting to question the rules. I'm fine with limiting the real performance enhancing items in stock like shocks, race tires, etc. I have Hoosiers but I don't see a point to them anymore, street tires are really really good at this point. |
Similar Threads | ||||
2012 BRZ/FR-S Stock Class Autocross Discussion | EMguy | Tracking / Autocross / HPDE / Drifting | 183 | 01-04-2013 03:17 AM |
What SCCA autocross class will the FRS be most competitive | SVThis | Tracking / Autocross / HPDE / Drifting | 5 | 07-30-2012 04:29 PM |
Share/discuss (this mornin) 86 Newsletter... | RebootWindows | AUSTRALIA | 6 | 07-19-2012 04:15 PM |
SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
Discuss.... | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 02-11-2012 12:55 PM |
