04-29-2013, 10:56 PM | #15 |
Works for me as does the dual control. But 95% of time windows down
04-29-2013, 11:00 PM | #16 |
Drives: 2013 BRZ Limited 6MT GBS
I always have AC goin at 60 and the lowest setting year round lol I'm always hot.
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist |
07-27-2015, 12:37 AM | #17 |
Drives: 2015 BRZ Ltd 6MT
Does anyone have the actual temperature that comes out the vents? I'm getting high 40s and low 50s, with recirculating on.
07-27-2015, 12:40 PM | #18 |
Drives: FR-S MT
The car runs hot, so I turn on my A/C when its above 64 degrees outside.
07-27-2015, 12:58 PM | #19 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
A/C robs HP I leave it off because racecar!! I dont use it often because I dont mind the heat and I like my windows down so I can listen to my crickets that power my car. It is important to make sure your crickets are well fed and chirp loud hahaha!!
07-27-2015, 01:08 PM | #20 |
Drives: FR-S MT
I recently had the HPFP replaced. A couple of miles away from the dealership I lifted the hood to listen. It was nice and quiet. But then while I was listening they suddenly chirped in again.
05-27-2016, 10:37 PM | #21 |
What temperature do you put A/C on
I believe theres already a thread for this titled "what did you do to your Camaro today?"
05-28-2016, 11:41 AM | #22 |
Drives: 2020 Hakone Edition, 2015 FR-S
I also start using the A/C at an outside temp of around 64 degrees on a sunny day if I have the windows up. The solar heating in the car is pretty fierce. However, these cars are great to drive with the windows open. So if the weather is nice, I will open windows around 60F and drive that way w/o A/C up into the low 80's.
05-28-2016, 12:56 PM | #23 |
Noob
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
I open the windows in the 40s and just leave the heat on. The leave the windows open and turn the ac on in the 70.
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599 -1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black |
06-13-2016, 08:55 AM | #24 |
Drives: World Rally Blue BRZ Limited, MT
I rarely use the AC. I The only time I use it is when the humidity is high and its above the high 80s. Other wise I'm a windows down kind of guy.
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear |
Similar Threads | ||||
Temperature not reading below 0 | BrewCity-FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-22-2013 10:05 AM |
BRZ temperature display malfunction | percyng | CANADA | 7 | 10-24-2012 09:31 PM |
Seat heater temperature? | milenko11 | BRZ First-Gen (2012+) -- General Topics | 29 | 09-20-2012 01:19 PM |
Disp Temperature not accurate | marinjim | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 08-22-2012 08:16 AM |
Engine temperature | Skye | Issues | Warranty | Recalls / TSB | 5 | 08-09-2012 10:33 PM |
