Old 04-19-2013, 01:03 PM   #15
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Originally Posted by rupert View Post
Thanks! I have added you to the list
Thanks!!!
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 08-25-2013, 06:56 AM   #16
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
General Information
Speaker Sizes
  • Tweeter: 1"
  • Midrange: 3.5" (Depth: 2")
  • Woofer - 6.5" (Depth: 2" without spacers)
  • Rear - 3.5" (Depth: omgwtfbbq a.k.a. enough)
Thank you!
Can I note- The wiring diagram says 6.3" for OEM doors ;P not that it matters.
Also, in the diagram, I'm noting that basically, (off the amp at least,) the front speakers are all wired together, so if I do a 4 CH amp I'm good right?
zohare is offline   Reply With Quote
Old 01-08-2014, 04:49 PM   #17
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Somewhere is a post where someone removed the stock speakers and took pictures of the specs on back. Can anyone find that post and add it to this list? So far I am unsuccessful.
oldpueblo is offline   Reply With Quote
Old 01-08-2014, 09:31 PM   #18
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
My stock speakers are somewhere since I have done my install. I can look tonight for them and see if I can get any good information off of them.
rupert is offline   Reply With Quote
Old 01-08-2014, 09:36 PM   #19
oldpueblo
oldpueblo's Avatar
Thanks. I'm actually happy with the stock system and will just be adding a powered subwoofer. I'm interested to see what frequencies might be best left to the stock system and where I should cross over the sub. I think the stock 6.5 subs actually do decent mid-bass already.
Also if I decide to replace stock speakers, knowing what their specs are will make it easier to buy better ones.
Old 01-28-2014, 11:37 PM   #20
scott86
Drives: 2013 Toyota 86 GTS
Custom sound in 86
Hi all
First post on here so i hope it goes into the right place!
OK so how about the Australian 86 doesn't have a spare wheel (Bit odd I thought!) but it all made sense when I custom molded a fibreglass sub enclosure into it - including a 700rms JL Audio 5 channel amp with Morel 200rms front splits on custom spacers in the front and a single din Alpine head unit
Leads for power and speakers are Stinger and cabled on opposite sides of the car to reduce/eliminate interference
Some photos to follow - but sound is incredible and sub though only a 8 inch proves more than enough thump
Cheers Scott
scott86 is offline   Reply With Quote
Old 01-30-2014, 07:43 PM   #21
rupert
rupert's Avatar
Originally Posted by scott86 View Post
Hi all
Cheers Scott
Hey Scott! Sounds like you have a nice setup. If you want, post a new thread that shows it off. I would be happy to link to it and make sure future people can see what you have done.
Old 01-31-2014, 05:22 AM   #22
labskaus
labskaus's Avatar
Drives: Toyota GT86
oh ... please also add my Thread in Audio Builds
http://www.ft86club.com/forums/showthread.php?t=47487
labskaus is offline   Reply With Quote
Old 01-31-2014, 03:24 PM   #23
rupert
rupert's Avatar
Done!
Old 08-17-2014, 12:57 AM   #24
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I'm getting my system upgraded =) stay tuned for another build thread.
CamryDS is offline   Reply With Quote
Old 01-21-2015, 12:01 AM   #25
jeffsquared
Drives: 2013 FR-S 10 Series #1186
Suggest adding these android HU threads?
Another Android Head Unit
Another Android radio (KGL/Klyde/RoadMaster/GS/JY/MD) - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB
jeffsquared is offline   Reply With Quote
Old 07-22-2015, 01:19 AM   #26
RJ_
RJ_'s Avatar
Has anyone installed one of the small Focal FD amps yet?
RJ_ is offline   Reply With Quote
Old 08-25-2016, 03:58 PM   #27
kenrickv
Drives: 2016 FR-S
6 pin harness
I've read somewhere in these posts about the unused 6 pin harness behind the stereo. It had constant 12 volt, an accessory 12v, a ground and a couple CAN signals. I can't seem to find the pin out. Anyone remember what thread this was in?
Edit: got the info needed. Pin 3 is 12V switched and pin 2 is ground. Powers an Alpine KPT amp pretty good.
kenrickv is offline   Reply With Quote
Old 08-01-2017, 04:29 PM   #28
reynierpm
Drives: Toyota 86 2017 Black
General Information
Speaker Sizes
  • Tweeter: 1"
Is this information accurate for a Toyota 86 2017?
reynierpm is offline   Reply With Quote
FR-S / BRZ DIY Directory WingsofWar DIY (Do-It-Yourself) Guides 77 02-02-2019 11:58 PM
Directory 86 Tanuki Site Announcements / Questions / Issues 17 10-10-2013 04:55 PM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
