Software Tuning Discuss all software tuning topics. |
10-03-2014, 05:33 PM | #15 | |
Drives: UK GT86
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (10-03-2014) |
10-04-2014, 01:40 AM | #16 | |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
knock correction advance max A is probably what you would call the advance map. It contains values between 0 and 6 degrees and has load and rpm parameters on a large graph just like base timing A and B... From what I understand, the ecu uses values in the active cell from knock correction max advance A, then multiplies them by IAM(which is 1 because I have no knock), then as far as I know, the only thing it does with that value is display it as KC learned in datalogs. lol... I'll go read some more, please don't kill me. |
10-04-2014, 02:19 AM | #17 | |
Have a read here http://www.ft86club.com/forums/showthread.php?t=61820 Base_TIMING_B is used during normal operation Base_Timing_A is for limp home mode |
10-04-2014, 03:55 AM | #18 |
Drives: UK GT86
Kinda, the AVCS (VVT) isn't active on cold engine start and doesn't become active immediately. I assume that's why that map is there as changes in overlap will affect the dynamic compression ratio.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (10-04-2014) |
10-04-2014, 03:00 PM | #19 | |
Also, to which table should I add advance? Base Timing B or the KCA table? Last edited by BuBlake; 10-04-2014 at 03:11 PM. |
10-04-2014, 04:31 PM | #20 | |
Drives: UK GT86
As to which table you add to is up to you. Is this on E85 or petrol?
.: Stealth 86 :.
10-04-2014, 05:49 PM | #21 | |
once the eu has used up the values in kca table it appears it can no longer reduce timing via iam fbkc or flkc . I suspect that the values in the kca table are selected to be larger in the knok prone areas such that when the iam applies a percentage reduction more timing is pulled in certian areas ie where kca value is larger. |
10-05-2014, 03:39 AM | #22 | |
Drives: UK GT86
Personally, if you have a good base to start on, I like to add to the advance table.
.: Stealth 86 :.
10-05-2014, 04:50 AM | #23 | |
Drives: UK GT86
I found the answer
.: Stealth 86 :.
10-05-2014, 04:58 AM | #24 | |
10-05-2014, 05:05 AM | #25 |
hopefully that applies to brz/86 ecu as i think merchgod left before the advent of our ecu, i would reckon it would run a similar method.
I think someone quoted 2.9 as the value in the kca table that is the cutoff for rough correction, i figure the kca table has that strange curve or values for some reason probably known to the subaru/toyota engineers so i like to leave it alone and make adjustments with base timing B , that just my preference based on my liited knoledge. |
10-05-2014, 05:57 AM | #26 |
@Kodename47
dug up an old log where I had a bit of knock. It using Tactrix to log and parameters provided by open source romraider guys but it appears to show that KCA can be 0 or negitive ? and that even when KCA =0 the FLKC correction is applied to the total timing value. Assuming the log parameters RAM addresses and scaling are correct. although in some areas it does not seem to add up unless some other compensations are being applied. http://datazap.me/u/steve99/98-knock...zoom=2020-2314 |
10-05-2014, 07:00 AM | #27 |
Drives: UK GT86
I just read the whole knock control thread on Romraider again, it is as I thought. FBKC and FLKC are always active so long as you're within the defined operating ranges and can apply up to their independent set maximum retard value regardless of IAM and the advance table value.
I need to look deeper into the appearance of "Ignition Correction - Fine" on logs as it's hard to determine on that thread whether it shows as immediate correction as per FBKC or just as historic knock, or pre-learnt knock if you will. I've gone back and forth on what I think happens, if it's the latter it's much harder to locate the exact area that has an issue.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (10-05-2014) |
10-05-2014, 07:05 AM | #28 | |
Drives: FR-S Whiteout
Similar Threads | ||||
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1212 | 03-10-2023 11:07 PM |
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) | DesertFrs | Northern California | 14 | 04-24-2014 03:15 AM |
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
2000 mile review, road trip to Road Atlanta & a chat with Randy Pobst. | Mtechnik | BRZ First-Gen (2012+) -- General Topics | 0 | 08-03-2012 11:07 AM |
