Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-07-2014, 10:28 AM | #15 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 09-07-2014 at 10:38 AM. |
09-07-2014, 11:00 AM | #16 |
Thanks
Just buy a Prosche, it already has a Boxer pushed as far back as possible.
The Following 3 Users Say Thank You to ZionsWrath For This Useful Post: |
09-07-2014, 11:31 AM | #17 |
Dismember
Drives: 2013 Red Scion FR-S
Just drive from the back seat.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post: | Apoc (09-07-2014), Captain Snooze (09-07-2014) |
09-07-2014, 12:23 PM | #18 |
Drives: 2013 GBS BRZ Limited
If I got bit by a monkey.......what kind of a shot would they need to give me?
How much do you think this building weighs? |
The Following User Says Thank You to stugray For This Useful Post: | Captain Snooze (09-07-2014) |
09-07-2014, 12:53 PM | #19 |
Unless you tell us what species of monkey and pics of you being bitten we couldn't possibly tell you which intake is best.
“The World is Flat”
[||•]=(86)=[•||] |
The Following User Says Thank You to Apoc For This Useful Post: | Captain Snooze (09-07-2014) |
09-07-2014, 08:32 PM | #20 |
Señor Member
It might be a worthwhile thing for the turbo guys, to create some breathing space behind the radiator but for an NA setup I can't see the result being worth the trouble.
1974 TA22 Celica
2013 86 GT |
09-07-2014, 08:48 PM | #21 |
Off Topic
09-07-2014, 09:05 PM | #22 |
Because compromise ®
Drives: Red Herring
308 Winchester?
The Following User Says Thank You to Captain Snooze For This Useful Post: | reardrv (09-08-2014) |
09-07-2014, 09:24 PM | #23 | |
Drives: 2017 Subaru BRZ PP
Toyota + Subaru =
09-07-2014, 09:32 PM | #24 |
No Carlton...
"If they were to carpet the state of Florida, how long would it take to vaccum it?" 99 bottles of beer on the wall...."If the bottles keep falling off the wall, why do they put them up there in the first place?" "Why do they call them handcuffs if you wear them on your wrists?" |
09-09-2014, 01:08 PM | #25 | |
What makes you think you are going to Engineer a better handling car? Have you (or anyone) done any simulations based on moving the engine? Show me balance, stability, grip and response graphs with the engine in different locations and I might believe what some of these engine swappers think... probably not though. |
09-09-2014, 01:22 PM | #26 | ||
But for all-out performance, I would guess a 50/50 setup would be faster because of how much weight you can transfer to the drive wheels on exit. Also better braking. With low-output cars like ours though, it probably doesn't matter as much. Quote:
2022 BRZ Build 2013 FR-S Build |
09-09-2014, 05:29 PM | #27 | |
Drives: Red Herring
Extreme but excellent example: [ame="http://www.youtube.com/watch?v=c_INdbXMqsw"]Track Test: Nissan DeltaWing Driven At Road Atlanta -- /CHRIS HARRIS ON CARS - YouTube[/ame] The explanation starts at 6.50 Given that the 3 variants (BRZ/86/FR-S) all have different f/r spring rate ratios the optimum distribution hypothesis is immediately dismissed.
09-09-2014, 05:43 PM | #28 | |
Like you, I also suspect (although haven't seen it quantified) that a moderate rearward balance would be even better for pure performance. Something like the Cayman's 46/54 or even the Carrera's 38/62. You get: - more even weight distribution under braking - more rearward weight distribution under acceleration - less weight upfront for better turn-in The main downside I see is, if the rear end did let go, it would be a wild ride, as it was with the old 911's. But that might more specifically be a function of the polar moment of inertia rather than weight distribution. If you could centralize the weight sufficiently, you could minimize this downside.
The Following User Says Thank You to DarkSunrise For This Useful Post: | Captain Snooze (09-09-2014) |
Tags |
brz, engine swap, fr-s, frs, motor swap |
Similar Threads | ||||
FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 05:19 AM |
Do the front seats go all the way back in a lying down position | sci3 | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 08-15-2014 05:31 PM |
Moving Back | pearsor1 | Hawaii | 0 | 03-03-2014 11:57 AM |
I am moving back to Portland | Tanuki | Northwest | 10 | 08-25-2013 08:12 PM |
Moving in neutral....Engine turns off? | deedz | Issues | Warranty | Recalls / TSB | 23 | 04-23-2013 09:23 PM |
